Question about Compaq Armada M700 Notebook
Compaq armada m700 wont boot up
Everytime i try to boot up my laptop it wont boot up it runs a check disc with no problem then it goes to this screen of dumping physical memory once that is done it tells me to contact support but i know there is a way i can do it myself
  • Anonymous Feb 20, 2009
    when i start doing my work in the middle it displays a blue screen telling "dumping physical memory"and i tried to reboot the system but it is getting restart gain without booting.it is not even going to the safe mode.what should i do?
  • 3 Answers
Most of this kind of problem are located in a corrupt file or a bad sector on the hard drive that checkdisk won't repair you got two option to try. one make a backup of you files and reinstall the Operating sistem or try to fix the surface of the hard drive with an utility call "HDD regenerator" in the 70% of the cases I had it fix the problem specially in older notebooks whitout the need of reintall the OS. you will try and may be this fix your problem. (tihis utility comes in a disk called "Hiren"s" boot cd.)
Posted on Jul 29, 2008
Physical memory dumping
once your computer take an BOD or blue screen of *****. it is an indicator that one of you perepherals was damage. in that case you only have to option the memory cards or the HDD. if some point you dont experience a hard time in booting it is not the HDD. maybe your memory cards was in defective state. sometimes good sometimes bad. try to chkdsk first or scan your HDD for posible bad cluster. and make a test also in your memory using some stress memory tester
Aug 21, 2017 | Intel Motherboard
ThinkPad Blue Screen of Death
Sometimes the blue screen can be caused by bad memory, but if it is doing it right when you try to sign in every time, it is probably a software corruption in windows. I have solved this problem by doing a repair install of windows xp, I am not sure if is an option on other os, if you google it you will find directions, you boot off the windows install disk and this option saves your programs and data.
Oct 27, 2009 | IBM ThinkPad T22 2647 Notebook
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
Blue screen on my inspiron 6000
your hard disk has some eror it must need fixing.u can format your harddisk with win xp recobery disk.
Mar 16, 2009 | Dell Inspiron 6000 Notebook
Inspiron 600 m Dell blue screen
Keep pressing F8 as the computer starts up, select "last known Good Configuration" from the menu.
Jan 22, 2009 | Dell Inspiron 600M Notebook
Dump of Physical Memory
Put the Dell CD in the drive bay. Turn on the computer and start pressing <F12> key. It should say "Preparing one-tome boot" When the screen shows a selection menu for the boot device, use the arrow keys to select the CD and press <Enter> key. That should run the Dell CD. Follow the onscreen prompts to run diagnostics checks
Dec 16, 2008 | Dell Inspiron 8600 Notebook
Windows program shut down Laptop problem model-no-XPS M1530
As with any blue screen, this is an operating system error in which a driver or program has overstepped it's boundries by writing into an unauthorized section of the memroy, therefore causing the memory dump. You will need to run a system repiar or reload with your recovery disc or operating system disc in order to cure the problem. Start with the repair, if the rogue still persists, then you will need to wipe the hard drive and reload the operating system.
Jul 13, 2008 | Dell Inspiron 6000 Notebook
Disk Cleanup.
well..you sound as though there is too much on the disk..
Mar 29, 2008 | Dell Latitude CPI Notebook
Registry file failure
If the last suggestion i posted didn't work, you need to put in your Windows CD on boot up and when it asks if you want to repair or install press 'R' for repair, this should repair any damaged registry files and Windows files.
Nov 12, 2006 | Dell Inspiron 600M Notebook
Compaq Armada M700 Notebook Logo
161 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
