Question about OKIPAGE 14ex Led Printer
Error 71 fires up and prints a couple of prints, then error 71.
  • 36 Answers
Fault with the fusing unit
try changing the fuse
see
http://ezinearticles.com/?Xerox,-Okidata-Error-Codes-and-How-to-Fix-Them&id=1053652
Posted on Jul 18, 2008
Print unable 71
Print Unable 71 means Polygon Mirror Failure on the Brother HL-4040, MFC-9840 and MFC-9440.
Pretty safe to say it means the same thing on the MFC-8880.
The Polygon Mirror is part of the Laser Unit, and its rpm isn't within specs.
The Laser Unit must be replaced.
Jan 08, 2015 | Brother MFC-8880DN Mono Multifunction...
Error 71
Error 71 indicates that the laser unit has failed and will need to be replaced. A trained technician will need to be called to repair this problem.
Jul 08, 2013 | Brother DCP-9045CDN Laser Printer
I have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
What does Print unable 71 mean and what do I have to do to correct the problem?
Error code 71
Print Unable 71
Turn the power off and then back on again.
Polygon motor failure
Jan 03, 2011 | Brother MFC-9840CDW Laser Printer
My printer was working fine on Sunday and now th window icon says error 71 and I cant print anything. Please Help
Error 71 says the laser unit is bad, it's not spinning fast enough to print. The laser unit itself runs about $120.00
Nov 18, 2009 | Brother MFC 9700 All-In-One Laser Printer
GOT ERROR 71 PLEASE HELP
any of the error 7X codes are to do with the fuser. Call an engineer
Jun 04, 2009 | Brother MFC-8220 Fax
Brother 4100 fax error code # 71
Error 71 is a laser scanner error.
Inkworks
866-381-0541
Nov 19, 2008 | Brother IntelliFAX 4100 Laser Fax
Paper jam 71
Paper jam 71 is an error that occurs when a driver on the controller board (IC-28) begins to wear out, or the timing gets thrown off. This causes one paper feed motor to drag the other one. This error is normally accompanied by a loud grinding noise because of this. Kodak's newest firmware version is supposed to fix the problem. If that has no effect then the fix is to replaced the controller board.
Good luck.
Jul 07, 2008 | Kodak 6800 Thermal Photo Printer
OKIPAGE 14ex Led Printer Logo
545 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
