Question about Enfora PocketSpider (CDP0601)
Enfora Compact Flash Modem
Help with IPAQ
July 16, 2008 4:25 PM Subscribe I have an HP iPAQ 2750. Around the same time it was manufactured, lots of aftermarket hardware and software came out with promises to enhance the device. One of those applications was a GPRS/GSM plug in modem (via the CF Card slot) and software from a company called Enfora. The modem was bundled with software from a company called BVRP. There was other software without a modem which also installed phone tools on the PDA from another company called WebToGo.
HP sells the modem from Enfora which it claims is compatible with the iPAQ. But after many tries to install it, it seems ActiveSync 4.0 (which is what the iPAQ came with) was preventing it. I upgraded to ActiveSync 4.5 but still no luck with the Enfora/BVRP software.
I assumed the modem to be generic enough to work with any phone tools software, so I found different phone tools from WebToGo. Their phone tools did load onto the iPAQ. But after lots of calls to TMobile and more onliine chats with HP, I can't get the modem to see the TMobile network - this even after getting TMobile's cell to network number (*99#) and its modem string and web address.
I also thought there might be some issues with Windows Mobile 2003. I tried to upgrade to Windows Mobile 5, but the connection kept dropping. After going through that a few times, I decided the upgrade was more trouble than it's worth. Besides, all of the hardware and software says they work with Pocket PC 2002 and Windows Mobile 2003 anyway and the latter is what the iPAQ came with. So I decided that probably wasn't the problem.
I know I could just buy a smartphone, but I really like the iPAQ. But I don't want to keep carrying an iPAQ and a cell phone around - cluttered. If there are hackers who can break open an iPhone, it seems there should be somebody who can make this work? It seems like I'm almost there. Does anybody have any advice?
2 Suggested Answers
  • 36 Answers
SOURCE: Where I can get drivers for enfora gsm 0110 ?
Select the appropriate one and download from this link provided
http://www.enfora.com/index.cgi
Posted on Mar 31, 2010
Hp ipaq rw 6828 modem driver not installed looking for free download driver
Here lol:
http://personalcomputerdeni.blogspot.com/2013/03/hp-ipaq-rw6828-multimedia-messenger.html
Dec 18, 2012 | HP iPAQ rw6828 Smartphone
How do install a backup battery in my hp iPAQ hx 2750?
try HP ?
ask them?
you need manual. most things this old the manuals are hard to find
so ask HP or learn to google?
the real HP forum and support !
https://h30434.www3.hp.com/
Jun 29, 2017 | HP iPAQ HX2750 Pocket PC
Can i get on the internet without using a modem card?
Your PDA doesn't have a inbuilt modem or wifi, so you can't use the Internet without a modem card.
Here are the specifications of your iPAQ:
http://reviews.cnet.com/pdas/hp-ipaq-pocket-pc/4507-3127_7-30422067.html
Jan 14, 2011 | HP iPAQ H1945 Pocket PC
My ipaq 2750 has frozen on ProtectTools screen. I have activesync installed but it wont even recognise the cradle device
There's a chapter called 'Resetting your HP iPAQ' on your device's User Manual. Firstly, perform a soft reset. If it doesn't solve your problems, jump to the hard reset procedure. If it still doesn't do the job, then, perform the clean reset procedure.
Just in case you happen to miss its manual, you can download it from this location.
Hope you are able to sort your problems out.
Cheers! Carlos
Apr 23, 2010 | HP iPAQ HX2750 Pocket PC
Cf card does not work on my ipaq 2750. is there an upgrade or software fix?
dear sir,
i used moto E6 long time.its good.yesterday my phone is locked. i tried unlock it but not successfull.so i want to tell me this phone unlock code.
thank you.my e-mail id-ashugoel9876@gmail
Feb 18, 2010 | HP iPAQ HX2750 Pocket PC
I need a charger for my hp ipaq but i don't know what series
In general, there's three types of charger you might need. Really ancient iPAqs used a round DC jack type charger, then there was a long time where all iPaqs used the same flat 22-pin connector. More recently, HP has moved to the same mini-USB plug used for a lot of mobile devices.
If you're really stuck, try http://www.ipaqrepair.co.uk/store.php?cat_id=25 and match your iPaq to the pictures.
Jan 12, 2010 | HP iPAQ 612C Smartphone
I recently purchased 2nd hand a HP ipaq hx2000 pocket PC. It all appears to function ok apart from it will not recognise any compact flash card when I insert it into the slot. I have tried several CF...
Have you tried using an SD card? The hx2000 is supposed to support SD cards and CompactFlash Type II memory cards. If it doesn't respond, it's possible that your second-hand device simply has a faulty card slot.
May 10, 2008 | Computers & Internet
DELL LCD monitor E151FPb turn white
I also tried re-soldering joint L781 on the main power control board (see Solutions #2 and #7). It worked. My 15 inch Dell flat panel LCD is working again, white screen gone. The solder around the pin did looked different to to the other joints...a very slight gap around the pin as though it wasn't contacting properly. To locate L781, look at the bottom of the PCB (the side with the soldering) with the power plug socket at the edge closest to you. L781 is in the top left quadrant of the board, about 2 inches in from left, 1 inch down from the top. For good measure, I also tried the solution that suggested trimming a millimeter of the end of the two data ribbons that plug into the smaller control board, although I couldn't see anything wrong with the data ribbons. I did this at the same time as resoldering L781 so not sure if it made any difference.
Feb 25, 2007 | LG 37LP1D 37 in. LCD Television
Using TomTom nevigator
For use with TTN you'll need the following: -A GPS mouse (either wired or wireless if you have bluetooth on your ipaq) -TomTom software -Memory card (usually Secure Digital of Compact Flash) to store the differents maps on it. It's also recommended to have a card reader on your pc to transfer the maps on the expansion card. Good luck and let me know if it works out or not
Sep 19, 2005 | HP (FA162A#AC3) for HP iPAQ 2200/4100...
Using my iPAQ 6325 as a modem
only by bluetooth !!! Try to determine services on IPAQ by your-PC bluetooth device... You must to see the "dial-up modem service" --- select it and do a settings by provider...... that`s all !!
Sep 11, 2005 | HP iPAQ h6325 Pocket PC
Enfora PocketSpider (CDP0601) Logo
225 people viewed this question
Top Enfora Computers & Internet Experts
David Payne
David Payne
Are you an Enfora Computer and Internet Expert? Answer questions, earn points and help others
