Question about Trendware TRENDnet TEW-443PI 108Mbps 802.11g Wireless PCI Adapter (NETRWP18)
Router failed Hi, I have a modem since 4 years, and yesterday I looked at it under192.168.1.1 and it's not working more. I didn't move or change nothing.Perhaps, I don't know, I pressed at the end on " LOG OUT " and Icancelled all the router, instead of "FINISH " or something like that.My problem is now, I have none router, how arrange that problem ? ?Thanks Michael from Montevideo, Uruguay The modeel I have doesn't appear under all. TrendNet TEW-231BRP 802.11b
  • 4 more comments
  • charoval Jul 19, 2008
    Clarification Request
    by Latoof, posted on Jul 19, 2008Hi, to assist you I need to know which model router you have
    the V1 - retanglular case
  • charoval Jul 22, 2008
    `could not repear the router. All indications has been done, but still the router doesn't work. Is it corrupt? I don`t think so, but don't undertsand what is hapening with it ! ! !
    Thanks for your help, nevertheless.
    Michael
    Yes, but couldn't arrange the problem that I have. I am sorry, but your steps couldn't help me. What is going on, I don't know. Regards
    Michael
    I don't believe that the router is damaged. Something should be there, wrong and I can not find or arrange it to work.
    Michael
  • charoval Jul 23, 2008
    so what is thwe status of the lights on the front?
    ***** The lights are working as you has indicated correctly.-
    The system light is
    it on, off or blinking?
    ****** System light blinking as you informed.-
    did you press the reset button?
    ****** yes, has been done, two times, and nothing happened.-
    tryturning
    router OFF and then press hold the reset button for 10 seconds then try
    connecting to it with cable to set up using either 192.168.1.1 or
    192.168.0.1
    ******* also I did that, and none response. I can not inform you what I have not done, all detailed I tried.
    Thanks for help,
    Michael
  • Dave May 11, 2010
    the V1 - retanglular case or the C1 - curved case
    Sergeant:
  • 287 Answers
I assume that all lights are on as normal on the router.
Check the System light.
SYSTEM
This indicator blinks green means the Internet Broadband Router is
working successful. Otherwise, this indicator always on or off means the function of the Internet Broadband Router is in a fail state.
If the System light is either always on or off go to step 3 below, otherwise start at step 1.
1. power down router and wait 30 seconds and power up.
Try connecting via 192.168.1.1 then 192.168.0.1 if NO do step 2.
2. disable any firewall programs on the PC
Try connecting via 192.168.1.1 then 192.168.0.1 if NO do step 3.
3. do a factory reset of the router. on the rear panel of the router there should be a small hole with a small button maarked RESET. if you press this in for 10 seconds it should RESET router to FACTORY settings.
Try connecting via 192.168.1.1 and 192.168.0.1 if NO then the router firmware is possibly corrupt or there is some other hardware fault.
Posted on Jul 19, 2008
  • 2 more comments
  • Dave Jul 20, 2008
    thanks for posting the type of router. Ihave located a manual which will make things easier if I need to refer to settings in detail.
    Have you tried my posted ideas yet? What were the results.?
  • Dave Jul 22, 2008
    so what is thwe status of the lights on the front? The system light is it on, off or blinking? did you press the reset button? tryturning router OFF and then press hold the reset button for 10 seconds then try connecting to it with cable to set up using either 192.168.1.1 or 192.168.0.1
  • Dave Jul 23, 2008
    Hi Michael,
    sorry to hear it is still not resolved... Please confirm that when you connect the ethernet cable to the PC that the PC is assigned a valid IP by the router.
  • Dave Jul 23, 2008
    Here is a link to the quick guide and manual for your router. If you donot have these it may be worthwhile to d/l these and recheck that you PC IP configuraation is set correctly
    LINK
Hi, I want to set up my router to my DCM425 modem (from Time Warner). So far I cannot access the internet on my laptop. I get internet fine when the modem is directly plugged into my laptop, and I can also...
1) Make sure the cable is plugged into the Internet port (or whatever the appropriate port is, since you didn't specify exactly which router).
2) At your router's configuration page, make sure DHCP (Automatic) is selected.
3) After connecting to the router, if it still does not work, open up the command window by going to the search box in the Start Menu or click Run... and type "cmd".
4) Type "ipconfig /release". Wait until this is finished.
5) Type "ipconfig /renew". Wait until this is finished.
This should have given you an IP Address.
6) Try to connect to a website.
Jun 04, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
My modem light is blinking orange and will not allow for a wireless internet connection. MODEL f5d8236-4 V2 Router and state telephone modem. Just worked yesterday, didnt make any changes and it stopped...
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Jan 27, 2011 | Belkin F5D8236-4 Router
LinkSys router early deaths
Your cable modem has a ip address of 192.168.1.1 and your router probably has the same ip address. Hook your computer up to the router and change the ip address to 192.168.9.1. On your router change the router mode to static ip address mode. Then you will need to know your username and password from you cable company, and the Domain Number. Then connect the cable back to the wan port from the modem and the other end to the wan port of the router. Connect the computer to the first lan port on the router and type 192.168.9.1 go to the status page and tell it to connect.
Your cable company is giving you one ip addres and have to pay for another for more than one computer. What are you doing is using the router to receive the first ip address and distrubting out to the other computers.
Nov 24, 2009 | Linksys WRT160N Wireless Router
I cannot get my router to work
If you connect the computer directly to the cable modem, you are able to go online. that is a good sign.
Now it seems that the router and the modem are not communicating with each other. You will need to reconfigure the router or change the router settings so that both the devices will communicate.
Click Here for more info
Oct 12, 2009 | Linksys Wireless-N WRT150N Router
I currently have a cable modem that the Linksys router has been working with for the last couple of years. Yesterday it started acting up by not letting me go to some sites. Today, it has failed...
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Jun 21, 2009 | Linksys Wireless-G WRT54G Router
Mtu failing
ther is no probs with ur xbox it will com on today
Sep 30, 2008 | Microsoft Xbox 360 Console
Installed WRT54G2 With ATT Motorola DSL and cannect to internet. dsl worked fine before installing the Modem had AT&T recheck the dsl and was configeration correct was advised that my problem in...
hi there ...
your isp is at&t? please verify the ip address straight to the modem if its is 192.168.1.1 and if your modem from your isp is set to DHCP or BRIDGE mode.
IF IP address is 192.168.1.1 (DHCP)
... change the LAN IP address of the router to 192.168.2.1 or 5.1 to prevent any IP conflict
by doing this :
1. access setup page of router usually 192.168.1.1
2. under setup tab look for the ip address, change it, then save
3. click on the status tab , and look for a VALID ip address
IF MODEM is set to BRIDGE mode
.... please ask username and password from your ISP coz we would need to set your router to PPOE...
2. under setup tab look for INTERNET CONNECTION TYPE
3. select PPPoE
fill in username and password
select "keep"alive
save
4. click on status tab
look for LOG in TYPe ===> click CONNECT
if connected : check a valid IP address
if authentication failed verify again your username and password from your ISP
Aug 07, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Reply
OK let me know if you have any probs with setup. I may be able to help.
please
Jul 17, 2008 | Linksys Wireless-G WRT54G Router
Di-624 stopped working
Hi sailaway!
. Make sure the router is going from the modem, to the port marked WAN, on the 624. You can test the cable, by plugging it directly into you computer, from the modem, if you want to. Disconnect the power from your modem, your router, and turn off your computer Wait 1 min. Turn on the Router, wait three full min's. Power up the 624, and wait one min. Power up the PC. Reason for the long wait on the modem is that it has to get data from the internet, to give to the router. If that don't hwlp, try changing the cable from the PC to the router, to a different port. If all that don't work, try resetting the router by gentley pressing a straightened out paperclip into the reset hole in the back. Hold it for 30 sec. If that fail resetting it, try holding it in while you unplug the 624 and plug it back in. If it resets, go thru the first steps to set it up again. If all that fails, your 624 may be bad. Had that happen to me. The steps I listed brought it back to life for about 2 months, and it died completely. Good Luck!
Jan 05, 2008 | D-Link DI-624 Air Plus XtremeG Wireless...
Configuring EDIMAX 6104 for Aztech 600E Router
Does your router automatically set the ip addresses for each computer, or do you have to set them up yourself? Is the computer that can connect the one that is directly connected to the modem? if it does and you asked windows to repair the connection it probably is messed up. check in the router settings to see if your pc's are on the same ip address route (e.g 192.168.x.x), but not all the same last digit; and the subnet masks are all the same (eg 255.255.255.0)
Oct 25, 2006 | Edimax BR-6104 Broadband Router. One...
Computers & Internet Logo
112 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
