Question about Kenwood Car Audio & Video
Kenwood KDC-W5534U i keep losing the display any help would be appreciated thanks.
    Master:
  • 726 Answers
That is a flip down cd player or detachable some times on the back of the face the metel pins dont touch unit corrctly or when driving the faces moves slighty
try cleaning them
also can be a fault with the cd player
if its under warrenty take it back before it runs out this problem will get to were the face will have no display at all
Posted on Jul 18, 2008
    President:
  • 624 Answers
I have seen this problem many times and it is an easy fix if you know how to solder.
There are a series of suface mount resistors on the main board that are in the front right near the side, as you look into the radio with the top off and the radio facing you.
Let me know if you want to do this yourself and if so, I will post a diagram of the board and and point out just what resistors need to be resoldered.
I am certain that this is ther fix, I repair them for a living and have done many of these myself.
  • Dave DeGain
    Dave DeGain Jul 18, 2008
    I work at a Kenwood authorized service center and have repaired about 100 or more of these over the last year alone.
    All you need to do is take the cd mech out of the unit and you will see the surface mount resistors I am talking about. Of course, you must remove the radio from the car first.This can not be done in the car.
    If you are not good with a soldering iron, maybe you can find a friend who is, because this is a very easy fix if you can solder.
  • Dave DeGain
    Dave DeGain Jul 21, 2008
    Have you checked out what I have posted for your problem?
    I am certain that my solution will fix your problem. If you want the radio display to work 100% of the time, this is the way you do it.
    It is a common problem with your model of Kenwood and several other models of Kenwood. The surface mount resistors in the front right area of the main circuit board get heat stressed and cause this problem. I really have repaired lots of these and you should take my solution seriously.
    It would be appreciated if you would please respond back and let all of the experts offering you solutions some update on your progress. Any post you make on this thread notifies all experts who have offered you a solution that you have made a post. If you would like to target your post to any particular expert you can always start your post addressing it to who ever you wish to communicate with.
    Genius:
  • 1,665 Answers
You can get a service manual from link below but better if warranty has expired take it to a service shop to estimate if can be repaired at reasonable cost.
http://www.service-docs.com/store/search.php?searchstring=KENWOOD%20KDC-W5534U&showresult=true&exp=&resultpage=&categories=&msg=&search=search.php
  • 405 Answers
The best advice I can give you is to detach the faceplate and clean the contacts on the face and radio with rubbing alchol and a q-tip. As the face is removed and re-installed over time the contacts can wear out and get dirty. If this doesn't work then contact kenwood to check your warranty status as it is an internal problem.
Hope this helps
    Brigadier General:
  • 3,614 Answers
Is this happen while your driving or the car is on heavy vibration...? did you check if the unit was securely locked and fitted and mounted properly..?
Kenwood kdc-w5534u manual
You may download a copy of the instruction manual here.
Jun 15, 2012 | Kenwood KDC-W5534U CD Player
When i start the car all settings go back to default please help
sound like you have the yellow wire going to a switched power source. it needs to go to a constant power source to retain its memory.
Apr 29, 2010 | Kenwood KDC-W5534U CD Player
Kenwood KDC-MP428 - the display is out but works otherwise
there are several surface mount resistors on the right side inside of the deck that need to be resoldered.
Jan 07, 2010 | Kenwood KDC-X590 CD Player
Kenwood cd player not working correctly
there is a ribbon cable that goes to the screen from the main board that may have come unplugged. you'll have to remove the top case to see.
Dec 16, 2009 | Kenwood CD-203 5-Disc CD Changer
Display Problems Kenwood
the problem is more than likely bad solder connections on the surface mount resistors located on the right front of the deck itself.
Sep 17, 2009 | Kenwood KDC-W5534U CD Player
Connecting to the AUX input. Hard and software
you are connecting a cd PLAYER to an AMPLIFIER of some sort?
The rear connecters are audio/video out (red/white audio L/R and yellow is video) i assume rca connectors (phono)
The sound should be on for those connectors all the time, so no need to switch to audio out.
You connect to Aux in on the amp. and select Aux on that (amp meaning amplifier or stereo unit with aux in)
I hope this helps.
May 09, 2009 | Kenwood KDC-W5534U CD Player
Display doesn't illuminate on flipdown faceplate
Has unit gotten very cold lately? If faceplate is removable, remove it and clean the brass terminals with a CLEAN pencil eraser, wiking sure to blow off any rubber "crumbs" when finished.
Mar 10, 2009 | Car Audio & Video
Kenwood KDC-W5534U Display stops working any help would be appreciated
I have the same problem, and i will find a solution!
when i have it i let you know
grtz
Jul 18, 2008 | Kenwood KDC-W5534U CD Player
Lost code kenwood auto radio
Hello, I`ve lost the code nummber for my Kennwood Radio. Trying very hard to recive the code number but nobody can seem to help me.Any ideas ?
Mar 07, 2008 | Kenwood KDC-W5534U CD Player
Kenwood kdc w5534u
Hi! I have problem with usb...i try to connect 5 or 6 diferent usb flash device and after reading it shown that no device? it is a technical problem? Thanks!
Jan 06, 2008 | Kenwood KDC-W5534U CD Player
Car Audio & Video Logo
202 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
