Question about Philips Magnavox 51MP392H Rear Projection Television
50'' mag rear projection tv
When first turning on set there is a red and green arc on the bottom of the screen. After a half hour or so if I unplug and plug then turn it on the set will come back fine and stay fine until it is shut off again for the night. Most of the time it has to be unplugged and plugged in 5 or more times. Thank's in advance...Tony
  • Philips Master
  • 8,617 Answers
Your convergence ICs are getting weak and will end up going out . You can get new replacement ICs at the following link they are STK392-120 you need two ICs. I would also get at least 4 of the 6.8 ohm 1watt resistors. They provide free instalation instructions with pics.
http://servicemanuals.vstore.ca/
Posted on Jul 18, 2008
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
Tv tries to turn on but then turns off with a red
Lamp light on again?must replaced the lamp again,the lamp hours it up.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Red and green arcs, 3-D effect
Convergence is dead.Know how to solders?Replaced 2 Convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit.The shop will cost u $300 for parts and labors.
Jan 21, 2010 | Samsung HC-P4752W 47" Rear Projection...
Blue arc and ghosting across middle part of screen.
Replace Both of your convergence ICs they are big Black ICs will have STK on them! Use STK392-150s or the 180s Better ICs Call Mats Electronics 1-800-628-1118
Dec 21, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Phillips Model 60pp920217f
I expect the answer to your question is YES! The convergence amplifiers are a common problem in many projection sets. When you search for the replacements you should find that the originals have been superceded by improved parts. Also be aware that when these parts fail, they will usually damage a resistor in the convergence yoke return path. The resistor must be replaced with one of the correct value or the convergence, though responsive, will be out of range.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 29, 2008 | Mitsubishi WD-52327 52" Rear Projection...
D52W19 No pix, sound good - now green light blinks, no come on
First of all you need to find out which CRT leaked and replace it before any other repairs are done. The clear liquid is conductive and has done damage to the CRT board or boards.
Jun 15, 2008 | RCA D52W19 52" Rear Projection Television
Only half the screen is being projected?
i am having the same issue............any solutions??
Mar 31, 2008 | Toshiba 50H72 50" Rear Projection...
Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Green Arcs
You will need to have all three CRT's replaced. This was a common issue with this year of Sony projection TV's
Feb 20, 2007 | Sony KP-46WT500 46" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
20 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
