Campbell Hausfeld 19.2V 2 - Speed Cordless Drill with Bonus 250 - Piece Accessory Kit - DG151905CK Logo
Posted on Jan 26, 2011
JDA-22 50 Hz cordless dril charger doesnot work. the red light indicating that power is delivered does not come on. Ive opened it, but nothing seems wrond - no broke wires or dry soldeering points. where can i have it fixed in pretoria south africa
1helpful
Charger only has a red light when do I know battery is fully charged??
depending on the model of drill, the indicator (if not colour / state changing) only indicates that the drill is connected to power.
hence with no indicator of a full charge, if you refer to the user manual for this drill it should tell you how long the drill should be charged for.
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
Charging light does not go off
unppluget the base, and put contacts cleaner in the contacts charger buy it from radio shack or computer, and wait by 30 minutes.
2) try again, if work is o.k
3) if doesnot resolve the problem, the IC charger in power supply is defective repair go to the repair shop for fix it.
God bless you
Phone not charging
1) clean the contacts charger with contacts cleaner unppluged the base phone.
2) try it. if work is ok
3) if doesnot work, the IC charger in the power supply is defective, repair.
4) go the repair shop for repair.
God bless you
2answers
What does it mean if the red and green light are on at the same time on the charger
If the red and green lights are flashing, the charger is detecting the battey has a defect and is not safe to charge. It could be one of the cells in the battey, a short in the wiring or circuit board or bad contacts. Usually the only fix is to replace the battery.
2helpful
Red light indicating fone charging has not shut off for around 20 hours.
My Vtech 6.0 charging light only turns off when I remove a handset from the charger base. I have had these three set for two years and they work fine. I think that the red light is just to let you know that the charger is working, if you loose power, or unplug one of the base units there is no indication of a dead battery.
12helpful
2answers
Battery charger on a Worx Gt Trimmer Battery is blinking red what is the problem
Flashing red light indicates battery is bad. Flashing green light indicates charger is bad.
6helpful
4answers
Charger broke
common problem, go here
http://mrclm.blogspot.com/2009/09/black-decker-18v-firestorm-drill.html
6helpful
2answers
Skil cordless drill model 2362 - won't charge
I have the same problem. The guys at Batterries Plus told me that 7.2 volt battereis are not easily replaced and definately not through them. If you left it charging for to long (ie over a week when you were gone like me) then the battery is never gonna charge again. You might as well find the same model of dril at skil's reconditioned site for around $40 or buy a brand new one for $60 or $70
Top Campbell Hausfeld Drills Experts
ADMIN Andrew
ADMIN Andrew
john h
Steve Pack
Steve Pack
Are you a Campbell Hausfeld Drill Expert? Answer questions, earn points and help others
