Question about Lite On LH-20A1H (4718390010221) Burner
Can Burn CDs but not DVDs
Everytime I attempt to burn a DVD, the burn fails.
10:33:09 AM #4 ISO9660GEN -11 File geniso.cpp, Line 3899
First writeable address = 0 (0x00000000)
10:33:09 AM #5 Text 0 File Burncd.cpp, Line 3172
Turn on Disc-at-once, using DVD media
10:33:09 AM #6 Text 0 File DlgWaitCD.cpp, Line 246
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 221871 ( 49:18.21, 433MB)
10:33:09 AM #7 Text 0 File DlgWaitCD.cpp, Line 258
Write in overburning mode: NO (enabled: CD)
10:33:09 AM #8 Text 0 File DlgWaitCD.cpp, Line 2143
Recorder: LITE-ON DVDRW LH-20A1H, Media type: DVD+R
Disc Manufacturer ID: CMC MAG, Media Type ID: M01, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 7
10:33:09 AM #9 Text 0 File DlgWaitCD.cpp, Line 419
>>> Protocol of DlgWaitCD activities: <<<
10:33:09 AM #10 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 221872 (221872) = #221872/49:18.22
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 221872 blocks [LITE-ON DVDRW LH-20A1H ]
10:33:31 AM #11 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [LITE-ON DVDRW LH-20A1H ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc not fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 454393856, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
221872 | lead-out | 1 | 0x00 | 0x41
10:33:31 AM #12 Phase 24 File dlgbrnst.cpp, Line 1845
Caching of files started
10:38:53 AM #13 Text 0 File Burncd.cpp, Line 4182
Cache writing successful.
10:38:53 AM #14 Phase 25 File dlgbrnst.cpp, Line 1845
Caching of files completed
10:38:54 AM #15 Phase 36 File dlgbrnst.cpp, Line 1845
Burn process started at 16x (22,160 KB/s)
10:38:54 AM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
10:38:54 AM #17 Text 0 File Cdrdrv.cpp, Line 8128
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1
Disc Size: 120 mm, Maximum Rate: (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 7 h
Disc Manufacturer ID: CMC.MAG.
Media type ID: M01
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 07 43 4D 43 20 4D - 41 47 00 4D 30 31 00 38 ...CMC.MAG.M01.8
23 54 37 18 00 3E 6E 00 - 70 62 15 15 0B 0B 08 08 #T7..>n.pb......
01 19 1B 0B 0B 0E 0F 01 - 00 00 00 00 00 00 00 00 ................
10:38:55 AM #18 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:31,863 (31863ms) -> OK
10:38:55 AM #19 Text 0 File DVDPlusRW.cpp, Line 621
Start write address at LBA 0
DVD high compatibility mode: No
10:40:07 AM #20 SCSI -1135 File Cdrdrv.cpp, Line 1442
SCSI Exec, HA 4, TA 0, LUN 0, buffer 0x02FF0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x01 0x76 0xC0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
10:40:07 AM #21 CDR -1135 File Writer.cpp, Line 304
Write error
10:40:07 AM #22 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
10:40:08 AM #23 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
10:40:09 AM #24 Text 0 File dlgbrnst.cpp, Line 1703
Set remaining time: 0:00,000 (0ms) -> OK
10:40:09 AM #25 Text 0 File dlgbrnst.cpp, Line 1703
10:40:10 AM #26 Phase 38 File dlgbrnst.cpp, Line 1845
Burn process failed at 16x (22,160 KB/s)
Existing drivers:
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 8/3/2004 10:59:44 PM (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
    President:
  • 1,257 Answers
GET YOUR PC PROBLEM FIXED
http://www.windowsguru.org
Posted on Jul 01, 2009
Windows vista is unable to format DVD+R and with a other burner program I get the following error: 19:17:00, File(cl_DVDData.cpp), Line(193) -&gt; Begin burning process Current drive: &lt;G:...
have had this problem myself and wasted many discs you need a new burner but there is a work around to this problem
just leave the disc open so that more data can be added and no more problems
Jan 05, 2011 | LG GP08NU20 DVD±RW Burner
TDK Life on Record 1-16x speed DVD-R keeps failing when writing. I have burned about 25 dvds from this TDK pack, and all burn normally right up to near the end when my Nero burner software notifies "Burn...
You could try diferent burning software.it may even be a hardware fault the dvdr drive.cds and dvds burn and read data from inside to outer edge.as the laser moves out twards edge the speed of disc changes to compensate for larger distance travelled so a worn drive can sometimes start to show this fault.also sometimes only play half a film or stop at track 10 on cd
Apr 19, 2017 | Computers & Internet
MadDog MD-16XDVD9 could not perform end of disc-at-once
Have you tried checking your basics ?
Firmware ?
ASPI ?
Disk Defrag ?
IDE location ?
Jumper settings ?
What type of media are you using ?
What programs are you using ?
Exactly where are you and what are you doing when your error occurs.
What are your PC's specs ?
Do you have any Roxio products installed on your PC ?
Please answer ALL of the above - if you don't know, say so, don't make something
Oct 20, 2009 | Computers & Internet
My gsa-t20n will burn regular disks but will not burn DL disks all of a sudden...it burns most of the way then Nero says it cannot finalize disk. 22:48:29] NeroVision [22:48:29] NeroVision 10:36:44 PM ...
Hello there jpd0490.
Here's your geek-steer ...
There are principally two chief causes for this type (calibration) of burn failure:
  1. Inadequate quality media (disks). Verbatim is always a solid choice. However, more important than the brand-name disks are sold under, is the actual manufacturer. You can determine this with the aid of a little software tool called "DVD Identifier". There is an entire sub-culture devoted to tracking the best media available, right down to the manufacturing lot level.
  2. Drive failing. Since you say that it works consistently otherwise, this option is unlikely.
Good luck, and please do post back ...
  • to let me (and interested others) know how things worked out,
  • to provide clarification or feedback,
  • if you have ANY further questions.
"Today's the best day of my life ... and NOW you're part of it!"
Via-con-Dios and Godspeed -- Geekinator (aka Craig).
Oct 10, 2009 | LG GSA-T20N DVD±RW Dual Layer Burner
My dvdburner of laptop hp pavilion DV2726CA reads any cd dvd but
Can use usethe drive to load data or write data and how about listening to music??
Oct 06, 2009 | Acer Aspire 5100 Notebook
Sir i write a cd i get this error somu 4C85-1000-0805-6481-407K-8KE9-**** Windows XP 6.0 IA32 WinAspi: - NT-SPTI used Nero Version: 7.10.1.0 Internal Version: 7, 10, 1, 0 (Nero Express) Recorder: ...
turn off buffer underrun protect in neros settings. It gives back the wrong info to nero causing it to crash. Contact nero about the issue. there may be a patch on the nero site to fix it.
Aug 30, 2009 | Acer Aspire 4720 Notebook
Sharp Actius AL27 strange DVD burning problem - The drive will burn a DVD+RW at 4x. A cheap (Imation) DVD+R burns OK, but a good 16X DVD+R (Verbatim) tries to burn at 2x and fails a few minutes in. This...
man it's not a condition that if the DVD Bulck writeen on it 16X that ur DVD writer will burn on this speed.
always don't try to burn ur DVD on maximum, always use the previous speed or the last previous one
ok good luck
Jun 17, 2009 | Sharp Actius AL27 Notebook
Write Error
That's almost an adequate error description! It is odd that a 24x CD speed description is given for burning in a DVD-RAM; what media and session types did you pick? If there is nothing (hair, fingerprints, soap...) on the particular disk preventing a burn, perhaps something has a write lock on dlgbrnst.cpp so it can't be reeled off to DVD-RW?
May 30, 2008 | Computers & Internet
Burn error
You unit is faulty.. replace the unit with a new one. The CD Write Laser has probably "Burnt Out" or perhaps the "Quadrant Detector" has faulted.. either way a new unit is only way solve ya problem ... sry :(
Sep 03, 2007 | HP Media Center m7250n (ED842AA) PC...
Lite On LH-20A1H (4718390010221) Burner Logo
255 people viewed this question
Top Lite On Computers & Internet Experts
John Anderson
John Anderson
Rommel Balcita
Gbenga
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
