Question about Sony PlayStation Portable (PSP) Console
Update problem i went to psp updat n i went to the game memory stick n pressed update 4.05 n it will say the system configuration of this psp ystem dose not appear to be correct orthis game can not be started (DADADADA). wat is that someone plzzzzzzzzz help me
  • 3 Answers
Some one else has the same problem
http://geeksquad.fixya.com/ThreadView.aspx?prdid=201358&thid=800757
Posted on Jul 19, 2008
When my psp is updating , the power turn off and psp doesn't turn on
Try this:
Remove the PSP battery and memory stick from the device. You will use these again so keep them close.
Insert the magic memory stick into the PSP card reader. The memory stick holds the firmware that will be flashed onto the PSP.
Insert the pandora battery and the PSP will turn on automatically. Press the "X" button twice to flash the firmware to the PSP. Press "X" again to shut down the PSP.
Reinsert the normal battery and memory stick and turn the PSP back on. Plug the PSP into its charger and go through the normal update process again by selecting "System Update" on the PSP menu.
Jan 19, 2011 | Sony PlayStation Portable (PSP) Console
How do you perform a network update on the system
To configure a network access point, press Home then move to Network Update, then you get to the configuration screen that asks for the WLAN Settings (the default is to enter an SSID), choose "Scan" and let the PSP identify all the wireless networks it can see. Choose whichever one is your network.
Choose all the default configuration settings and you should promptly be asked to press the X button to save your new access profile. Do so, then select it again and, if your connection works you'll see "Checking Server...", then, if there's an update available, the PSP shows:
Network Update has found a later version.
To download, insert a Memory Stick with at least 14MB of free space and press the X button. Press the X button and you'll see "Downloading..." and a warning not to turn the unit off or remove the Memory Stick while downloading, then the download starts.
When the download succeeds, you'll now see:
Download completed.
The update is now available on your
Memory Stick.
To install now, press the x button.
To install later, go to [Game]..
Let me know if there is anything else.
Reagrds.
Aug 15, 2010 | Sony PlayStation Portable (PSP) Console
Hi i want to ask how to downgarde psp 6.20 to 5.50 without pandora battery please help me in that...thank you
Hi
You can downgrade your psp without a pandora battery but you will need a Lumines game hack,Follow these steps to do so.
Download the 5.50.pbp file. Rename the 5.50.pbp file to "UPDATE.PBP." Connect your PSP to your computer with the USB cable and select "USB Connection" to place the PSP into USB mode. A window will appear on your computer and you will be able to see the PSP memory stick files.
Download the downgrade pack. Open the "MS_ROOT" folder from the downgrade pack. Right-click the "PSP" folder and click "Copy." Go back to the PSP memory stick and right-click it. Click "Paste" and "Yes" to overwrite the data.
Right-click the UPDATE.PBP file that you downloaded in step one and click "Copy." Open the "PSP" folder on the PSP memory stick and you will see the "GAME" folder. Open this folder to reveal the "UPDATE" folder. Right-click the "UPDATE" folder and click "Paste" to transfer the update file to your PSP memory stick. The downgrade pack and 5.50 update file are on the PSP memory stick. Press the "O" button to safely disconnect the PSP from your computer.
Insert the Lumines PSP game into the PSP drive. Select the game from the PSP menu to start. Press the "Start" button when you get to the Lumines start screen. Your screen will blink red and will turn completely blue. You will be brought back to the PSP screen. It is important to not press any buttons before you get to the Lumines start screen.
Go to the game section of the PSP menu and you will now be able to see the "x.yz update" application. Select it with the "X" button to start it. Press the "X button from the main menu to start the downgrading process. Press "X" again to reboot the PSP when the downgrade has completed. You have now downgraded your PSP to 5.50 firmware.
Jul 31, 2010 | Video Game Consoles & Games
I downloaded the update but the pc cannot open the file . the updater is called eboot. i have it in my pc but cannot open it
The file is not supposed to be opened by your PC. You have the transfer the file from your PC to the PSP. To do this, you need a USB cable and you have to plug your PSP into your PC.
Download procedure
  1. Prepare to save the update data on either system storage or Memory Stick Micro™ (M2)™ media, using one of the following methods:
    • Connect the PSP® system to the PC using the USB cable
    • Connect a commercially available Memory Stick USB reader/writer to the PC
    • Use the Memory Stick slot on a PC
  2. Create a folder for the update data on either system storage or Memory Stick™ media.
    Using your PC, create a folder named "PSP". Within the "PSP" folder, create a folder named "GAME". Within the "GAME" folder, create a folder named "UPDATE". (Folder names must be in all uppercase letters).
  3. Download the update data for the PSP-N1000 (PSP®go) series and save it in the "UPDATE" folder created in step 2.
Notice
You must save the downloaded data as noted in these instructions. If you do not save in the correct location and with the filename shown below, the system will not recognize the update data.
  • Filename: Save as filename "EBOOT.PBP"
Nov 19, 2009 | Sony PlayStation Portable (PSP) Console
PSP Update -- Memory Stick could not be read.
ok if the stick is to small it wont work but what are you really trying to do! mod it well here is how you do it!!!!!!!!!!!!!!!!!
http://forums.afterdawn.com/thread_view.cfm/688507 read about five comments down!!!!!
Jun 13, 2009 | Sony PlayStation Portable (PSP) Console
I cant play games in my psp memory stick after i updated to 5.2
Please check you update. If your update is low, you must upgrade it to 3.52 m33 then download a firmware 3.70 m33 or higher to get the m33 recovery.
As your PSP start press SELECT and you can see a menu then go to "UMD ISO MODE" from "normal" change it to "Sony NP9660" then exit.
Now enjoy playing ISO or CSO game. Happy playing.
Jan 29, 2009 | Sony PlayStation Portable (PSP) Console
How to i update my psp & my psp not suported the video....give an
you can go to the nearest gaming store to update a new firmware. pls remember not to download any firmware update from the internet, this will corrupt your console. Mostly, internet firmware update are not safe.
Dec 25, 2008 | Sony PlayStation Portable (PSP) Slim...
Firmware 4.01 is not installing in my psp
I think you are trying to install a CFW update on an OFW PSP. Just rename 401.PBP to EBOOT.PBP and get rid of the other EBOOT.PBP.
Dec 24, 2008 | Sony PlayStation Portable (PSP) Console
PSP update
This may lead to the same problem, but here goes.
Try an earlier version of firmware to update to first, like 3.80, 3.90, or 4.00. You can get those here: http://www.psp-hacks.com/category/36 Download the update file, apply it to your memory card, and try installing the older version.
If you get the same problem, try dumping all of the contents of your memory card to your computer, title it "PSP Memory Stick Backup" or something along those lines so you don't lose it. After you clear the memory card, reset your PSP to the original settings under System, System Settings, Restore Default Settings. Then format your memory stick with the PSP's format option. Try any of the updates and then put everything back on your memory card.
If none of that works, I guess it would be time to call Sony.
Oct 03, 2008 | Sony PlayStation Portable (PSP) Console
Update
the system on your PSP is Hacked, you have to update to a hacked version :)
search in google for hacked PSP system sofware and follow the instructions ;)
and dont forget to mention your psp version name in search.
Regards.
Jul 18, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
179 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
