Same problem as the others, no sound no picture...did anyone get a new tv from viewsonic?
If the TV will not turn on and you do not have a "red" power indicator light you will need to replace or fix the power module. This is easy to replace, approx 125 USD, but also can be fixed. I fixed mine for about 1.97 USD with parts from Radio Shack.
[email protected]
I had the same problem , and at first they would not honor the warranty . i phoned back and mention the problem with this model and the waranty was honored , i was sent a refurbished model because my tv took longer then 21 days to fix . the main component board is the problem . good luck .
Have no sound, no pix, No standby LED, Fuse is good - suspect main signal pcb - trying to obtain
was this still within the 1 year warranty or did they honor it after a year was up because of the model?
viewsonic lcd tv will not turn on
I have the same problem did you guys repaired it?
I found this on justanswer.com
Common problem with this set are the filter capaciotrs in the power supply. Usually 2 1000uf and 2 1500uf capacitors.
