DVD will not play,message reads incorrect disc format we were watching DVD when it froze and will not permit any DVD to play now
  • wbauerly Mar 22, 2009
    Every time I try to play a dvd I get the error message: Inorrect disc format. Mine will not play music CD's either it gives the same error message.
  • 4,234 Answers
Try cleaning the optics lens using a cotton swab and alcohol. If that does not resolve the problem, than one of the following has occurred:
1) The optics assembly is not able to read the disc anymore (replace the optics).
2) The logic board has failed in some way and the information obtained from the disc is being marked as invalid. This option will take more diagnosis to completely resolve.
If option 1 appears to be the case, the unit should stillbe able to read a music CD. CDs require a lower level of laser than DVD.
Keep us posted.
Dan
Posted on Jul 18, 2008
How can I play a disc reading incorrect and error It worked fine this morning
Try some other discs first or try that on another player, usually if cannot read the disc either a dirty of bad Optical Pickup in the player.
Dec 16, 2012 | Toshiba SD-V291 DVD Player/VCR
Toshiba DVD player
Does this happen with all discs? What disc are you inserting that gives this error? DVD?
Feb 05, 2008 | Televison & Video
Playback on recorded disk
The DVD has burned incorrectly and the data has likely corrupted somewhat to the point where the DVD player/writer can't read it. You may be able to watch it on your computer with a DVD drive. Try saving it to your computer, then erasing the disc and trying to record something short to it and play it back - if it plays back, it's likely to have been a recording problem, however, if you get the same problem, it may be a dodgy disc, a faulty DVD player/writer, or a format problem. Try this, in order left to right. Copy DVD to PC -> Erase DVD -> Record on DVD from TV -> Play back If plays back Erase DVD -> Continue as normal If not Buy DVD-RW (emphasis on the minus) -> Try using that If that works continue as normal, otherwise... Return the DVD player/writer under warranty for repair/replacement.
Sep 17, 2007 | iLO DVDR04
My DVD-HR753 will not read discs. A message comes up saying 'this disc cannot be played or recorded'
Original dvd disc,not copy or not another countries datas disc?Same country as the DVD player was bought and formatted Disc?Most likely the disc u trying to play it is in a difference formatted of recording or finalizing data codes inbeted by some patent coded program.Tries play many more other DVD discs,should work find,than the original disc,u trying to play have protected datas or difference format and not same as of ur DVD player main programming firmware.
May 27, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
Disc read error on my 2005 acura TL gps
Was the door open when you got the message (easy to do)?
Did you close the door properly?
Did you replace the disc shiny side down?
Aug 26, 2009 | 1999 Acura TL
DVD Displays "Incorrect Disc"
Movies and CD's that I've played before in the Sharp now read " Incorrect Disc" . Is this fixableby me or do I have to take it in for service? Thanks.
Mar 31, 2009 | Sharp LC-20DV20U 20 in. LCD HDTV/DVD Combo
Disc Error - Playback Feature not Available on this Disc
I think I figured it out...at least mine is working now anyways and it hasn't worked in 2 years! I got the remote out, pushed setup in dvd mode and initialize and now it works
Sep 15, 2008 | Emerson EWD2004
Incorrect disc message
You might try using rubbing alcohol and a q-tip on the lens to clean it.
Apr 24, 2008 | JVC HR-XVC1U DVD Player/VCR
Sounds as if the carriage has been trashed somehow. Incorrect loading of a disc of any sort can cause this sort of message...accordianman
Mar 16, 2008 | Orion TVDVD092 9 in. TV/DVD Combo
TOSHIBA HDDVD PLAYER A20
I have a problem like this but mine will play regular dvd's
and just stop playing hd dvd's . exact same message
gene
mrjazz1959@gmail.com
Nov 03, 2007 | Toshiba HD-A20
Televison & Video Logo
208 people viewed this question
Top Televison & Video Experts
Electro Med Services...
