Tv message-ac failed -what does this mean - Televison & Video
    Sergeant:
  • 280 Answers
On RCA and others it just means that the AC power went out for a short time.
You may have to auto program the channels back in depending on how long power was out
Posted on Jul 25, 2008
What does error message ACS0307 mean
ACS is an Atheros company hardware error. This could be a wireless card in your computer that has failed. It might also be a driver that is missing or corrupt.
Jun 05, 2014 | Dell LATITUDE Computers & Internet
Have a haier plasma tv model#42hp25bat. sound but no picture. can it be repaired?
Did this occur suddenly, or was the picture gradually failing over time?
Jun 05, 2008 | Televison & Video
What does treadmill error code E1 mean?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Here's a link to more error codes:
Error Code List for Precor Fitness Equipment
May 26, 2014 | Precor Exercise & Fitness
Cyclone SX9 0 MAXPRO Treadmill
God bless you
Jun 03, 2013 | Exercise & Fitness
Pro-Plus error Panel 03
Description
Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and
EEPROM checksum during the power up test sequence. If a fault is found during the power up
test sequence, the appropriate error code will be displayed.
Possible Causes
1. These errors messages almost always indicate an upper PCA problem when they are
consistently displayed. Failures causing these error messages to be displayed are rare.
Possible Remedies
1. If the error message is consistently displayed when the unit is powered up, the upper PCA
should be replaced. It is possible to see one of these messages displayed intermittently due
the test could fail resulting in one of these messages being displayed. Treadmills operating
on non-dedicated A.C. circuits may see these messages displayed on an intermittent basis.
Remember PCA, mean Printed circuit assembly with the componentsattached.
God bless you
Jan 14, 2013 | Exercise & Fitness
When I started my DELL Inspiron 1525 running Win 7 Ultimate, I got a white-on-black screen which questioned the voltage from power adapter. Diagnostic program run.. Stopped with the following msg: Error...
2000-0142 and 2000-0146 are hard drive SMART errors, indicating the HDD will fail.
To boot message about the AC adapter was a BIOS level message that normally appears when a Auto/air ac adapter or other 65 watt ac adapter is used to power the system.
Jul 16, 2011 | Dell Inspiron 1525 Laptop
Camera initialization failed, Lenovo easy capture closed. this message comes when i open lenovo easy capture .
Welcome to Fixya
This means that the software failed to load up. Try to reinstall the easy capture software by going to the lenovo site. You can try also to disable/enable the camera by pressing the Fn key + Esc key.
Thank you for using Fixya!
Feb 20, 2011 | Lenovo 3000 G230 4107 Laptop AC Power...
Camera says graph render fail what does this mean
Ok what that means is the DirectX "Graph" or set of instructions that tells windows graphics, how to perform, what Filters to use, and how to and what to, do with the signal to be displayed. This is generally an error to do with TV cards, Display cards etc. usually again, it means that the correct CODECs aren't installed, and when the "Graph" tries to "load" them, it cannot "Find" them, and thus fails, and displays that error message.
May 12, 2010 | Computers & Internet
Toshiba Satellite A105-s101 video problems
Unmountable boot volume means most likely the hard drive has failed.
Dec 18, 2008 | Toshiba Satellite A105 Notebook
Tv will not turn on
'AC Line Failed'
That was generated when you pulled the AC plug. This is telling you that some custom settings you might have made could be lost.
The clicking you hear is a relay that repeatedly connects, then disconnects the AC to prevent fire or further damage.
If it's failing to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
Dec 05, 2008 | Zenith C27A24T 27" TV
Televison & Video Logo
Top Televison & Video Experts
