The fuse for the shower is really hot when we use the shower?
  • 828 Answers
I would have this checked by an electrician, there is a voltage drop at the point where the heat is detected. This could be caused by the fuse being loose in the socket or the screw in the bottom of the socket could be loose.
Posted on Jul 18, 2008
I have power to the shower power to the switch inside the shower but no water comes out
not familiar with powered showers please make and model bit old fashioned EH use 2 handles one on hot and one on cold
Jan 30, 2015 | Home
Our bath taps which are a mixer with shower attachment stay really hot if you put the hot on first or really cold if you put the cold on first any idea how to adjust so we can have warm water when turning...
you make no sense. From the picture the water "mixer" is the center lever or is it a diverter valve for the shower and water nozzle below???
The knobs are for hot and cold water??
Jun 08, 2014 | Plumbing
Triton jade 3 running cold
Sounds like you have an instant hot water system... (no hot water tank) if true, check that fuse.
Jan 12, 2014 | Home
Triton thermostatic shower hot water is reaching the shower but not traverling any further only cold water comes out.i've had the whole shower system off the wall and hot water flows out of pipe but when i...
Could be the pressure on the hot water flow is insufficient, you really need a 5/6 feet head of water from the shower head to the bottom of the storage tank for sufficient pressure.
Nov 06, 2017 | Home
Turn on shower, only a little bit of heat but only when you really turn up temp gage. there's no power light on as well.
make sure the rest of the house is getting good hot water to rule out a problem with your hotwater heater, if all other is ok then your shower valve may be clogged with trash on the hot side restricting flow and hot water. If its an ant scald shower valve you may need to raise the temp control.
Oct 26, 2010 | Home
Shower keeps getting really hot then really cold
is it posibel that oder ppl in the house is opening taps while u are showering? and may well also be a dirty reducer velves varteage located on cold water feed to geyser. let me know if thats not the problem, thanx
Jun 17, 2010 | Home
No hot water
Check your fuse/breaker, should be a rcd switch. Depending when the shower was installed the fuse/breaker may be separate from the main fuse board, if it is an rcd switch it should be between 30A and 40A rating. If it is still fuse wire or cartridge fuse it should be replaced by residual current device.
Remember to turn the shower off in the bathroom before returning power to it.
Hope this helps
Apr 10, 2010 | Home
Electric shower is not getting hot
Locate your electrical panel box, find the breaker for the water heater, turn it off then back on, locate the water heater. Fins the powere disconect. Sometimes they are a simple pull disconect or switch, sometimes they are another breaker or fuse.
Check the fuses or flip the breaker if aplicable.
Do you have a volt/ohm meter?
Dec 06, 2008 | Home
My shower mixing valve will not adjust. The water is hot no matter what position I put it in. Makes for some really hot showers.
Are you using the wall instant hot shower heater? You should be careful, sometimes if all of sudden you only got hot water, you will get burned.
Call the supply companyright away.
Jul 07, 2008 | Heating & Cooling
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
