Question about Mitsubishi WS-65809 65" Rear Projection Television
Horizontal Output Transistor
Is this an expensive fix??? Or can it be a do it yourself jobs???
    Master:
  • 505 Answers
I do not recommend that you do it your seft
Posted on Jul 31, 2008
I have audio but no picture except a horizontal light across the middle of screen. Sylvania 32" tube type TV. Model SST4324
Sounds like your Output Transistor has blown. I would suggest you take to your nearest TV repair person. Will most likely cost between £30 to £50...
!.This is not a job you should carry out yourself. As you are dealing with High voltage, even when TV is turned off.!
Hope this helps
Apr 08, 2011 | Sylvania Televison & Video
H out transistor defetive & number missing plz solve
Hello
The horizontal output transistor number for Sony KV-ES34M61
Horizontal output - [Q6807] == 2SC5480-01
Pin output - [Q6808] == 2SC5480-01 Again
Please replace bothe the transistor at the same time. Check horizontal output transformer [LOT of HOT], for any defects.. Ok
Jan 06, 2011 | Sony KV-ES34M61 34" TV
Sound, no picture, Red LED 4 flashes
Hello Thanshar, Hi, you TV has sound, but no picture. this could be several things, and let us add the red led flash. In my analysis, no picture means no high voltage is reaching the picture tube. this could be due to a bad Horizontal output transistor, and/or a bad flyback transformer. This bad transistor is causing an overload to the power supply section, causing the 4 led flash to blink. Now i want to know if you want to do this service or get professional help. if you decide to do this by yourself, this needs to be performed: the Horizontal output transistor must be checked for short, the horizontal flyback transformer needs to be tested, the deflection yoke also needs to be checked, especially to horizontal coil.
Oct 09, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Pop sound frome tv could it be a fuse? now it dont come on.
The pop may be the Horizontal output transistor, shorted. And that is usually because you have or had an extremely dry or bad capacitor! It may be an expensive fix. Thanks for asking!
Jun 12, 2010 | Philips Magnavox TS3260C 32" TV
Kv-9pt50 no picture hv and sound ok
its either you have a problem in the horizontal output,most probably flyback transformer or horizontal output transistor or ther is a defective component in hori. section.do not do it yourself.lehtal voltages present.contact qualified technician.
Nov 11, 2009 | Sony KV-9PT50 Television
No picture
I disagree with given info, this tv has no horizontal output transistor because it is dlp tv.
3 red light blink means lamp cover is not placed back properly after lamp replacement/ lamp checking. Make sure lamp cover is fixed back in its place securely and tight.
Jul 16, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
TV is beeping from the back.
The horizontal output transistor is shorted and probably the flyback transformer is bad as well. Expensive to fix.
Mar 28, 2009 | RCA P52926 52" Rear Projection Television
Replaced Flyback Transformer and Horizontal Output Transistor
how miuch was the repair can you do it yourself
Aug 13, 2008 | RCA F36650 36" TV
no not expensive at all from repair man but if you attempt it yourself you could damage serton components
Jul 20, 2008 | Mitsubishi WS-65809 65" Rear Projection...
JVCAV-N2043TV,Horiontal Output Transistor burns out everytime if fix a new one
Hi There,
The Hor Output transistor is connected to the Line Output Transformer. This transfromer provides a lot of voltages around your TV set but includes the very high voltage to the Picture tube...
These transformers are specially tuned to resonate at a certain frequency,
The Hor output transistor needs to match this frequency....so if the wiring inside the transformer is shorted by "just a bit" the picture will be visible but the transistor is struggling to match the transformer impedance,from the mismatched tuning...so the transistor draws more current from the power supply.. runs hot then burns out...
Usually manufacturers provide a Trip circuit that detects that an overload on the power supply is occuring and cuts the power to the Line output stage ...this is usually detected by a clicking sound within the power supply its called hiccuping.
If some one has altered the correct setting on the power trip circuit then the next thing that happens is the Transistor goes Blooooey like in your case.....
So to save you a lot of money replacing the output transistor
please replace the output transfromer as well next time...
But please... please... re-check the power supply trip circuit to save you a lot more expense in the future....
Best Regards From YUBEUT
Oct 10, 2007 | JVC AV-27230 27" TV
Mitsubishi WS-65809 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
