Question about Lanier Office Equipment & Supplies
Lanier Printer LP131n
When sending a Word document to print to tray 1, printer beeps and displays message "8 1/2 x 11 Change Setting Tray 1". Only way to work around is to send to bypass tray. Could it be a faulty sensor on the tray itself?
  • dalyte Jul 29, 2008
    Thanks for the help. It works for now and you gave me several options for later.
    Guru:
  • 1,049 Answers
Don't be mad, but it never hurts to ask if you've checked the following...
  • Made sure that the printer has not been set to use legal or A4 paper in tray 1. You can set this through the options listed in the menu map on the printer display.
  • Have you checked that the Word document is not setup in the "normal.dot" or in the document itself to use A4 or legal as the default paper type.
  • Is the small paper resize lever in tray 1 pushed flush against the 8.5x11 paper in the feeder so that it detects properly.
Less obvious...
  • Did you make sure that the print properties are not setup with the wrong tray configuration...i.e. listing a duplexer when one is not present, additional trays, or a feeder?
If the answer is that you have done all of this and the issue has not been resolved, I would try looking for obstruction above the primary feeder tray, in the gear assemblies in and around the bottom of the printer and the tray, or around the paper sensor. (a small plastic lever in the front of the tray.
Posted on Jul 25, 2008
I have a Lexmark T630 printer and every time I go to print it beeps and says change tray 1. How to I get it to not beep while printing?
You will need to change your paper handling.
From the machine, go into the Menu-> then Paper Menu -> Change your paper size and type to your machine settings. Example if tray 1 is letter make sure it's set to letter and plain, then confirm each tray setting for each tray attached to the machine.
Also pull the tray(s) out completely and make sure the guides are set correctly. (The guides move so you can put legal, A4 etc.)
I've come across a lot of machines that the guides are off by a fraction which will prompt your machine to display the message you stated.
Nov 16, 2010 | Lexmark T630 Laser Printer
Tray 1 is not set correctly, yet everything is set right. Help
81/2 x 11 is not a custom paper size. Set tray 1 to 81/2 x11 plain paper and set your print driver the same way. the descriptions have to match or it will not print.
Jan 05, 2010 | Lanier UNKNOWN
PRINTING FROM WRONG TRAY
Go to your Control Panel - Printers - [Select the LJ 2300 printer] - Properties setting on the PC and reset the default print tray to number 2
Sep 22, 2009 | HP LaserJet 2300 Printer
Brother MFC-9840CDW says no paper when trying to print. there is paper, it will make copies and test page, but beeps and flashes no paper when printing. Says "reload paper in MP tray", I've taken out all...
I had this problem trying to print from MS Word in a template I downloaded. I found this link and it worked perfectly. I'm using Word 2010 so I had to adjust accordingly. It's for a slightly earlier Brother model but that did not affect my using it.
Jul 15, 2009 | Brother MFC-9840CDW Laser Printer
Prints from Manual Tray instead of Tray 4
Open a document. Select File>Page Setup and change the Source to Tray 4.
Or...
Try to print something. When the Print window comes up, select Preferences. On the Print/Quality tab look for the drop down menu labeled "Source is:" and change it to the tray you want. Click on the Save button.
Here is more info from HP:
HP M9050 Tray Configure
Apr 16, 2009 | HP LaserJet M9050 MFP Printer
Printer only sends paper to tray 1 when printing from procomm...
Sounds like a Procomm issue. Since I am not familiar with Procomm I can help you any further. But here is my analysis: All other application except for Procomm prints to tray 2. That is because all those applications use the setting as configured in your printer properties in Windows. What Procomm seems to be doing is trying to load a special paper from the manual feed tray, that is tray 1. You will have to check with in this Procomm application where you can change the printer properties so you can specify it to use tray 2 as the default. This is all within Procomm and has nothing to do with Windows nor your printer.
Apr 09, 2009 | HP LaserJet P3005n Printer
Paper size won't print
First customize the paper size in the Page Setup. Secondly when you send command for print, change the paper size to custom size from the Printer Properties and click print. On the other hand, you can select the paper size from the printer's menu itself after sending the print command. Please make sure that the right driver of the printer is installed on your computer.
Hope it will help and fix your problem.
May 22, 2017 | HP Photosmart 3210 Printer
Printer Trays
I have the same problem. Tray 2 shows "!" and doesn not print. PLEASE HELP!
Jul 02, 2008 | Lexmark T632 Laser Printer
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
Paper tray selection
Go to Paper Menu > Paper Size > Tray 1 - note what the Auto setting states (Letter, A4, Legal, etc.) Pull the tray out to set what it is configured for. Then reinsert it & pull it out a few times, noting what the display show the Auto size show. It should match the tray's settings.
If the Display indicates otherwise, it means one of two things:
1) The "auto size sensing" board on the left may be defective. The left side of the tray has a matrix of 3 plastic tabs that stick out in certain order depending on the tray setting. If this board fails, it may show Executive or A4 when the tray is set for letter.
2) The tray may be in-between two settings. Try to readjust the tray length setting between sizes. (You will notice the plastic tabs will change order.) The last time you loaded paper it may have pushed it just enough so that it is no longer seen as letter by the auto sensing board.
I hope this helps...
Nov 28, 2007 | Lexmark Optra T610 Laser Printer
285 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Adorjani Laszlo
Anthony Karuku
George Mclaughlin
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
