A message keep popping up saying the server xml is not working
  • 43 Answers
Go to www.java.com and install the latest ver. but before that goto add remove programs and uninstall the previous java versons!!!provide more details might help
Posted on Jul 27, 2008
Ya u have to chake your network setting properly chake all setting and complete that all if till problem continuslly than u have to re-install your operating system or server.OK have a nice day.
I am getting a message that says full IMAP support is not enabled for this account on a new godly email account I am setting up w secure server
Sounds like email incoming server setting problem. There are two type of Email server IMAP and POP . Maybe it needs to be set as POP for incoming email server setting rather than IMAP.
IMAP stores email messages on the email server where as POP only stores them until you download them to the email client program you are using on your device. You may have to check with email provider if it is using an IMAP server or if it is a POP server.
Aug 11, 2015 | Cell Phones
Failed to load application configuration data from "core.hp.main/application.xml" what does this mean
It is to do with servers. See; http://docs.oracle.com/cd/E13222_01/wls/docs61/programming/app_xml.html
Try booting in safe mode and restore your system to a known good date. When successful, you will be able to find out mre about why you have this error. It is probably a registry error.
Dec 07, 2013 | Computers & Internet
Computer pop up
IE: stack overflow at line: 0 Today, I noticed the following issue (IE only, of course). Running a page that does some comet (via “XHR GET” for long-polling), I got the following warning: “stack overflow at line: 0′ and the application stopped working…
I did some google-searches and found some “hints” that said I should disable my third-party tools for IE etc. That sounds strange…
In fact the problem was the odd cache behavior of the IE. The XML (from the “long-polling servlet”) was cached and its JS was executed; also the application itself started the polling too, so I (no IE) ran into this odd issue…
Changing the server-side code – that is responsible to render the XML – to have no cache rules (e.g.”Cache-Control”:”no-cache”) did the trick. It worked again. Of course, on your “comet output” you potentially don’t want cache to be present…
So fixing the cache solved the issue. There was no need to disable Norton or any other third-party tool… icon_smile.gif
Mar 28, 2010 | Microsoft Windows XP Home Edition
There was a problem signing into yahoo...please try again later..it keeps saying this.what can i do please
Check your Internet connection properly that it's working...if internet connection is not getting any data from yahoo then this type of messege pop ups....or if you are banned from yahoo server it will say same....Good Luck
Oct 27, 2009 | Yahoo Messenger
When I try to send a picture I scaned to an email it keeps saying something about a pop 3 server not found
Do you use outlook express or outlook for your email or a server based email. If you use a server based email the scanner software is opening the program that resided on your pc which is not set up for emailing. That is why it says the pop 3 server is not found. You will need to attach the picture file to your email from within your hotmail or google or what ever web based email you use. Then send it.
Aug 02, 2009 | Lexmark X2600 InkJet Printer
Code 721 keep coming up and the machine keeps beeping. How do we fix it?
Error 721: Cannot connect to the Pop Server. (Incorrect POP Server IP Address) Pop Server is down.
Solution: Check the Pop Server IP Address. Contact the Network Administrator
Were you setting up email by chance, you need to make sure the email server settings are set correctly for your POP email provider. Otherwise you will get this message. If you don't use email, go into settings (Fax Parameters) and disable email features.
Apr 27, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
My Acer Aspire 5100 will not stop shuting down and restarting. It is trying to configure 3 of 3 updates. I tried the going through the F8 button and going through the last configuration section. That did...
Hi sboon4...did I lose you on chat? I have a couple more things to try....
hello?
inthecellar says:
I'm not sure if you're still connected but I have a couple more things to try here...so I'll type it out.
inthecellar says:
If you can get back to a command prompt again, you can try the following:
inthecellar says:
C:\windows\winsxs\pending.xml C:\windows\winsxs\pending.old.xml
C:\windows\winsxs\cleanup.xml -> C:\windows\winsxs\cleanup.old.xml
inthecellar says:
You want to rename the pending.xml to old and cleanup.xml to old.
inthecellar says:
if that doesn't work then try going into the bios of the Acer to choose recovery (which may erase all data) by hitting Alt-F10 while it boots up.
inthecellar says:
my email is doingitright@blueskyit.ca if you need more assistance...I'll keep it connected.
Apr 25, 2009 | Acer Aspire 5100 Notebook
Can't load my email messages in yahoo mail anymore since they introduced the new email format on Oct. 1st
You should call this number, these folks will resolve your issue:
Customer Care
http://help.yahoo.com/
1-866-562-7219
anaanymous
Oct 05, 2008 | Computers & Internet
XMLHttp/00413E6C
this must be a troja or a virus and the mesage that pops up bears no relevance as XML is a exel type file along with a HTTP address number.
Click start>run, then type msconfig and in the next window, look at the startup tab and look in the list for anything that relates to XML and untick it.
Click apply and then reboot the pc and then click don't show again when a windows pops up and says that you have changed system settings.
The notification should not now pop up.
Oct 14, 2007 | Belkin (F6D3230-4) Router (F6D32304)
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
