Question about Carrier Heating & Cooling
Error code c2/c3 on carrier kd07 split ducted system
  • 1,420 Answers
Need a better model number to be able to help you out. Somethong like 40QK_ _ _
Posted on Jul 21, 2008
WHAT IS FAULT CODE 00 01 Ad on Teco LU160DHRA1 Air Con
Carrier Split Air Conditioner Error Codes - AC Error Code
acerrorcode.com/carrier-split-air-conditioner-error-codes.html
Jan 25, 2015 - REMOTE CONTROLLER FOR AIR CONDITIONER (SPLIT TYPE). Carrier Split Air Conditioner Error Codes. 00-01-02-03. 11-12-04-05.
Nov 25, 2015 | Heating & Cooling
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
42KEL-024LX
have you tried to call carrier to see if there is a universal remote that may be programed to your mini split system?
Oct 22, 2013 | Carrier High-wall Duct Free Split System...
What is e4 code of duct split carrier a/c ?
Need model. Number or name. E4 is several different codes for carrier. Likely a temp sensor from what I'm seeing.
Jul 13, 2011 | Carrier 38CKC042 Air Conditioner
Aeg sensorlogic 50700 first showed c2 message; we drained & cleaned filters 3 times; worked half cycle and now showing error message c3?
Error message C3 is most likely indicating the flood switch is triggered. This means water is leaking from under the sump. The C2 error is linked to drain problems which you cleared.
Dec 29, 2010 | AEG Dishwashers
ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Mar 10, 2010 | Carrier Heating & Cooling
Carrier Air Conditioning error code 5
Carrier A/C split Model # 38KCL112313GP has error code E1 What is that?
Aug 09, 2009 | Carrier Heating & Cooling
Carrier A/C system (P250H) smells like urine
Since the smell could only come from the inside, and you say your drain pan, and condensate line are clear, I would think that the indoor coil may be dirty, and the water isn't flowing from the coil, but dripping into the duct, and becoming stagnate. There are many possiblities, you may want to get a flashlight and check all of your duct openings for things such as moisture, and unfortunately dead animals. Sometimes mice, squirrels, rats, bats, etc. find ways into the duct, and either die, or urinate in the duct and so on. I hope you find it. Good luck.
Feb 22, 2009 | Carrier 36KCARMS Air Conditioner
Heating & Cooling Logo
164 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
