Question about GE WSXH208A Front Load Washer
Door in lock will not open
The clothes are not spun out and the door is in lock and I cannot get anything else to work.....
More than likely you have a bad door switch assy. This nifty little gizmo has the locking mechinism AND the door switch in one unit. Last one I changed had two connections on it I believe. If the dryer is mounted on top you can access it by removing the tub boot seal. Major PIA to get it back on just right. Easier if you can get access from the top. If your nimble enough you can check continuity w/o removing the switch.
Posted on Jul 22, 2008
How to open the door of my AW 1000w door is jammed
Is this the first time? If so its the door switch / solenoid. If its every time then its likely the processor board is faulty. Find a local appliance tech. If the top lid comes off at a couple of screws along the rear edge, disconnect the power and see if you can reach inside and trip the lock. This will release the clothes. Then you need to work out the fault.
Sep 27, 2016 | Washing Machines
Superwash button constant flashing
I do not have a solution but also have the same issue. That is when putting on a cotton programme, the superwash light comes on at the end of the programme and I am unable to open the door as it remains locked. I then have to put it to a rinse or spin cycle as it does not seem to have spun the clothes at all.
Jul 15, 2010 | Hoover H140E Front Load Washer
Completed cycle, door locked tho, help
you need to drain the water and the door should release ,check filter
Jan 12, 2010 | Washing Machines
The door is locked on my front loader washer.
PUSH THE START PAUSE BUTTON, AND CLEAN THE LINT TRAP AT THE BOTTOM OF THE UNIT
ROB
Apr 14, 2009 | GE WPXH214A Front Load Washer
I have a Splendide 2000 s vented washer and dryer. I started a load and there was water leaking all over my floor from the washer, so I immediately turned it off. Now I'm trying to get those clothes out...
Unplug it. Door latch has thermal delay. Unplug, let cool 3 minutes, open door.
After door is open, you can kill the delay: with door open remove rubber boot to access gap between door & drum, remove door catch from cabinet, glue, break or unwire delay parts & replace all. Do this with safety glasses, the spring holding rubber boot can be a bit jumpy.
Your leak I know nothing of.
Jan 26, 2009 | Splendide 2100 Vented Washer-Dryer
Door of washing machine will not open.
Some times, you have to really pull hard to open the door
If no joy, then you have a faulty door lock.
To replace. remove door seal at front, thius will give you access to the door lock.
Nov 18, 2008 | Hotpoint First Edition FEW12 Front Load...
My son has been given a HOOVER PERFORMA 1200 AC120 (used) he put his washing in it for first time it never drained or spun and now his clothes are stuck in machine full of water! the button you press to...
the washing machine must be empty for the door to open.
either open the trap at the bottom of your machine..prepare for flood!! or drop the grey drain hose to the floor and machine should empty.
glasgow domestics.
Feb 29, 2008 | Washing Machines
Drying cycle ma;function
The problem lies with the water valve at the water entrance area; trace the pipe from where the water comes to dispenser. This should be done after opening up the top ( careful not to touch any part which could give you electric shock or anything) The pipe where the water gushes should be traced back to the inlet area, you will have to change this valve. To see the gush gently open the dispenser drawer.
Nov 27, 2007 | Malber WD1000 Front Load Washer/Dryer
Bosch Nexxt Essence Washer
start a cycle, once the door lock light comes on pull on the door to see if its really locked if not, you need a new door lock assembly
Nov 12, 2007 | Bosch WFMC2100UC Nexxt Essence Washer
GE WSXH208A Front Load Washer Logo
54 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
