Question about IBM Wheelwriter 30 Typewriter
IBM Personal Wheelwriter typewriter
Sometimes when you turn on the computer the 3 green lights at the right bottom flash with the 1st and 3rd lights only and when you try to type or advance paper it just beeps. Turning it off and on alot of times sometimes makes it work. Eventurally it will work. What could cause this? Thank you for your help..
  • brendafay Aug 21, 2008
    it wont do anything two greens lights on 1 and 2 on bottom right help
  • Anonymous Aug 25, 2008
    the first and third light at the bottom just keep flashing and you can not do anything else.
  • IBM Master
  • 3,594 Answers
This could be a bad keyboard see my tip under WW1000
DickyO
Posted on Jul 29, 2008
    Sergeant:
  • 329 Answers
Check chrome carriage rail, make sure is clean with a slight amount of oil such as 3 n1. move printer back and forth, does it move smoothly. Also could be a bad on and off switch they do go bad I stock them just for this reason. Some times to get to work drip a small and I mean small amount of WD40 down the orange or red switch to allow it to get into switch contacs.
Posted on Jul 21, 2008
How to solve a problem with an IBM Wheelwriter 10 Series ll Model 6783
It is most likely a bad keyboard. You can try my fix under WW1000 or contact Geo. Beyers Co. for a rebuild.
DickyO
Feb 28, 2013 | Swintec Ibm Wheelwriter 10 Series Ii...
I have a IBM Personal Wheelwriter 2 that when shut off, it lights up, but then shuts off. Sometimes it stays lit up, so we try not shutting off, but it's a problem.
I have never replaced an off on switch on a personal WW but it sure sounds like it is bad. You can buy one for 15.00 from us.
Dickyo
216-241-0027
Jan 05, 2011 | IBM Wheelwriter 6 Typewriter
IBM Personal Wheelwriter 2 - Machine comes on and is stuck with flashing lights on the left . . .
If the 1 &2 lights are flashing check the keyboard conectors and see my tip under WW1000.
DickyO
Dec 11, 2008 | IBM Wheelwriter 30 Typewriter
Check to be sure the keyboard is fully pluged in, if it is try pushing them while powering on, if that helps see my keyboard tip under WW1000.
DickyO
Jul 16, 2008 | IBM Wheelwriter 30 Typewriter
IBM personal wheelwriter 2 memory
I have a IBM Personal Wheelwriter 2 by Lexmark and when you turn it on it beeps and then the single and double space lines light up and stay on but the it will do nothing else. (It's like it is locked up
Mar 25, 2008 | IBM Wheelwriter 30 Typewriter
IBM wheelwriter 6 Series II
try turning the machine off put a SMALL amount of oil on the large round rod running across the typewriter manually push the print head left and right a few times to see if it will loosen up. The problem is usually caused be drying oil you may consider having it serviced by a pro.
Oct 31, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
IBM Wheelwriter 30 Typewriter Logo
124 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
