Cannot get on the internet with my hp laptop. even tho it says I am connected and the signal is fine. we were at a hotel and it was working fine then the battery went dead so we pluged into elctrical and after that we could not get on the internet at all. not even at home
  • 5 more comments
  • joycemann Jul 18, 2008
    that did not work.
    I cannot acess the internet even tho it says
    the signal is good and I am connected.
    I have tried disconnecting internet explorer and reconecting . that did not help.
    windows xp
    it is a hp laptop dv 8000 running windows xp home edition.
    its a pavillion
    I don't know about the settings or what they
    should be. so telling me to change the settings is no help. I need to know what to do.
    no nothing occured. and if the wireless card went out, why would it say it
    was picking up the signal and the signal is strong.?
    its a hp pavillion dv 8000 laptop
    Novelist:
    Scholar:
  • 160 Answers
Try this simple solution first. We'll reset the network card IP addresses...
1) As Ekse said, Press Start, Run, type in CMD and press ok.
2) Now type ipconfig /release & press enter
3) When that responds, type ipconfig /renew & press enter
4) If all is well, you should now have addresses assigned to your cards.
Press exit.
Hope that helps!
Posted on Jul 18, 2008
  • 1,183 Answers
Connect the router, to the laptop using the network cable. If you donnot have a spare network cable , bypass the router and connect to the cable.
If the system goes to the internet , this would confirm the machine is ok and the internet is working fine.
If that is true: Then the wireless profile is corrupt and you need to make a new wirless profile.
Check the following link
http://www.hp.com/sbso/wireless/tools-troubleshoot.html
Thanks
Proton
    Sergeant:
    Champion:
  • 248 Answers
Use different browsers, try firefox, if two browsers (IE and firefox) do not work then check your connection, disable and enable your local or wireless connection to refresh it. try connecting again. If it still will not connect, restart Wireless Zero in your services. To do this go to control panel, admin tools, services, a new window will appear with a list of services, highlight Wireless Zero and restart it (there's a link) ...try once again. Dont forget to try to power down your wireless router....
  • 13,433 Answers
The wireless settings are wrong or the wireless radio is not enabled.
brand and model of your laptop?
  • Ekse Jul 18, 2008
    these kind of problems are best solved by actually coming over to the house and fixing the problem, its hard for me to start giving you instructions on what to check and what todo.
    well try refreshing your connection.. heres how
    press start -> run -> type in the box CMD
    in the black window that just opened on the laptop, type in ipconfig
    can you post me everything you see there?
    Heres a example what would show up
    C:\Documents and Settings\Administrator>ipconfig
    Windows IP Configuration
    Ethernet adapter Integ:
    Connection-specific DNS Suffix . : ********.fi
    IP Address. . . . . . . . . . . . : 91.******.241
    Subnet Mask . . . . . . . . . . . : 255.*******.0
    Default Gateway . . . . . . . . . : 91.*******.1
  • 197 Answers
Did something acure between the time you pluged it and charged the battery like a power surge . because it sounds like your internal wireless card went out.
    Brigadier General:
  • 3,614 Answers
May i know the Laptop model you have, and the current OS installed to it...
Thanks..
    Sergeant:
    Champion:
  • 230 Answers
Uninstall the browser and then reinstall it and try ,because virus might have corrupted your browser.And also scan the lap top whether there is any virus or not
  • 19,396 Answers
Are you connecting by wireless?
  • Ginko
    Ginko Jul 18, 2008
    Accessing to the free network in the hotel may have messed up wireless network setting on your laptop. Probably the laptop loaded automatically settings for the hotel network , and now does not connect to your usual home network.
    I doubt removing the battery may have anything to do with this.
    If you are connecting by wireless check that you have the right encryption key set up, and that you are connecting to the right network, not automatically to some neighbor's unprotected network.
    If you are using an external wireless adapter remove it and put it back, eventually also reinstall the drivers.
    Disable the firewall or test firewall settings.
    One of the procedures above should sort out the problem.
  • Ginko
    Ginko Jul 18, 2008
    Before doing the rest try turning off computer , removing network adapter (if it is not internal) then restart and check.
    Even if there is signal the network may not be working properly. Probably there is limited or no connectivity.
    First ensure that is not related to firewall, and disable it , check your internet security etc.
    Then ensure you are on the right network with the right password, and on the right network. Go to 'display available wireless networks', clicking either on network card software or on the small wireless icon near to the clock. Disconnect and connect to the right network, ensure you have your network key.
    After this, the simplest thing you can do is going into control panel/installed devices, removing wireless network adapter from device list and installing it again. This will fix many troubles with TCP IP and other internet settings.
    Go to control panel and click on system properties
    Display the hardware device list using the tab in system property window
    Remove wireless adapter from displayed devices.
    Click apply or ok in device list window
    Restart computer.
    At restart the wireless adapter will reinstall by itself.
    After installing you will be asked to select network and provide network key again.
What do I need to use the internet when I visit france on holiday/with my laptop.
Many hotels in Europe offer free WiFi connections and the hotels will provide you with the necessary sign-on information when you check in.
Your computer should automatically find the connection then all you have to do is sign on with the information the hotel provided.
In addition, many hotels also have business centers where free computers are available which provide instant access to the internet. In those cases I recommend using the hotel computer to protect information that you have on your laptop.
Hacking is a major problem in Europe and often hackers will have locked onto your computer within seconds after you have logged in...especially on public WiFi networks.
This can and does happen even on "secure" sites. You need to be aware of this and avoid accessing any websites where you have confidential information.
Once you return from France, I would suggest running an immediate full system anti-virus scan and I would change all of the passwords in all of the accounts I accessed while I was away.
May 14, 2014 | Measuring Tools & Sensors
I have an acer extensa 5620z and netgear dg834v5 modem/router. I can connect via ethernet, but even though i have set the router without security, the laptop detects the wireless network, but won't...
This is worked for me on Vista:
1. Goto Network and Sharing Center.
2. Click on your Wireless Connection "View Status".
3. Click on Propertes.
4. Uncheck the option that says "Internet Protocol Version 6"
When I did this, my wireless began working again.
Jun 11, 2011 | Acer Extensa 5620 Notebook PC
Play online ps3 in hotel free wireless Internet n won't connect
I'm staying in a hotel and have free wi-fi and wired internet but I can not seem to get online. During the connection test the "obtain IP address" step is successful, however the next step "internet connection" fails. This is an unsecured network and does not require any wpa keys , and I don't think it requires an SSID. I had no trouble connecting my laptop.
http://www.newyork-hotels.us
May 01, 2010 | Dmm Call of Duty: World at War
Internet signal is fine, works on main computer but not on laptop
download the driver here
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?os=19&softwareitem=dj-28354-1&lc=en&dlc=en&cc=us&lang=en&product=57565
Apr 03, 2010 | Linksys Wireless-G WRT54G Router
I have an HP Laptop LAN connection will not connect to internet
The wireless modem you are connecting to is protected with a WEP key. You have to get the WEP key or find another wifi hotspot that is not protected.
You can also get a better antenna for your laptop to see if you can pull in another site.
Jul 30, 2009 | Dell Inspiron 1501 Notebook
Connects to network, strong signal, will not connect to internet.
it looks like wireless card in the laptops need to be changed.
Jun 03, 2009 | Acer Aspire 5610-4648 Notebook
My Hp Laptop is unable to be connected to the internet
sound like u might need to find the drivers for the cable modem even tho it worked on another pc i would try this first
Mar 24, 2009 | HP Pavilion dv6000z Notebook
Can't connect to hotel internet
try hard coding the IP address given by the Hotel people for the while you are in here !
Mar 19, 2009 | Dell Inspiron 1200 Notebook
X Box 360 can't connect in hotel room!
I figured it out! I am also in a hotel room with only ethernet...and can connect to the network but not to the internet. When I got onto the internet for the first time on my laptop, there was a hotel internet webpage that came up immediately. You have to click CONNECT for 24hrs; 48; 1 week etc. unfortunately for us, Xbox doesn't have a internet browser like the PS3 does. So we can not click CONNECT when we are attempting to connect on the 360. The only reason why I know this is correct is because my friend brought his PS3 to my hotel room and that hotel connect window popped up and immediately we were playing Modern Warfare 2 with "full bars"...Xbox should really add a download for a browser! Like 360 way more. Sorry guys!
Jan 28, 2009 | Microsoft Xbox 360 Console
Problems with Internet connections abroad via hotel provided username and password
do one thing go to the control panel open internet option then go to connection, delete all the existing connection if there are, then click on add select the wifi and follow the instructions that comes
Nov 10, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
