SOURCE: Battery Charging light doesn't flash and battery doesn't charge
I have the same problem. Worked for 3 years and now the battery charges to green but goes dead immediately. I've changed batteries. Its the camera not the batteries. Works fine plugged in. Obviously the cameras are not charging the batteries. Canon must know but I cannot find a fix and warranty is over. I guess buying the expensive camera of the day isnt always assuring you of quality.
SOURCE: Wont Turn on at all - Casio Ex-z750
Contact the person @ www.digitalcamrepair.com he can repair it for you.
SOURCE: Fuji Fine Pix Z5 battery won't charge
I looked up this question with the same problem and while the battery was placed in with the right side in, the three metal tabs weren't on the right side with the three metal chargers- so I had to spin it around the other way...i hope i'm explaining this right...now it's charging! I am so glad. This camera is excellent.
SOURCE: lithium ion battery won't charge
known issue, battery needs to be 'shocked" back to life. Here's the fix:
"Hi,I just found a soultion on another website and it appears to have worked for me.Apparently the battery loses it memory when fully discharged,to fix this take a 9v battery and place the terminals + to + and - to - with the camera battery for 30 seconds or so then put the battery back in the camera and charge as normal.I just did this and it seems to be charging and the red light is solid.hope this helps."
SOURCE: Battery charger light flash
Its pretty simple to fix. The lithium battery has just depolarized. Just buy a 9V battery.... put them end to end... the 9V and the lithium and touch the metal parts of them. hold for 20 seconds... if it doesn't work, lick the 9V to conduct the electricity better.. hold for 20 seconds and put directly on the charger... I just did this, and it is charging as we speak! good luck!
