Question about HP Pavilion zd8000 Notebook
Reinstalling a key cover
One of the key-tops (the '2') on the numeric keypad has come off. I can't spot anything that is broken, but haven't been able to find a procedure that puts it back on to stay. I've tried installing the white under-clips then pressing the cover in place-- no go. I've tried leaving the under-clips attached to the key cover and then manipulating the key top assembly into place-- no go.
Does anyone know the proper tweak?
Thanks, - Bill
    Genius:
  • 2,028 Answers
I know these can be a bit frustrating, but you're just going to have to keep working with it untill it snaps in properly. Unfortunately there is no diagram for these, if you're unsure that you have it together right, I suggest taking another key off to see exactly how it goes together.
Posted on Jul 18, 2008
Numeric keypad
1.Hold Fn (bottom left corner key on your keyboard beside "Ctrl") and press F11 key once (or find symbol that looks like "lock with number 1 inside" )
OR
2. Find key on your keyboard called "NumLock" and press once.
Mar 17, 2014 | Dell Inspiron Computers & Internet
How to reset brother printer mfc 8460n the printer says drum near end...so i decided to replace a new one,but the problem is, it still flashing the same problem...what should i do? i do not know how to...
1. Make sure that the machine is turned on.
2. Open the front cover.
3. Press Clear or Clear/Back on the control panel.?
4. If your Brother machine has a numeric keypad: Press 1 to reset the drum counter.
If your Brother machine doesn't have a numeric keypad: Press the Up Arrow Key to reset the drum counter.
5. When the LCD shows Accepted, close the front cover.
Feb 06, 2018 | Brother Office Equipment & Supplies
Secret keypad letters in computer
hi
Click on a text box or open a text document.
  • 2 Press the "Num Lock" key to activate your keyboard's numeric keypad.
  • 3 Press and hold the "Alt" key.
  • 4 Enter the numeric code on the number pad. Press "1" to create a "smiley face." Display a musical note by pressing "14". To make a heart symbol, press "3".
  • 5 Release the "Alt" key after entering each numeric code. The symbol will appear.
  • Jan 15, 2011 | Computers & Internet
    Unlock numeric key pad on lap top
    your laptop should have a blue FN key (Function) that will work in conjunction with other blue keys on teh keyboard. most laptops this is located in the lower left, next to the ctrl key. Look to the right top on your keyboard for a one labeled numlk. hold down teh left FN key and tap the right num lk key and you just turned off the numbers lock.
    There is another option that is a little more intense - if interested let me know that laptop type you have.
    Feb 04, 2010 | Microsoft Windows XP Professional
    My function key is on and i cant figure out how to turn it off
    To use the embedded keypad
    After pressing Fn+F8 to activate the numeric keypad, you must press the Lock key
    (in the top row of the keyboard) to turn number lock on or off.
    When number lock is on:
    • Keys change to the numeric or arithmetic designations printed on the right side of the
    keys in the numeric keypad area.
    • The Num Lock status indicator is lit.
    • To turn off the embedded keypad, press Fn+F8 again.
    For further reference of usage of Function keys, check the HP manual:
    http://h10032.www1.hp.com/ctg/Manual/lpi05379.pdf
    Page number: 30/141
    Regards,
    Nags
    Jan 19, 2010 | HP Pavilion N5415 Notebook
    Numeric keys not workin g
    The key in the top-left of the numeric-pad enables/disables the numeric keypad. Press it once, to make the keypad function as a numeric-pad.
    Dec 11, 2009 | Logitech MX5500 Keyboard/Mouse
    I recently replaced the magenta cartridge in my HP 3210 Photosmart printer because the light indicated it needed to be replaced. However, the printer still won't print, and the message still says that I...
    If you turned the machine off and replaced the cartridge, you can get this error.
    Could you try the following procedure below please to clear the error, thanks.
    1. Turn on the unit.
    2. Open the top cover to access the print cartridges.
    3. Remove the new cartridge that is causing the message.
    4. Reinsert the cartridge and close the cover. The following message will appear on the front panel: "Press 1 for new cartridge or press 2 for a used cartridge."
    5. Press the 1 on the numeric keypad of the HP product.
    If the message, press 1 for new cartridge or press 2 for a used cartridge, "does not appear after removing and reinstalling the new cartridge, and the low ink warning message still displays,
    follow the steps below:
    2. Open the top cover to access the ink cartridges.
    3. After the cartridges stop moving, unplug the power cord.
    4. Remove both cartridges and close the top cover.
    5. Plug the power back in. The unit will reinitialize and a message will appear to insert the cartridges.
    6. Open the top cover and reinsert the ink cartridges. Close the top cover. The message,
    7. Press 1 for new cartridge or press 2 for a used cartridge," should appear.
    Hope this helps
    Regards.
    Apr 18, 2009 | HP Photosmart 3310 Printer
    Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
    NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
    Mar 22, 2009 | HP 2133 Notebook PC
    Numeric keypad affecting laptop
    Another common problem. The drivers of the numeric keypad always confuse the NUM lock button. Try playing with the numlock and also if it does not work, try reinstalling the drivers.
    Mar 06, 2009 | Computers & Internet
    Keyboard
    The Numeral Lock mode is turned on by pressing the key named "NUM LOCK" which is usually located on the top of the number keypad (on far right side of keyboard).
    However, laptop keyboards are different. Most laptops do not have a separate numeral keypad set. Those laptops usually use a blue (or other color-coded) "Fn" key, on the bottom left. You must press that Fn key at the same time as the "Num Lock" key of same colr. Then a light comes on to indicate the mode change, and some alpha-numeric keys on the keyboard now become your numeral keypad. On mine, it is 789, UIO (456), JKL (123) and M (which is zero).
    If this is too confusing, you can plug in a cheap full size desktop keyboard, using the USB or PS2 port on your laptop. That is what I prefer, because the funky integrated dual-key deal interferes with all the touch-typing I learned 37 years ago.
    Feb 10, 2008 | Compaq Presario 1275 Notebook
    HP Pavilion zd8000 Notebook Logo
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
