Question about HP Officejet 5610 All-In-One InkJet Printer
HP Officejet 5610 All-in-one Installation trouble
Computer won't install software correctly. Says registry key does not exist, issues stopping installation are:
1. slbcsp.dll
2. sccbase.dll
3. gpkcsp.dll
4. Enum
What do i do?
I used the live chat feature on HP's website. They guy I talked to reminded me very simply that the disk I was using to try and install the printer software did not support Windows Vista, which i what my computer is operating. He gave me a website and I downloaded and installed the Vista version of the printer software. I works perfect now!
(I'm sorry I can't remember the software, but live chat is great and they should be able to give it to you right away if you ask for it. Or you could always google it)
Posted on Jul 19, 2008
Cant get it to install
uninstall the existing printer drivers first before you try a reinstall.
Mar 16, 2017 | HP Photosmart 2575 All-In-One InkJet...
I have a new computer but can't find my installation CD for my Officejet 5610 printer/fax/scanner. Can I download the installation software and install the printer on this new computer?
Yes, you can download the software from www.hp.com
> Click on Support & Drivers on the top.
> Type the product name "Officejet 5610" and click GO
> Select the Operating system and click Next to download the driver.
Regards
Riztech
Jan 10, 2011 | HP Officejet 5610 All-In-One InkJet...
Had to install a new harddrive on my HP computer, while installing the HP J4580 software I had a power failure.....rebooted and uninstalled (using the control panel uninstall) the J4580 software. NOW when...
it's sure that the hp j4580 entries are still existing in the computer if the installation was done with the cd-rom then please do the following steps: insert the cd-rom into the computer do not auto-run the cd go to the hp cd icon in my computer right click on cd icon then click on open then look for folder named util under util right click and open folder ccc then under ccc you will look for a file l3 uninstall or uninstall.l3 right click on it and click on open then disconnect the usb cable from the printer(in case it is a wired installation) go on selecting the files that the uninstaller will show then do not restart then go to the control panel go to add or remove programs remove the hp softwares if exists(hp j4580 required software,hp solution centre,hp imaging device,hp customer participation program,shop for hp supplies,etc.. ) then go the start icon go to the run option enter "regedit" then registry opens up click on h-key local machine select software then select hp printer entires that are highlighted then delete them from the registry restart the computer then download the fresh version of j4580 from hp.com then install the software the issue will be resolved for a software download install: go to the folder where the downloaded version is saved then right click on the software and click on `run then close the folder then go the temp folder by writing the command in the run box %temp% then look for a folder that starts with the name"7z........." open that folder then look for util folder then the steps mentioned above will be done please try this and the issue will be resolved if the issue remains unresolved please revert back
Dec 22, 2010 | HP OfficeJet J4580 All-In-One Laser...
Installing officejet 5610. Donlt have disk for
You can download the required installation drivers and software from manufacturer's site by clicking this link
On the page which opens, select your operating system to download the appropriate drivers and software.
Hope this solves your problem. Thanks.
Nov 21, 2009 | HP Officejet 5610 All-In-One InkJet...
The program won't install
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
aswq21
Aug 20, 2009 | HP Officejet 5610 All-In-One InkJet...
FAX
If you have fax on hp officejet 5610.
You can recive fax .
start>steeting>printers and Fax> Setup Fax.You need windows XP CD for this Fax installation.IF manufacturer given software u r not need to install again.Just review the fax configuration by rigt click on fax icon then go to properties.
IF it helps
pls RATE ME
Jun 25, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610xi All-in-one Installation problem
Hi Tom,
The Software that you are trying to install is not compatible.
Download the compatible software here ----> Download
1.Click on Download Only, save the file.
2.Disconnect the Printer.
3.Run the downloaded software, follow the instructions and install the printer.
Reply if there is any problem.
GoodLuck
Thanks
Riz
Jan 14, 2009 | HP Officejet 5610 All-In-One InkJet...
Instal problame
Try downloading the software and installing it. Make sure that you download for the version of windows that you have.
http://h10025.www1.hp.com/ewfrf/wc/product?product=441115&lc=en&cc=us&dlc=en&submit.y=6&submit.x=2〈=en&cc=us
Dec 30, 2008 | HP PSC1410 Printer
Installing HP 5610 all in one printer
Please let me know if you have Windows Vista on the new computer and you are putting the Installation Cd to install the printer on the computer.
Please check if Windows Vista written on the CD. If not no problem. Plug the usb cable to the computer and connect printer. Wait while you get the message that the device is ready to use.
Now try printing abd it will work fine.
If it is still not getting installed.....Go to Add/Remove programs and uninstall the drivers for the Printer "Deskjets and Officejet" or anything like that. Then try installing. The issue will be resolved.
Aug 04, 2008 | HP Officejet 5610 All-In-One InkJet...
Trouble installing HP officejet 5610 all-in-one
slbcsp.dll - this registry does not exist
sccbase.dll - this registry does not exist
gpkcsp.dll - this registry does not exist
Enum - installer can not access
Oct 22, 2007 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
219 people viewed this question
Seeker5211
Seeker5211
