Question about Brother IntelliFAX 4100 Laser Fax
Black lines on received faxes
I get two lines down the center of our received faxes. what should i try to clean. Also, down through the center of the page the print is very light.
thanks
  • 550 Answers
Look for a corona wire, close to the drum
  1. Clean the primary corona wire inside the drum unit by gently sliding the tab from right to left several times.
  2. Return the tab and snap it into the home position.
black lines on received faxes - zl42b.gif Note
    If the tab is not at the home position, printed pages may have vertical stripes.
    Posted on Jul 18, 2008
    • AlmostBob
      AlmostBob Jul 18, 2008
      imge didnt go :(
    Black Stripe on outgoing faxes
    If the stripe is a thin line, the scanner glass is dirty, if it is wide stripe you have a bad scanner block. EXPENSIVE
    Jul 01, 2010 | Brother IntelliFAX 4100 Laser Fax
    Black line down center of faxed document
    Where u put in the faxes there is a glass with LED's on it that needs to be cleaned!
    Apr 29, 2010 | Office Equipment & Supplies
    Black line down paper
    Pull the doc feeder open and clean the scanner glass
    Feb 11, 2010 | HP 1040 Plain Paper Inkjet Fax
    On sending a fax the receiver copy has a black
    You must clean the glass strip that the origional passes over to be scanned. You may have White-Out or an Ink smuge on it. Another way to determine if it is your FAX is to put in an original and make a copy. If the line is on your copy than it is your scanner **** (glass).
    Oct 30, 2009 | HP Officejet 6500 Wireless All-in-One...
    Black line down the center of the page on faxes
    I am assuming that you have clened the glass the problem therefore would be in the optics most likely a hair on a mirror. You can try opening up the case and cleaning them with a cotton ball and some alcohol, but unless you are handy you may not get it back together.
    Oct 02, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
    PANASONIC FAX MACHINE PRINTING BLACK THICK LINE
    Open the front of the fax machine. Then pull down the the tray that has the down arrow imprinted on it. Locate the glass strip towards the back, just behind the center roller. Use a cloth and rubbing alcohol to clean the glass and that should remove the black line.
    Apr 22, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
    Black line about 1 1/2 inches wide down side of faxes or copies
    if your RECEIVED faxes look good, then leroyal is dead on. you will need a new CIS which stands for contact image sensor. if you have an authorized brother service center nearby, they may be able to do it for 100 to 150.00, depending on their pricing of course. if rec'd faxes are bad also, pull drum out and make sure the blue tab on top of drum is all the way to the right side, although that usually only leaves about a 1/2" black band.
    hth,
    razors
    Jan 27, 2009 | Brother IntelliFAX 4100 Laser Fax
    White vertical line on received faxes
    hi,
    The upper glass is under the drum unit.
    - Remove Toner and Drum Unit and you will see the glass. Try to clean it.
    Bye.
    Dec 02, 2008 | Panasonic KX-FL501 Plain Paper Laser Fax
    Line almost straight down center when receiving fax
    if you try a internal print such as a report does it go away? if so its more lucky the person sending you the fax.
    if you print a report and its on there i would check the ribbon and look for marks, also it could be a transfer problem causing these marks.
    Hope this gives you a starts
    Oct 21, 2008 | Brother MFC-1970MC Plain Paper Inkjet Fax
    Stripe on receiving fax Brother MFC 7820N
    I had the same problem, and I just fixed it.  It was a tiny little black dot which was stuck to the glass where the document feeder passes the paper to.  First you need to figure out where the line is on paper with respect to the paper, and just carefully run your finger on the glass to see if there is something on the glass.  I removed it, cleaned the glass, and anything which I run through the document feeder is now fine.  Hope this helps.
    Aug 15, 2008 | Brother MFC-7820N Printer
    Brother IntelliFAX 4100 Laser Fax Logo
    288 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
