Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Not wireless service
I just bought a new laptop, i had westell wind river modem before, it worked perfect, but don't have wireless. i got westell versa link 327w from a friend, this one have wireless, but still my laptop don't have internet conection, i don't have manual or intalation disk so i don't know if i'm doing something wrong.
BOUGHT A NEW ROUTER
Posted on Jul 19, 2008
Where ca i find it's drivers
I dont think u can that looks like its box u get from a company provider.. Netgear bought out westell and u can look there for something..
Sep 05, 2012 | Westell Wirespeed Westell Dsl Router Wind...
Modem installation
It is not a lost cause BUT you will have major issues connecting to most websites because the browsers are so advanced now that if you connect, it wont display correctly and there is an issue with some secure servers rejecting you because the operating system can be read and the server wont allow the connection.
http://www.dslreports.com/faq/bellsouth/3.14_Westell_2100_2200_6100_Info#7342
Jul 26, 2017 | Westell Wirespeed Westell Dsl Router Wind...
How do I hook up my Westell wireless router to the zhone modem so I can use my laptop. I have to use a dedicated line with a zhone modem to get DSL service. I want to hook up my wireless router Westell...
Connect the Westell wireless to the Zhone as if the Westell is the PC that used to be connected to it. Then connect the PC (through any available port) only to the Westell. That's the WIRED connection. For the wireless to work, after connecting through the WIRED connection, there should be a CD that came with it that will help you configure the wireless.
Feb 18, 2010 | Zhone 6212-I3-200 Router
I have charter internet with a modem and i have a westell 327w wireless router/modem. How can i connect the two modems to work wirelessly?
I think the Westell Router/modem that you have must be the modem for the DSL connection.
Charter is a cable internet service provider.
You can not use 2 modems connected to each other.
You have a charter modem , you can purchase a wireless router only.
That will work.
Click Here for more info about routers
Oct 27, 2009 | Westell Wirespeed VersaLink...
No wireless connectivity with Westell 327w
on the back of the modem is a reset button. try resetting and bridging the modem again.
Apr 09, 2009 | Westell Wirespeed VersaLink...
Westell model 327w router
if this is the first time you're trying to connect your laptop with the gateway, if this is a windows operating system, you have to go to your wireless zero configuration so that windows can automatically configure the wireless connection of your laptop. you cann see that by clicking on start, and then run, and then type in the box services.msc, and then search for wireless zero configuration click on start if the service has not yet started. if this doesn't work check your built in wireless adapter, uninstall and reinstall it. try to access your westell by typing in 192.168.1.1 in the internet explorer address bar. the default username and password for that is admin and password. you can configure the wireless settings in the modem by going here. the WEP key for your wireless connection can be found below your westell modem/router. if i'm not mistaken this is the westell 327 versalink right? you can also find out if your laptop is connected to your modem by checking your computer's ip address. it should be 192.168.1.xx. if it's like this, your laptop is connected to your 327w. if it's a 169.xxxx ip address, you're not connected to the modem. the best way to configure your laptop and modem wirelessly is to configure it while you're connected using an ethernet cable.
Oct 21, 2008 | NetGear DG834G Router
Westell model 327w
you can run another ethernet cable from your westell modem to your laptop. hence, if you want your laptop to connect wirelessly, it must have a wireless card/adapter inside. if it already has a wireless adapter, it should automatically detect your wireless network and you just need to connect to it (note: you need to enter the correct wireless security/network key if you have enabled it on your modem). by default the serial number is the ssid of the router and the wireless security is disabled. but if you are not sure of your wireless security, log on to the modem's web user interface by typing http://192.168.1.1 on your web browser's address. then go to the wireless section and verify your wireless settings from there.
hope this'll help you.
ciao!
Aug 20, 2008 | Westell Wirespeed VersaLink...
I have a westell versalink 327w date on the bottom is 07/2007
You'll need to go into the administrative interface of the router and enable the wireless network and then you should be able to see if from any laptop/PC with a wireless networking card in it.
Feb 05, 2008 | Westell Wirespeed VersaLink...
Hook up westell 327w to linksys router
the wireless won't work. i have the same problem. westell modems aren't compatible with wireless function on some laptops therefore routing signal through a wireless router allows that. it can be done, i've done it but after modem was reset having issues. keep searching it can be done...
thanks for the vague and non-informative answer though whoever that was.
Jan 14, 2008 | Westell Wirespeed VersaLink...
DSL modem and Linksys Wireless Router not working together anymore
if i were to guess you are probably a PPPoE user with a dynamic IP address.
possible config
Dec 18, 2007 | Computers & Internet
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
133 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
