Question about Danby DPAC8399 Air Conditioner
No Fan Somebody junked this thing, I guess because the fan doesn't work. Does anybody have any experience with the fan? I figure it has to be the relay (but I hear a click), the capacitor, or the fan motor (fan rotates freely). Before I perform surgery, I'd like to clarify the diagnosis. Thanks.
  • Mad Tinker Jul 18, 2008
    OK, I got the cover off (do they really need six different kinds of screws???) and spun the fan by hand. When I turned the unit on (with the fan still going), it worked fine. So I think it probably is the capacitor. It tests bad (small resistance, then infinite). Any recommendations on where to get a new one? It's a 8 μF, black box with four spade lugs and one mounting flange off the side. My two regular sources (Sears Parts and ApplianceParts) don't list it. Danby's web site isn't much help. In the meantime, I think I will use the Hi Tech approach (use a bigger hammer) and start it manually until I get a new capacitor. Thanks.
  • Andre99 Jul 20, 2008
    Fan motor will not start on its own - when on switch pushed compressor starts but fan "jiggles" back and forth maybe an 8th of an inch a couple of times but that's it. If I push it it runs fine. I do not hear a click when I push start. No noise whatever.
  • 42 Answers
Danby DPAC8399Aftermarket (Post Warranty)Parts 800-496-6049 CanadaAsk for the motor start capacitor, cost me $38 with shipping
Posted on Sep 27, 2011
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
If you here a click then check the Relay, open and turn on you should see a black box with wires going to it, (Careful HIGH VOLTAGE!!!!)
Posted on Jul 18, 2008
I have a Hampton bay model number 266-848 ceiling fan and the lights on the fan keep going off and on by them selves and now I can't get the fan to work .What could be the problem?
I would guess you have someone else in your neighborhood who happened to set the same digital code pair as you (or didn't set it and they're both set to the factory default). Open the remote and change one of the rocker switches to a different code. NOTE which one you change.
Open the bezel where the fan attaches to the ceiling, find the rocker switches and do the same thing. Can't figure out why it would have quit completely - perhaps weak batteries in the remote?
Mar 04, 2018 | Hampton Bay Dryers
SUZUKI SX 2009 FAN FOR AIR CONDITION IS NOT WORKING
times 2, what fan................/?????? point to it or name it... (exact location)
answering for front grill, condenser fan.
cab fan is called blower.
are you a tech>? do you want just wild blind guessing?
no , own a $10 volt meter, well that is easy to use. (1hr, training)
if there is 12vdc to the fan up in grill. then the fan is bad.
if 0v the relay is either bad or being told not to energize.
if the relay coil is 0v (across it)
then the relay is commanded off for due cause.
more tests.. ask.
there are 8 reasons for the (BRAINS box) to cut fan. up to 8.
if the brain box goes to cut A.C
it cuts the compressor and fan.
we can find this easy with that same meter.
in a jiffy.
but most here , just want blind guessing
so here , ill feed the flames.
the fan relay is bad.
ask me tomorrow
and the fan is bad....
Feb 02, 2015 | Suzuki Cars & Trucks
Blower motor stays on when car is off 1999 mercury mystique
The Mercury Mystique had somewhat of a bad reputation for wiring problems. I guess my question to you is have you had to have the wiring worked on?? If so, I'd guess that it would be pretty possible for a wire to be hooked up wrong at the ignition switch if somebody has been fooling with that. Just a thought... Also, I'm wondering if the fan continues to run until your battery goes dead?? Now, I'm hoping you don't have the blower motor (for the heater and air conditioner) confused with the electric engine cooling fan. It is normal for the engine fan to run for a while after you shut your engine off. But, I'm probably telling you things you already know along that line.
Dec 06, 2013 | Mercury Mystique Cars & Trucks
NEED A WIRING DIAGRAM
go to the junk yard with a camera take a pic of the wiring harness then go back an match them up
Feb 07, 2013 | Cars & Trucks
Compressor not working
If unit is receiving power and a new start cap/relay will not start the compressor then latter is toast and it is time to go shopping.
Aug 22, 2017 | Frigidaire Refrigerators
Hunter ceiling fan remote will not turn off light it just dims the light
Try this. Remove power from the fan. Remove batteries from the remote. Press butttons on remote (might be stuck). Apply power to the fan. Install batteries in the remote and try all functions. If this doesn't work, the remote may be defective or the remote receiver may be defective. I can tell you from my own experience I have a ceiling fan that loses its mind whenever there is a power outage. Has to be reeducated from scratch
Oct 06, 2012 | Hunter Ceiling Fan Remote Transmitter...
My insignia computer wont recognize my computers output!
Are you sure you have the proper adapters and the drivers are downloaded properly and that they are compatible. All these things have to be perfect for it to work. What keeps coming to mind since I read your query is your drivers. I just had a bad experience with downloading audio drives. Windows security was partially blocking my downloads and it would leave part of the drivers out and it would give the error"Speakers Unplugged". The computer said the drives were working fine but they were not installed correctly. Just a few things to try.Hope one of them works.
Gillight.
Aug 27, 2012 | Insignia Televison & Video
My 2004 pontiac grand am cooling fan doesn't work what do i need to do
The cooling fan can be run through a self diagnostic by a dealer using a special tool called a scanner, it will then deliver back to the tech what is found, this can be any number of things, the fan motor wiring to it or the controller for the fan. Guessing is not an option and if you keep overheating this engine you will shortly need a new one.
Jul 18, 2012 | 2004 Pontiac Grand Am
Fans wont come on 2004 ford tarus
It sounds like temp control switch, either on radiator or thermostat housing, it will have a couple of wires on it, if you disconnect the plug and just connect the 2 wires together with the ignition on the fans should start, if they do then replace the switch, if they dont check for a blown fuse, ( they are normally quite a high amp fuse)
Jun 16, 2011 | Ford Taurus Cars & Trucks
Danby DPAC8399 Air Conditioner Logo
184 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
