Question about Dryers
I am building a platform to sit my newly purchased (not delivered yet) Bosch Nexxt 500 Electric Dryer. I need to know where the vent hose comes out the back and also is the depth of 31 3/5" include the vent hose turning and going out a side vent hole?
I went back out to the store and looked at the back of the dryer and measured where the vent hole was.....
Posted on Jul 19, 2008
How do you reset the Bosch 500 series dryer?
One has to remove the back panel (need Torx bit). Down by the exhaust vent, there is a small red button (see detailed drawing) and push it to reset. It is annoying but will save a lot of money on a service call.
May 26, 2014 | Bosch Nexxt WTMC 3300 Electric Dryer
Bottom venting Electric Dryer
If you never find one, can you do this? Build a 5 inch platform for the dryer to sit on,( out of wood), and then take a flexible hose and run it from the back of the dryer to the hole in the floor under the dryer?.
Dryer vent hoses come in metal or plastic. Some metal ones have a 90 degree elbow included which would make the turn under the dryer easier.
Be blessed.
Jan 05, 2014 | Whirlpool WED5800S Electric Dryer
My Bosch Nexxt 500 dryer keeps tripping the hi-limit cut out.
Try checking your exhaust vent pipe for excessive bends and kinks, make sure there is good strong airflow coming out the exhaust where it exits the building.
Dec 12, 2013 | Bosch Nexxt 500 Dryer
Bosch Nexxt 500 series dryer
Make sure the vent outside isn't blocked either.
May 21, 2012 | Dryers
What do I purchase to connect my new dryer to the vent?
SHOULD JUST NEED A 4 INCH VENT HOSE AND TWO 4 INCH HOSE CLAMPS NORMALLY COMES AS A KIT... I WOULD RECOMMEND METAL FLEX HOSE INSTEAD OF THE PLASTIC STYLE AS IT DOES GET HOT WHEN EXHAUSTING AIR....
Jan 12, 2011 | Bosch Nexxt WTMC8320US Electric Dryer
Lint is building up in the dryer vent outside and the dryer is heating up but not drying the clothes
you will need to clean out or replace the vent line as you clothes will not dry if there is a restriction in the line.
Oct 04, 2010 | Bosch Nexxt WTMC 6300 Electric Dryer
My Bosch Nexxt 500 Dryer takes way too long to dry!
check your flex vent hose on back of dryer are go out side your home an locate where the vent come out of your home an see if the air flowing out of your vent, if not you need to pull the dry out take the hose off of the dry an clean the lint out ok, an send me the money you find in the vent ok
Apr 24, 2010 | Bosch Nexxt 500 Dryer
Bosch 500 series dryer stuck on pause mode
things I would try:
remove the power from the dryer and let sit for a while. Plug back in when you feel it is time.
If that does not reset, I would take the cover of the board to see if the button is not stuck. (remove the top 1st, the the cover of the control board will come out)
Jun 05, 2009 | Bosch Nexxt WTMC3321US Electric Dryer
Bosch Nexxt 500 Plus Elect Dryer Error E01
Absolutely those dryer sheets are the root of all evil....I would also recommend a good vent brush to clean your dryer vent.
Follow these steps, it worked for me:
1. use a shop vacuum to clean out the dry vent or a vent brush.
2. Clean your lint filter with windex, hot water and and soft bristle brush.
If this doesnt work try running the until disconnected from the vent for a cycle to isolate the vent as your issue.
Cheers!
Oct 28, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 500 Electric Dryer: lint filter light goes on even though it does not need emptying
call bosch. they are having problems with one of the sensor in that dryer. they try to fix it but in my experiance they end up having to swap out the dryer
Nov 20, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryers Logo
64 people viewed this question
Top Dryers Experts
