Question about Keating Kitchen Appliances - Others
Need 3 phase contactor for keating deep fryer
DO YOU HAVE OR KNOW WERE TO GET ONE .
    Champion:
  • 254 Answers
You might try
http://www.grainger.com
You will have to determine the amperage size, voltage load size, and the coil voltage size. This info should be on the old contactor you can comment me if you need more help.
Hope this helps you
please rate me
Posted on Jul 25, 2008
Wells deep fryer 208 volt 3 element. 1 element works other two don't working left to right. Continuity good resistance good. Relay problem?
Sounds like this maybe a three phase unit and you are powering it off on single phase power. Most can be converted to single phase but will draw three times the current and requires some wiring changes. It needs to be on a three section breaker for 3 phase.
Jul 21, 2014 | Kitchen Appliances - Others
I have an old GE deep fat fryer,m/n CK40B, which has no wiring diagram, I am trying to use it for my shop, but can't find any diagrams anywhere on this fryer. It was wired for 3 phase, I am trying to...
If you feed single phase into the line terminals, you will get only 1/3 the heat wattage. To get all heating elements working on single ph, you'll have to separate the common ends of the elements, then connect all 3 in parallel. Keep in mind, doing so will raise your line amperage x3 also. That may put you over the contactor's max rating. Another thing, the contactor will activate on only one sequence of single phase. You may need to move the line to another 2 of the 3 connections.
Feb 02, 2018 | GE Kitchen Appliances - Others
My keating fryer heats the oil fine to temp set on thermostat but will not re fire when oil temp drops unless I push the high limit button. Don't know if the problem is the themostat or high limit...
Sounds like the thermostat is working because it does heat to the right temperature, right? The high limit switch is to shut it down when it gets too hot, so why that helps the unit relight and heat up is strange? Is this gas or electric? Since hitting the reset or high limit button is what is working, I would start there, and replace that... I don't think either part is super expensive, so replacing both wouldn't be too expensive, especially since you have one of the best fryers ever made... Keating is number one in my book, and I know they are expensive to start with, but these two parts shouldn't be much....however I would start with the high limit switch or reset button... If you need a part, we can get you a price....I'm Susan with Restaurant Equipment Outlet, Cincinnati, Ohio, 888-542-5959, or you can ask for Paul too. Thanks, Susan REO
Sep 12, 2011 | Keating Instant Recovery 20AA (NG) Deep...
WHICH IS THE BEST DEEP FRYER. VULCAN 70 LB NAT GAS OR AVANTCO 70-100 LB
Vulcan, however there are other brands that are better than both of those...Keating is one and Imperial is another. There is a pretty big price difference also. The Keating is the most expensive, but also the best of the bunch.... If you need additional pricing, please call us at 888-542-5959. Our website is www.restaurantequipmentinc.com Thanks, Susan Restaurant Equipment Outlet, Cinc, OHio
Aug 19, 2011 | Vulcan Kitchen Appliances - Others
Converting from three phase to single phase
Do you want to convert 3 phase to single phase?What voltage do you currently have (220v 3phase)?
May 07, 2009 | Kitchen Appliances - Others
Change 208v heating elements to 240v.
If your supplying 240 vac to a 208 vac element it will work but shorten the life of it.Goto 3wire.com and register,they should have a 208vac element.The wild leg could also be an issue but if you get a 208 vac element it shouldnt hurt it that much.Why you would be getting a reading of 240 vac on l1-l2-l1-l3-l2-l3 is strange.Let me know.
Mar 25, 2009 | Cecilware EFS-40 Deep Fryer
Just bought wells fyer model # F-67
3 phase is VERY DANGEROUS, contact an electrician,
Jan 26, 2009 | Wells F-67 21167 Deep Fryer
Starting the fryer
PUSH THE LIMIT TEST BUTTON.BAD GAS VAVLE OR TRIPPED LIMIT.
Jul 23, 2008 | Keating Instant Recovery 14CMG Deep Fryer
Kitchen Appliances - Others Logo
160 people viewed this question
Top Keating Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Keating Kitchen Appliances - Other Expert? Answer questions, earn points and help others
