Question about Epson Expression 1680 Professional Flatbed Scanner
Communication with scanner
Quite regularly (in one out of three scans), the scanner stops before the scan is finished and a dialogue box comes up that says: 'Could not communicate with scanner etc.' I've installed the latest driver, bought a new device cable that shows (with a little blue light) that the connection is working and it still happens. What can I do to solve the problem?
  • Epson Master
  • 2,794 Answers
You could take it apart and see if you can lubricate the shaft the the scanner sits on with some vasoline. If that doesn't it could be that the stepper motor that controls the scanner is going bad in it.
Posted on Jul 18, 2008
My fujitsue fi-6130 stopped automatically scanning both sides
You can try a 'hard reboot' of the unit by unplugging it while it is running, wait a minute or so and then restore the power.
With most electronics this forces a 'self-diagnostic' program which might fix the problem. Another option is to delete and them reinstall the software with a disc or online. Make certain that you have your machine set to automatically check for updates if it is connected to the Internet.
Jul 22, 2014 | Fujitsu fi-6130 Flatbed Scanner
Nikon Coolscan 5000 ED not scanning
Have you tried resetting the scanner itself?
Jul 09, 2008 | Nikon COOLSCAN 5000 ED Film Scanner
How do i scan more than one sheet into a pdf document?
In Adobe Acrobat, go to -File-/-Create PDF-/-From Scanner-/-Scan-. Scan your first sheet and after it is completed, in the Acrobat Scan Dialogue box, click on -Next-, and scan the next sheet. Continue until you have finished your document and then click on -Done-. You can make your scanned document searchable by doing an OCR procedure on it by going to -Document-, -Recognise document by using OCR-/-Start-.
Aug 12, 2011 | Canon MP560 All-In-One InkJet Printer
Simply how to use the scanner which does not come with instructions. Many t hanks for your assistance
  • Click Settings > Scan Settings > Button Settings at the bottom of the left pane.
  • Click the Scan Picture Button tab. Under "Scan to" select the program you would like to edit the image with after the scan is finished.
  • Repeat step 2 for the Scan Button, the Scan Document Button and Scan Film Button. Select the program you would like to use to open each type of scan, or select "Save to File" and the desired file type. Select your preferences under the Document or Picture menus based on the type of image or document you will scan most often using this button. Ensure that the "Show Preview" check box is checked for each button type. Click "OK."
  • Place your document or picture on the glass. If scanning film, place the 35 mm negative or slide in the special adapter provided by HP. Select the Scan Picture, Document or Film button depending on what you are scanning. Select the Make Copies button to copy the document or picture directly. Click "Scan" and then "OK" to see the scan preview.
  • Crop your image by clicking the small black boxes at the edges of the selection area. Drag your mouse until the portion of the image you wish to scan is selected. Select the image correction settings in the menu on the right to fix any problems with the picture or document. You may also change the image resolution and resize the image in these menus. When you're finished, click the "Accept" button. If you'd like to scan another image, select "Yes" in the next dialogue box. If not, select "No."
  • Feb 21, 2011 | Office Equipment & Supplies
    I cannot scan
    If you on windows xp, go to My Computer and in the list of drives and devices you will see your scanner icon. Double click to open the scanner dialogue box. From there simply follow the instructions to complete your scan.
    If you are on windows Vista, go to start/all programs/windows photo gallery. When it opens click on file/import from scanner or camera. The dialogue opens for you to select your scanner. The scanner dialogue box opens and simply follow the instructions to complete your scan.
    Good luck & God bless!
    Nov 23, 2010 | HP J3680 Officejet All In One Printer
    I own a brother mfc 7840W and want to scan to a word file then convert it to a pdf how would I do this?
    hello there
    first thing, scan the document and when you typed the filename below that box is option, you can select what extension name you want to that file select pdf and click save. be sure you have pdf reader or acrobat reader etc..
    Thanks
    Nov 13, 2010 | Brother MFC 7840W Printer
    How do I recalibrate
    Normally just use it./ After so many uses the scanner driver will automatically conduct a recalibration.
    You may have to do 20 or more scans for it to happen but if you keep changing the setting in the scan dialogue box each time, you may get it to happen quicker.
    Jun 24, 2010 | Canon CanoScan N670U Flatbed Scanner
    Not reading card
    Hi m cantell. This is one of those issues that could have about 20 different causes. Fortunately, they are all quite easy to fix. I keep a general initial troubleshooting guide on my company's website (www.shiftintoblue.com/troubleshooting) give that a look-over and see if anything there solves your issue. If not, I've hosted Metrologic's configuration manual for you (www.shiftintoblue.com/resources/metrologic_config.pdf). Before you start scanning configuration barcodes, though, you'll need to know your scanner's communication method. If it is Keyboard Wedge or RS232, you'll be fine. If it is IBM46XX, USB (standard/low speed), or USB (full-speed USB/FSUSB), you will have to do a little more configuration and I will go over that at the end. After you know your communication method, go to page 11 and note the barcode 'Recall Defaults'. Print this page, and scan the barcode on the sheet. This will reset the unit to it's factory defaults (or, if your vendor took the time, the defaults they know you need to have) and should solve any problems within the unit.
    As I mentioned before about communication methods, if you have IMB46XX, USB (regular), or USB (full speed) then you will need to do one the following.
    For IBM46XX: use page 50 and scan the barcode "Load IBM46XX Defaults" and then "Enable IBM46XX Communication". This will enable IBM46XX communication.
    For USB: use page 51 and scan the barcode "Enable Low Speed USB" and then "Load Low Speed USB Defaults". This enables regular USB (like you'd find on a PC) communication.
    For full speed USB: use page 185 and scan "Enable Full Speed USB" and then "Load Integrated Full Speed USB Defaults". This will load the integrated FSUSB communication settings. If that doesn't work then scan "Full Speed USB Defaults". This will load the hardware's original FSUSB settings (if applicable).
    A side note: FSUSB is very, very different from standard USB. If you have standard USB, do not use the FSUSB configurations out of desperation. Many of my clients (and myself once) have done this and can really make a mess of things. If you need more help, please feel free to send me a message or email me. I hope this helps. Good luck!
    Jan 04, 2010 | Microsoft Metrologic MS7120 ORBIT Barcode...
    Scanner Canon 5010c
    This is a known problem with the scanner. Use PixEdit to scan which comes around this problem so the scanning terminates OK after the ADF goes empty.
    Dec 22, 2008 | Canon DR-5010C Path-Through Scanner
    Epson Expression 1680 Professional Flatbed Scanner Logo
    177 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
