Username /password to change
Using D-link for 2 years now, had some power disturbances & d-link went bad gave for service- BIOS set up problem & got it rectified. even checked the working in the service centre.
have a broadband connection with BSNL here in India. the serv guy told to change the u.name/p.word . How do I do it pls HELP.
Thank U all
regds
MSrinivasan
    Problem Solver:
  • 14 Answers
To change username and password in dlink router you have to access http://192.168.0.1 in the address bar of internet explorer
it will bring you to the configuration screen of dlink.. it will ask for the dlink usid and password, the default userid is "admin" , for the password leave it blank.
  1. The router's Web-based Setup Utility should appear. Do not run the wizard. Select the WAN button on the left-hand side of the screen.
  2. Select the PPPoE and Dynamic PPPoE options on the WAN settings screen.
Enter the your USERNAME and PASSWORD that your broadband connection provider gave you into the corresponding fields and select Apply and then Continue.
Once the screen refreshes, exit the browser.
now try to connect
Posted on Jul 18, 2008
Cant log in
This problem happens very often.
1. Try to request your password replacement or your username by saying that your have forgotten one or another. Your email server (company your your email with) will send you a link to change your password or username. Do it.
2. The best of all is to locate your email client setting on the site of your Internet Service Provider and configure your own email setting accordingly.
Nov 02, 2013 | Computers & Internet
Hotmail password went to change
Log in to Hotmail using your current password, click on your username in the upper-right, click "Account Settings", then click the "Change password" link.
Aug 25, 2013 | Computers & Internet
Only lights stnadby lamp
Turn on the Wi-Fi on a D-Link Router
The internal Wi-Fi radio is enabled by default on most new wireless routers. However, if you purchased a D-Link router used, you may find that the internal radio is disabled because the previous owner had an exclusively wired network and wanted to eliminate the possibility of a hacker breaking into one of her computers. Enable the Wi-Fi radio on your D-Link router to enable your computers to connect to the Internet wirelessly.
Connect the router to your computer using an Ethernet cable. Open a web browser and browse the IP address "192.168.0.1." Enter the username "admin" and leave the password blank. Note that these are default values; both the user name and password can be changed. Click the "Setup" tab at the top of the screen, then click the "Wireless Settings" Scroll to the bottom of the screen and click the "Manual Wireless Network Setup" button. Place a check in the box labeled "Enable Wireless" and click "Save Settings."
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc If you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima D-Link Wireless Router D-Link routers use the connection from your Internet service provider to create a wireless network for the various Wi-Fi- enabled devices in your home or office. Once the router is installed, you can truly enjoy the portable capabilities of your laptop or other wireless device. D-Link routers have a straightforward installation process, despite the advanced technology behind wireless equipment. So there is no reason to wait around for a technician to help you install your wireless equipment.
Remove the cable that is attached to the "Internet" port on the rear of your DSL or cable modem. Plug the Ethernet cable into the "Internet" port on the modem and plug the other end of the cable into the "Internet" port on the rear of the D-Link router. Attach the power adapter to the port on the rear of the router and plug the adapter's cord into a outlet. Remove the power cord from your modem and wait 10 seconds before plugging it back in. This will reinitialize your modem and force it to establish a connection to the D-Link router. Your router will immediately begin distributing a wireless network with the "D-Link" network name. Connect your computer to one of Ethernet ports on the rear of the router and open a Web browser. Type "http://192.168.0.1" into the address bar and press "Enter." Enter "admin" into the username field and type "admin" again into the password field. Click "OK" to open the wireless configuration page. Click "Wireless Security Setup Wizard" to create a wireless password for your router's network. Click "Apply" to save the changes to the router's settings.
Network D-Link wireless b> Type the router IP address, "192.168.0.1", into your Internet browser. Press "Enter" on your keyboard. Enter your username and password to log into the D-link configuration panel. By default, the username is "Admin" with a blank password field. To prevent outsiders from being able to access your D-link router's configuration panel, change the username and password to something more secure. This can be done by selecting "Tools" from the menu and selecting "Admin." Select "Administration Settings" and enter your new username and password. Save your changes by clicking "Apply." Enter the IP addresses for the computers you want to give access to your router. You can do this by clicking the "DHCP" link underneath the "Home" tab. Click "Apply" to save the IP addresses. Select the "Wireless" link underneath the "Home" tab. Enter a name in the "SSID" field to identify your wireless network. Choose "WPA" for your "Security" option. WPA will provide the highest level of security for your wireless network. Create a WPA password to access your wireless network. For maximum security, enter a combination of numbers, letters, and symbols. Store your password in a safe place in case you ever forget it. Click "Apply" to save your settings. Install a software firewall program on your computer to add an additional measure of security for your wireless network. A few of the popular firewall programs available are Norton Antivirus, McAfee and Zone Alarm.
Jan 28, 2013 | D-Link DIR-600L Wireless N150 Cloud Router
I forgot my username and password
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there hope this helps
also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased. Hope this helps
May 25, 2011 | Computers & Internet
I am replacing a linksys which is still working and I am using now. I cannot get the D-Link to connect to my bellsouth DSL
Step 1: Log into the web-based configuration by typing in the IP address of the router (default:192.168.0.1) in your web browser. Select Admin as the username and type in your password. Leave blank if you have not created or changed your password.
Note: The address 192.168.0.1 is NOT on the Internet. The web-based configuration is built-in to the router.
If the router is already online, you will be taken to the STATUS page after logging in. If this is the case, the router is connected and you do not need to continue with this FAQ.
Step 2: Click the Setup tab and then click Internet on the left side.
Step 3: Click on the Manual Configure button.
Step 4: Select PPPoE (username/password) from the My Internet Connection is drop down menu and enter the following settings:
-Address Mode: Select the Dynamic IP radio button, unless your ISP (Internet Service Provider) supplied you with a static IP address.
-Username and Password: Enter the username and password your ISP gave you. In most cases your username is the same as your email address provided by your internet provider (example: yourname@yourisp.com).
-Reconnect Mode:Should be set to On Demand
-MTU and Maximum Idle Time: Should be left at the defaults (MTU: 1492 / Maximum Idle Time: 20) unless specifically instructed otherwise by your ISP.
Step 5: Click on the Save Setting button to save the changes.
Step 6: Click on Status tab and Device Setting on the left side.
If you are connected to the Internet; your Cable Status and Network Status will say Connected,you will have an IP Address, Subnet mask, Default Gateway, Primary DNS Server and Secondary DNS Server. If you do not, click on the Renew Button.
May 14, 2011 | D-Link DIR-825 Wireless QuadBand Router
Hello where can i know my user name for DSL-2640T ? I NEED IT !! PLEASE CAN U HELP ME
Hi
There is 2 Usernames when it comes to Routers.
1st is the USERNAME and Password you use to get into the Router configurations which is the following.
Username: admin
Password: admin
The above username and password is the Factory setting and only the password can be changed by an user. SO if it was not changed the password will still be admin or you can reset the modem to reset the password back to admin.
2nd is the Username and Passsword you get from your Internet Service Provider which usually is the email address and whatever password you gave them to set your internet up
Feb 04, 2011 | D-Link AirPlus DI-524 Wireless Router
Everex ce1200v won't except username and password
Go to Control Panel, select Add or remove user account, select The User Name with the Password, under Administrator or Guest acccounts. You can change the User Name and Password. I hope thise Fix it.
Jan 21, 2010 | Everex CloudBook CE1201V Netbook
Can't login to 192.168.1.1
Hi the username and password for the router has been changed while the previous configuration.If you can call your service providor they should be able to provide the same.There are other some common usernames and passwords which you can try.
username:admin
password:epicrouter
*OR*
username:admin
password:password
*OR*
username:password
password:password
*OR*
username:snowflake
password:password
*******Alternatively you can also try to reset the router to its default settings by pressing the reset button at the back of the router(however this should be the last step of action).
Apr 13, 2009 | Computers & Internet
Need to change password as all neighbors are using (I gave it out
You need to determine your gateway IP address. Click on your network status to determine that. It will most likely be 192.168.1.1. You can open a web browser and go to http://192.168.1.1 to get to your router login page. Try admin for your username and leave the password blank.
That should bring you the interface where you can change the wireless security settings to "enabled" and set your password. Let me know if this works for you!
Your ex may have set a different password for the router, and you may have to do a factory "reset" on the router.
Mar 30, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Computers & Internet Logo
239 people viewed this question
David Payne
David Payne
