Question about Electrolux EOG7330WN Gas Double Oven
Electrolux EOG7330 gas cooker - electric timer fails?
Electrolux EOG7330 gas cooker - electric timer fails - so grill and oven switch off. Apparently there is a switch behind the control panel which you press to reset the electrics, but where is it?
  • 7 more comments
  • popeye1969 Jul 18, 2008
    Hi tresilla
    Thanks for the quick response ime at work now so will take a look when i get home, we did have the grill and oven on high both at the same time and i cant remember the fan coming on so this might be the solution, i will let you know.
  • RickieH Dec 13, 2008
    oven and grill wont work and the elec timer is off. Had this problem once before and workman pulled 1 of the knobs on the timer off and put something in it to fix it . Any idea what he did ?
    Any help would be great.
    Thanks
  • stephen osullivan Dec 29, 2008
    we have same promblem can u tell me where reset button is plz send repley to platformhydraulics@yahoo.co.uk plz regards steve
    same fault need to know where reset button plz
  • andyb5051 Mar 05, 2009
    i have the same pro but my model is eou6330xx
  • Anonymous May 19, 2009
    Same problem despite no vent probs it was in my house, so I still hadn't fixed the kickboards!)
    Replaced overheat stat. A few months later main thermostat went.
    Now replaced (cheap parts) for £40 (parts only), but I am not impressed with my oven.
  • s j fixya Mar 14, 2013
    Yep, this solution works! Remove lower knob. Shine in torch. There's a small round red component, which you can press with a long screwdriver. The fault will then clear itself. Bizzare, but true!
    Yep, this works. Pull off lower knob. Look for small round red button. Insert long thin screwdriver. Once pressed, the cooker will click and the fault will clear. Very odd, but true.
  • Colin Templeman
    Colin Templeman Aug 02, 2015
    Confirmed. This definately works.
    It is only found behind the oven knob (lower of the 2 knobs).
    You need to have a very strong light and shine it down at an angle of 45 degres - through the hole in the front of the oven and through the hole behind (Approx 2 inches 50 mm from the face plate)
    The red button referred to in the article above is a very slim hollow tube threaded on the outside which appears from below. Approx same diameter as a pencil.
    There appears to be some sort of very slim rod showing in the middle of this tube. It needs a very long thin screwdriver or skewer or chopstick to depress this rod.
    Hey presto! Switch the power back on and both oven and grill are working
    Problem Solver:
  • 3 Answers
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Posted on Jan 15, 2009
    President:
  • 1,462 Answers
I suspect there is no fault with timer. there is an overheat stat usually on top of the oven but sometimes inside the back. if this detects overheat, then everything is switched off and comes back on after cooled down.
if this is the case, then suspect lack of ventilation causing the overheat or the casing cooling fan failed.
get back to me if i got it wrong
Posted on Jul 18, 2008
The grill and ovens on my Jackson Topline cooker have just stopped working, the rings work but none of the lights above the switches are on when they are working, any Ideas please? thanks.
I am not familiar with your model of cooker but I assume it is a gas cooker.
Gas cookers have safety devices in the oven and grill the hob rings do not need. I speculate even the domestic oven hasn't escaped the interference from the electronics industry and I expect the aforementioned safety devices depend on (low voltage) electronics and electronics depend on electricity - that the lights aren't working would suggest there is no (low voltage) electricity.
Even in the case of an electric oven the thermostat could be electronic and need (low voltage) electricity to work.
I suspect the internal power supply has failed.
Jun 17, 2016 | Ovens Ovens
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Replaced EOU43002X element, clock/timer now dead
Make sure there is power to the timer. Should be a fuse somewhere.
Mar 19, 2014 | Electrolux Ovens
Lamona LAM 4400 oven not switching on
may be an internal fuse / wire burnt off oven control as nothing works
Nov 10, 2013 | Ovens
AEG Oven model D98000VF - error code F8 on display. All functions failed (no grill,ovens,hob)
I am pretty sure this is the temerature probe that has failed it can also be a failure of the main control board see how you get on but resubmit question if in bother.Hope I helped.
May 02, 2010 | Electrolux Ovens
PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Please rate my solution.
Thanks.
Apr 27, 2009 | Bosch HBL 5032 Electric Single Oven
Where is the reset button
Hi.
thanks for request re your gas oven,unfortunately ,I have no experience of gas ovens, and am therefore unable to help solve your prob.
Check the experts, and see if there is one who is conversent with gas ovens.. Once again , sorry.
Jan 10, 2009 | Electrolux EOG7330WN Gas Double Oven
How can i mend the grill and oven on my electric cooker?
If the rings work o/k then could be timer if it has one make sure it is set to manual and not auto.
Another thing it could be is a faulty selector switch, which selects the different functions.
Hope this helps.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Ovens
Electric oven and hood not working but grill is?
Make sure the timer is set to manual and not on auto.
Dec 10, 2008 | Zanussi ZBQ665 Electric Single Oven
SMEG Oven won't heat up
This is late response but this fault is your fan element. You have two of them, if heating slower than usual, it is only one that has failed. When replacing one, it is recommended the other one be replaced. Tripping the circuit breaker is the symptom. These elements 2100 Watt each are anywhere between $70 to $110.
Service Tech.
Dec 10, 2007 | Ovens
Electrolux EOG7330WN Gas Double Oven Logo
1,440 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
