A/c ok! you are right the compressor is turning on, does not stay on, blowing cold air however it does not adjust to the settings selected and therefore does not get "real" cold based on the setting selected and that is why I thought the compressor was not working.
  • 828 Answers
You may want to check the size of your A/C in BTU's to the size of the space you are trying to cool. A rule of of thumb on this would be 200 sq ft to every 6,000 BTU capacity.
Posted on Jul 18, 2008
Toyota wish.1.8...aircond not cold...gas ok..circuit ok relay ok...compressor ok..but still not cold....when turn on ac only blow air but not cold...tq need answer
Make sure the compressor is actually turning. Most auto compressors run a magnetic clutch drive. When the air con is turned on, an electro magnet pulls the compressor clutch in so instead of the pulley just idling, it turns the compressor as well. You normally hear a loud click when the clutch pulls in. If you have a close look, there is normally 1 wire coming out from the drive end of the compressor which is the feed wire for the electro magnetic clutch. Check if this has been disconnected or broken.
Sep 17, 2015 | MagnaFlow 2006 Toyota Matrix - 2WD, 1.8L...
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Apr 22, 2014 | Frigidaire FAM157S1A Air Conditioner
Compressor turns, holds a charge but does not blow cold air even when I turn on the outside air it blows warm air
OK, this is air-conditioning 1-0-1
You say that i holds a charge, and the compressore turns, but does the comprressor cycle on and off, as this is indicating that there is enough charge, and once there is low pressure detected, it turns the compressor on, and when it reaches a high pressure, the compressor cycles off.
Lastly, when engine running and AC on, if you feel the 2 pipes going in to the firewall, one should be hot, the other should be cold ???...is this happening ???
Mar 28, 2011 | Ford F-150 Cars & Trucks
I have a 1989 Mazda 626 with no air conditioning. i would like to change that being its getting around 90 degrees already so please help me. Ok on the control board for the a/c 1 and 2 wont blow air. 3 and...
hmmm maybe a bad compressor bearly giving what it has left till it dies? if your getting cold air then there is not freon leak i would think. its gonna cost you. you gotta take it in to some pros. ac stuff is never simple unless its low on freon. are you hearing a loud scratchy sound while its on coming from the compressor?
Apr 24, 2010 | 1989 Mazda 626
AC blows cold or hot
if it is the same thing that is wrong with my frontier. check to see if the compressor is turning on when you use the ac. if not you might have a bad connection that is intermittantly preventing the compressor from getting the signal to turn on. get a service manual and a voltmeter and you can fix.
Jul 01, 2009 | Nissan Frontier Cars & Trucks
Freezer is ok, but lower section does not stay cold even at max
I think it's a compressor problem, must be compressor air is low .
May 26, 2009 | GE Refrigerators
Ac blows hot air ac compressor is ice cold but the vents blow hot air when enige is hot. bloows cold air when engine is cold
check your air diverter doors, sounds like the door for heat is open, when a/c is selected the doors should move and close the heater off. the heater will over power the a/c. the door controller is located on the environmental station under the dash neat to the floor. the control is electronic and probably not functioning
Mar 20, 2009 | 2003 Ford Explorer
Cooling problem
Since it is not so hot outside you may have to adjust the Thermostat to a lower setting to get the AC unit to kick on the compressor and blow out cold air. Give it a try, and if not the T-stat then we can go from there.
Jul 14, 2008 | Office Equipment & Supplies
Air conditioner problem
You may have an extremely intolerant cold control, a weak gaurdette on the compressor, a compressor motor winding issue, or maybe an oversized unit for the area you are trying to cool.
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
115 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
