-   the clean light keeps blinking and I am unable to get it to stop. This has prevented me from using any of the cycles and so the unit is unusable. We've tried turning the power off at the breaker to see if that would work. Any ideas on how to reset this? The unit is 2 years old, but only has about 60 washes on it as it is our brand new weekend beach home-   bethanycondo
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will
stop working and lock the functions (clean light flashes 7 times, all
buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
...all
the lights will turn on briefly and the machine will start a diagnostic
cycle. You can press cancel or let the diagnostic cyle finish (1-2
minutes). You should now be able to run the dishwasher as normal.
If
the issue returns, you could have a problem with the heating circuit
(ie. element, thermostat or wiring). It rarely happens but it could
also be the door switch not engaging properly when the door is closed
(slightly bend the door latch down making sure it doesn't hit the door
when you close it).
Was this helpful?
Yes
No
8 people thought this was helpful
Popular Solutions for Kenmore 16602 / 16604 / 16609
I can't figure out how to take apart the spray arm on my Kenmore dishwasher to see if there's...
(More)
I can't figure out how to take apart the spray arm on my Kenmore dishwasher to see if there's anything stuck in there. The dishwasher is making a loud noise and I think there could be something stuck. I tried to unscrew it but it won't budge. Is it supposed to come off some other way?
dishwasher not cleaning dishes as good as before. is there a filter that needs cleaned or changed...
(More)
dishwasher not cleaning dishes as good as before. is there a filter that needs cleaned or changed somewhere?
