Re: Uniden 5.8 cordless how to turn the ringer on or off
Since you declined to specify the model of your Uniden system, I can only direct you to select it from the list beginning at
http://www.uniden.com/scat/cordlessphones_mnl to download a copy of the manual.
Since you didn't give the model of your Uniden phone, please select it from the list beginning at http://www.uniden.com/owners-manuals/cordless-phones/scat/cordlessphones_mnl to download a copy of the manual.
The procedure varies from phone to phone. Since you neglected to specify the model of your Uniden 5.8GHz cordless phone I can only suggest you select it from the list beginning here to download a copy of the manual.
Since you declined to specify the model of your Uniden cordless phone, I can only suggest that you select it from the list beginning here to download a copy of the manual.
Do you mean the Uniden EXI4560 2.4 GHz phone? With the handset in standby, press the volume up button (above End and just below the LCD screen). Then you will be able to toggle between the 5 available ring tones and volume levels. (I'm assuming the unit is set to Ringer Off which is another choice in the list.) Press End to confirm and save your ring volume setting.
All of the Uniden manuals are here: http://www.uniden.com/scat/cordlessphones_mnl . Use the drop down menu to select the type of phone and then find it in the list by numerical and alphabetical order. The EXI4560 is on page 4 under cordless phones.
You can increase the ringer volume from the menu ... by the way Uniden DECT 6.0 Cordless phone basically have very low ring volume ,,, try using an extra ringer which is very cheap or you can make your self ... A simple circuit diagram available on http://www.electronics2day.com/index_files/Page790.htm
My phone is a Uniden TCX905 model. Ringer Volume Choose from three ringer volume settings (off, low, and high). With the phone in standby(normal display), use button on center of handset. Press up arrow or down arrow to adjust the ringer volume.
