Question about Kitchen Ranges
Shipmate propane stove model #873, need replacement burner element for oven
  • awab Dec 04, 2008
    I have an 50 year old 3 burner stove with oven on top shipmate on my sailboat. the burner are not good anymore and the flame leaves on all pots a black stain. need new burners. the old burners been out off cast iron. need help to find the burners
    thanks
    email temp@awab.net
Call JP at 954-817-1246 at Gearbusters or check his ebay store. He has the burners and all the knowledge you need to know.
Posted on Mar 09, 2009
Is there something available to convert a hardwick propane stove / oven to run on Natural gas?
Should only be a matter of changing the jets, see a gas fitter if they can be changed.
Dec 20, 2015 | Maytag Crosley Hardwick Caloric Kenmore 8"...
I've just converted my stove from natural gas to propane and the oven and broiler flame are both to high, how can I lower them?
When converting from natural gas to propane you have to switch the regulator to propane. then on most modern stoves you have to turn the orifice hoods down to adjust for the higher pressure of propane. there are some stoves that you have to purchase a propane conversion kit with different orifices for the burners and oven burners.
Oct 01, 2015 | Kitchen Ranges
We have a kenmore 36665 propane gas range/stove. The range burners become very unstable and sometime blow out when the oven turns on. We replaced the main propane regulator and nothing changed. We had...
the oven is leaking
the oven is gas as well? the oven burner when on burns the oxygen in the air if that air travels up oven vent and your exhaust hood pulls it to outside
if your oven door is not closing proper that air gets into burner area the burners as well need air to burn but because this air is now depleted of oxygen the flames start to lift and dance starved for oxygen
you need a service tech
Jan 06, 2018 | Kenmore 36665 / 36669 Gas Kitchen Range
I have a kenmore range the oven burner does not work but the broiler does. The igniter on the oven element appears to glow in preparation of lighting but propane does not come out of the element. Now when...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
sgf
Nov 16, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Poorly functioning Shipmate stove
Hi
Normally pressing red buttons on stoves is for lighting the oven. You press the button, light the pilot light, leave it depressed for a minute and then that heats up the thermocouple, which opens a valve and allows gas to the main burner.
Shipmate Stoves are still in business, so you could contact them. The link also suggests places for Shipmate propane gas stove spares.
Shipmate stoves Google Search
Mar 27, 2017 | Brown Stove Works 23 in. TL03-3 Gas...
Replacing oven burner element, the lower element, for a GE stove
(I think it is 50 watts or volts??)
Most electric ranges are supplied with 220 volts - this is, especially at 60 Hz, deadly. You were lucky this time.
If the wires are not welded onto the element contacts, they might be so-called 'quick-disconnects' that pull straight off of blades that are part of the elelment.
You probably haven't hurt the range with the momentary short circuit since the chassis of the range is connected to neutral or ground so you just gave your breaker a workout. BTW, I have had to replace late breakers after they tripped. They wouldn't stay reset any more even after the problem was removed from the circuit. Don't be surprised if yours doesn't stay reset; it may not be a fault causing it.
Jan 18, 2009 | General Electric Stove/Oven/Range Chrome...
Whirlpool electric stove
The ideal thing to do, would to be to replace the elements themselves. Most heating elements for stoves are universal and can be bought at lowes stores. I found your model number specific burner elements on a supply website for 42.00 each on the 8 inch and 35.95 each on the 6 inch elements. I am almost certain, you'll find these parts at lowes or home depot much cheaper. If this doesn't help, let me know, we will try another route.
Apr 15, 2008 | Ovens
Kitchen Ranges Logo
722 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
