Question about Danby Portable Air Conditioner
Water is leaking everywhere
There is watr leaking everywhere, not sure where the hose is soppose to run!
Its the condesation pan you must hook a hose to the pans outlet then to a bucket for when it overflows :)
Posted on Aug 06, 2008
I CLOSE THE SHOWER OFF BUT WATRE STILL RUNS THROUGH AND DRIPPS
Incoming Inlet valve's plunger might not closing properly or ur faucet water valve defective.
Sep 10, 2014 | Camp Chef Triton Propane Hot Water Heater...
Water leak
Replace that hose. If it's a big hose, it must be one of your two radiator hoses. If it's a small hose (about 1 inch in diameter) it must be one of your two heater hoses, running from the firewall in back of engine to the engine. To replace hoses, drain your radiator before disconnecting hoses, or you will have coolant going everywhere. Good luck.
Jun 16, 2012 | 2004 Pontiac Grand Prix
1997 Olds ** watr leaking into floorboard. By searching all over google- i found a few situations where this car has a "wheel well" problem of throwing water from tire up into wheel well which...
No, you would need to replace the well but it sounds like this is not the problem, most of these that rott are visible with a light shining from outside in with trunk carpet removed from the sides, i think your problem may be in the front area. try sparing with a water hose, no pressure hose, spray around windsheild and see if it leaks inside, another thing to check is the heater box drain, theres a small hole coming through firewall that comes from the heater box , this drains water from ac and wtare that gets into box and drains it outside, check that to make sure its not plugged. if you notice the water after it rains then its not the heater box but check it anyway.
Mar 19, 2011 | 1997 Oldsmobile 88
I just bought a new kohler cimmaron biscuit 2 peice tiolet. it is installed correctly. every so often i hear the water running for a few seconds then it shuts off like its losing water and refilling. i...
check fill tube from the fill valve to the flush valve, if the end of the hose is close to the watr level it will back syphon.... recommend also putting in better inner components.. fluild master 400 a fill valve and a nice red korky flapper
Sep 02, 2010 | Kohler Cimarron 2-PC Elongated Toilet with...
How to stop it from leaking oil
Where does it leak from? If you can't tell because oil is everywhere, get a can of engine degreaser, clean the oil, hose it down and then run it for few miles to see where the oil is coming out from. When cleaning the engine with degreaser and water be sure to cover the electronics with some water proof material, like a nylon bag. Once you see the leak, area, please post the question again with more details. thanks
Aug 30, 2010 | 1985 Mercedes-Benz 300
Leaking from behind?
If the leak is coming from the back of the washer, the problem may be attributed to either a leaking water inlet valve, or the associated internal hoses that run from the valve to the dispenser. The following link explains how to access the inside of the washer and/or replace the valve (if required):
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
If the leak is coming from under the front of the washer, the problem may be the drain pump. These pumps can develop cracks and start leaking. they are non-serviceable and will require replacing is defective. The following link explains how: http://www.fixya.com/support/r397092-replacing_water_pump Inspect all internal hoses and hose connections as well. There are two drain hoses on the water pump, and several small hoses near the water inlet valve. These hoses can develop leaks over time. If the leak appears to be coming from the bottom of the wash tub, you may have a leaking tub seal, or cracked wash tub (worst case scenario). You will see tell-tale signs of water marks on the gearcase (transmission) if this were the case. On the lower right hand side of the wash tub is an air dome with a small rubber air hoses attached. Make sure this hose is still attached and has no leaks. The air hose can slip off the nipple it is attached to and water will begin to pour out of the washer when it starts to fill. This will be an "attention-getting" leak as water will gush everywhere. Double check the air hose just in case. If parts are required, you can purchase from any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop all of them for the best deals.
If you have any questions about this repair, or require additional assistance, please let me know. I hope you find this helpful.
Jul 30, 2009 | Kenmore 24032\24036 Top Load Washer
Water wont fill washer. The water currently in
The pump is probably clogged with a coin. Pull off the hoses and check the pump. Make sure you put a pan under the hoses to catch the water
Jun 27, 2009 | Frigidaire Washing Machines
Beko wmb1ow leaking cant see where from
Have a look at the hose that runs from the dispenser to the tub front.
They can leak when they rub against the shell.
Hope that helps
Nov 25, 2008 | Zanussi ZWF1430W Front Load Washer
Kenmore top load washer leaks as it fills and drain hose is not an issue. There is a small hole in the plastic hosing where the two hoses meet, but why is water even getting to that point when it should be...
As the washer fills the water will go up the drain hose to the same height as the watr fills in the tub. That is why the drain needs to be higher then the tub or the water can just run down the drain.
Apr 25, 2008 | Washing Machines
Whirlpool dishwasher leaks everywhere
CHECK YOUR HOSES FOR CRACKS. BE SURE THEY ARE ATTACHED SECURELY TO THE PUMP OULET.
THERE IS ALSO A BLACK HOSE FROM THE VALVE THAT GOES UP THE LEFT SIDE TO A VACUUM BREAK ON THE SIDE OF THE TUB. BE SURE THE HOSE HASN'T BEEN DAMAGED OR DISCONNECTED. IF THERE IS SUFFICIENT SUPPLY HOSE, PULL THE DISHWASHER OUT OF IT'S INSTALLATION AND TURN IT ON. WATCH FOR WATER DRIPPING ON THE FLOOR AND TRACE IT BACK TO FIND THE PROBLEM.
Mar 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Danby Portable Air Conditioner Logo
195 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
