Question about Quantum Computers & Internet
Quantum fireball lct 20
My pc wont detect my hdd my jumper is set to master
  • 129 Answers
Is it the only drive installed? If so, you may have to reinstall windows from the genuine disk. Check cable to motherboard too and come back to me for more if this fails
Posted on Jul 20, 2008
Need jumper setting for quantum hdd 3.5 series fireball lct ,LB10A011 10.1gb to set up as a slave hdd ,thanks
Try this if not then get back to me and i will see if i have another diagram. I had to dig for this info too old haha. i still work with this stuff
Feb 27, 2011 | Quantum (LB10A011) Hard Drive
Will a Quantum Fireball hdd replace a Sata hdd.Both are 3.5 and 5/12v or do you need to re configure them?
SATA (serial ATA) is a connection type, not a brand of hard drive. Any brand of hard drive will replace any other, as long as they are both SATA drives. The data and power connections are standard between drives, as are mounting dimensions. Normally, with SATA drives there are no jumpers or other configuration you need to deal with. Each SATA drive has its own connection to the motherboard, so you don't need to set master/slave jumpers like you would on the parallel ATA drives using the wide data cable.
Nov 14, 2010 | Quantum Fireball Lct20 (QML20000LD-A) 20...
I have a hdd quantum fireball lct 10 3.5" series with the serial number 973006916882 papxx power req 5/12v 600/900 ma. My question is about the capacity of this hdd since it is not written as I want to...
my hdd was install in IBM pc. Aftr that i am install my hdd in my assemble machine. My hdd is good condition.In BIOS HDD property is show perfect but when i want to format my HDD maybe fdisk or winXP CD my HDD is not work properly from this time. Please help me..........
May 20, 2010 | Computers & Internet
Hard disk not recognized
found the solution inside Dell web page - jumper position shown graphically - Thank you, anyway.
Jan 07, 2010 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Quantum Fireball lct 30gig not recognized in Dell Dimension 3000
Turns out this particular drive needs TWO jumpers on it, to set it to CS. I received it used with a single jumper in the Master position, but after checking the Maxtor/Quantum website, it listed the jumper positions and showed the second jumper. As soon as I installed the TWO jumpers in the correct position, the Dimension 3000 booted right up and let me reinstall Windows. I had scoured the internet for many hours looking for a solution, none solved it until I decided to check the manufacturers website. Always start there!- Solved!
May 18, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Setint the jamper as a 2nd drive and Do i need to farmat it frist
If I recall right this HDD is a PATA (IDE) type. As for the Jumpers please check the following link. The jumper should be as Slave drive.
http://www.helpwithpcs.com/upgrading/install-hard-drive.htm
May 15, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Problem putting a 30 gig quantum lct 15 3.5"series as a slave
Did you switch the jumper config back to Master or CableSelect before trying to install them as a single drive? Also check the Maxtor website, (they owned Quantum too), for the correct jumper settings. Some of these drives (like the Quantum Fireball lct series) need TWO jumpers not just one.That was the trick that fixed mine from not being recognized by the Bios or the Windows setup disk....I got it used with only a single jumper, but it needed two to put it Cable Select mode.
Apr 07, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Fireball 30 gb not recognizeable to new pc
Bad drive motor the disk itself is the problem, you may have to get a software that can get those files you need off that drive,in fact you will need a software that will get those files.
Jan 10, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Hard drive quantum fireball lct 20
go to quantum website, download manual, check for correct jumper settings
Dec 03, 2007 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Computers & Internet Logo
452 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
