Sanyo CE32LD81-B - Stuck in standby after loss of digital signal. Will not switch back on, tried unplugging everything but nothing works.
MicrowaveSvc
  • 9098 Answers
SOURCE: No digital signal but analog works fine
Seems like this was already answered? But once you've checked against the owner's manual and ruled out the PC, I would suspect the signal / video board inside the monitor. May have gotten a surge or static, etc.
Posted on Jan 12, 2007
SOURCE: Sky Remote code for Sanyo LCD TV
I HAVE FOUND THE CODE AND SKY NEVER HELPED THE CODE IS AS FOLLOWS DEPENDING ON HOW OLD YOURE REMOTE IS 0065 IF YOU HAVE AN OLD REMOTE TAKE THE FIRST ZERO AWAY
Posted on May 01, 2009
  • 5 Answers
SOURCE: AC stuck on cold, compressor still hums after power off. Tried up and back down temp settings, tried ac reset switch, unplugged 15 min. It is still stuck on after I plug in again.
sounds like your switch is bad still allows power to compressor when it shuts down the blower,,.....
Posted on May 31, 2009
dave1645
  • 834 Answers
SOURCE: my sony wega will not turn on, the standby light
the flyback and horz out are bad and will need replaceing about a 100 dollar job
Posted on Dec 04, 2009
saidneurot
  • 128 Answers
SOURCE: element stuck in standby and wont turn back on.
you can unplug the power cord and drench the power and after go ahead and plug in back the TV and try to start it
Posted on Jul 30, 2010
Keeps saying no signal
You got a meat probe ? maybe its waiting for that?
Dec 21, 2016 | Sanyo Microwave Ovens
Sanyo tv troubleshooting CE32LD81-B/UK
If the set should not come out of standby, the fault should be with its main digital control board itself. Troubleshooting procedure to these boards are very skilled work, and need all measuring instruments, and expertise. To get more details, http://electronicshelponline.blogspot.com/
Nov 14, 2013 | Televison & Video
Tv keeps switching itself onto standby by itself. When left off for a while, it lets me switch back on but after a while, it switches itself back off
Unfortunately there are several reason why this may be happening.
The two most likely ones are a bad main board and a bad power board.
What I'd do if I were you is open the TV, inspect the power board for bulging capacitors, have them replaced if I spot some and if the problem persists I'd assume it's a bad main board.
Oddly enough all such main boards I could find on eBay were in UK...are you by chance in UK too?
You'd need 17MB22-2 021106 .
Hope this helps.
www.coppelltvrepair.com
Feb 22, 2013 | Sanyo Televison & Video
Hello, i have a sanyo dp 19648 that was working perfectly when last used, i have been away on a trip & turned all electric power right off from the mains & when i got back, the tv will not come on...
Power supply in set has a standby the runs 7/24 (all sets do and computers also) and the loss of power when restored may have damaged something there---a fuse is possible and should be looked at first---the Standby provides voltage for the remote to turn main supply and the set on.
Nov 06, 2012 | Sanyo Televison & Video
Sanyo ce32ld81-b has no picture or sound just flashes green, blue and red. It was working when I went to bed woke up and went to turn it on nd it wasn't working.
Tries tv unplug,replug it back in like about an hour later for the tv to do a resetting itself back to the factory setting.The tv now should be working again.If the tv still have the same result.Mean ur tv the tv power supply board it is the problems and the causes.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Sep 04, 2011 | Sanyo Televison & Video
My sanyo tv model CE32LD81-B is currently on standby but i cant switch it on with or without a remote i think it may have been blocked
I think it has a power supply fault. The standby power supply is a small, separate supply from the main power supply.
I hope that helps.
Mar 10, 2011 | Televison & Video
How do i turn on my sanyo tv model ce32ld81-b do not have a remote and think child lock is on
turn on at the rear (switch next to power lead socket) and the blue standby light on the front should illuminate. on the right hand side of the tv is a series of buttons, press the top one to start the tv, the others are channel up & down ,volume up & down. If you have a Sky remote you can programme that to run your TV
Sep 25, 2010 | Televison & Video
Unit works fine. However when it is switched to standby for a few minutes or longer then powered up. Nothing happens. Cannot hear the click of something, i assume a relay inside the unit. If the unit is...
I got same issue. Solution is to buy a efergy standby eliminator plug so it can respond to the On/Off signal by cutting off and restoring mains power
Dec 20, 2009 | Yamaha YSP-800 System
On a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
Aug 11, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Lost my Digital audio signal, stuck on analog
Hi - Please check the setup of the digital inputs as per pages 11, 20. 21 & 37 in the manual.
Most important:
Are you using coax or optical connections? Even if you have not moved them you should check they are securely fitted as they can work themselves out in time.
Let me know how you get on.
Best regards,
Informatica.
Sep 06, 2008 | Audio Players & Recorders
Televison & Video Logo
82 people viewed this question
Top Televison & Video Experts
