Question about HP Deskjet 2360 InkJet Printer
My printer wont work
My printer hp deskjet2360 wont print even all the connection are properly attached and the installer is installed, the LED on the printer is just blinking i thought there's no paper, but when i press again still nothing happens it remain blinking, i lost my manual so i dont know what to do...
  • Anonymous Jul 20, 2008
    same problem here
My cd installer is loss
Posted on Aug 07, 2008
My hp deskject 5650 printer wont print in colour help ??
Hi, When you have installed the ink cartridges make sure connections are clean that means finger prints as well. Clean with isopropil alcohol not rubbing alcohol. Next, check printer properties that software is working properly. If all is OK. Cartridge maybe clogged or defective (replace).
Jun 09, 2011 | HP DeskJet 5650 InkJet Printer
INSTALL PRINTER (HP DESKJET2360)I
Choose your operation system and download it from HERE
May 14, 2011 | Computers & Internet
I have a hp officejet printer hooked up to my daughters windows xp. It is installed and when you click on print it printing but it will not print. All the lights are flashing on the top.
Well here is the resolution for the problem.
As you had mentioned that the printer prints on given command print but the print outs are not coming out of it.
Well sometimes even if you had not set the papers in tray properly than also it wont take paper to print out.
It will sound like its printing but the paper is not getting in. So please check the paper tray if it is not set properly please set it or even the pages you used in it are in proper order or not even check that as well.
Well sometimes If the printer run out of cartridge than also it wont print anything even it insert the page ven it will come out as blank as it was inserted, So please check if your not run out of cartridge if so please change it and your printer will start working again.
Please do reply me if you still have the same problem or any more problem.
Naiven.
May 21, 2010 | Office Equipment & Supplies
Wont print lights flashing even after new hp ink installed - what now?
I had this psc and usually the ink was leaking or the cartrige head needed cleaning, or the cartridge was not installed properly. Just check these 3 things and you will find the problem.
Apr 07, 2010 | HP PSC 1315 All-In-One InkJet Printer
Print from nokia E63 through WIFI
Try connecting your printer directly to the wifi router/switch in a shared network configuration. Then go to your router settings, find the local ip address add this as the 'host'. Your settings should be as follows:
Driver : HP Mobile Printing
Bearer: Socket/HP Jetdirect
Access Piont: My Home Wifi (kaba)
Host : ip address of you printer
user : Blank ( tried my windows username,no use)
port : 9100
Printer Model: Officejet Printers
You will have to reconfigure your drivers on your pc as well. Mine installed as a wireless shared printer even though the printer is not wireless but I have it connected to my wifi switch for sharing and it worked fine.
Good luck
Damien_1977
Jan 07, 2010 | Polaroid PoGo Digital Photo Printer
Hp printer wont print through print server
Share printer option needs to be turned on
Realize that the scan option only funtions on local connection
Aug 11, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
My hp printer 3535 wont printer.it says the files are ready.The printer wont print them.
Hi
Thanks for using FixYa. Please check that your printer has paper, has no paper jams and is currently set on the ‘use printer online’ settings by right clicking property and then setting it from there. Also please check that you have selected the correct default printer and drivers in the printer options. If there is any paper jams clear it. You can also check the few things like---
Please check that both ends of the cable which connects the printer to the computer are connected properly. To print a test page right click on printer properties and then click the 'Print Test Page' button and see if you get a test page printed properly. If you do, this indicates that the printer is properly connected to the computer and the computer has the drivers installed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 04, 2009 | HP Office Equipment & Supplies
Scanner wont work
You don't give a lot of information to go by, but my best guess is that you don't have the proper drivers installed.
HP Scanners and printers usually require that you first install the drivers, then connect the device. If Windows still does not recognize it, reboot with the scanner attached. The 'Found New Hardware' wizard should pop up and install the drivers.
Download the latest drivers from HP's website and install.
Hope this helps.
Jun 28, 2009 | HP Photosmart 3210 All-In-One InkJet...
I am having HP Deskjet 3920 Printer. When i try to print any documents, it will show an error message that " The Triclor cartridge is incorrectly installed" , although still it will print color prints...
Hi Anish, Have u checked the printer cartridges installed properly(i.e., Color in color door and black in black door). and also check the cabling between the system and your printer. and put the papers properly. if the problem again persists uninstall the printer driver and install the latest drives which can be downloaded from the net.
Thanks,
Sriram.S
Chennai.
May 02, 2009 | HP DeskJet 3940 InkJet Photo Printer
Printer wont connect to pc
firstly you try shut down the printer and latter you un-install the anti-virus on the system and re-install the printer,Have encounter this kind of problem before in my office and this was what i used to solve the problem
Feb 13, 2009 | HP LaserJet 3050 All-In-One Printer
HP Deskjet 2360 InkJet Printer Logo
64 people viewed this question
Ben Johnson
