My espon R300 printer has stopped loading paper. its trying but not taking it in. The printer still prints on cd's via the tray but I think it might have knocked either a sensor out of line or the rollers that grip the paper and feed it in. I have used the service dvd to reset the software or firmware in the printer. this actually got the cd tray back up and printing. originally it was saying paper jam all the time. Something must have happened, I don't know of anything that has happened to the printer but i do have a 2 yr old son who could have knocked it with something. any help would be most appreciated. Cheers Steve
1 Other User Has The Same Problem
Comment by ajmn2007, posted on Aug 13, 2008
I´m a Senior Citizen and in this moment I can´t paid for service in my country ( Argentina ) please, If you have a Manual of Parts and maybe I can open the back part of the machine and repair the problem. Thanks for you help.
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Was this solution helpful? Show your Appreciation by rating it:
Post a New problem for Epson Stylus Photo R300 InkJet
Email this problem
Can you Help with these Printers problems?
Programs Lock until Printing...
Epson Stylus Photo R300 - paper...
my printer won't turn off
