Question about LG Refrigerators
I am getting an error in my refrigerator (FF error, i think it means freezer fan). The model i have is LRFC22750ST
    Master:
  • 505 Answers
I am so appauled at the quality, and service of of 2 year old LG fridge with ice despenser, which cost us $3.500. I was so excited to buy a new fridge after 20 years, and now wish I would of kept my old Amana.
After only a month there was a hair line crack in the Chef Fresh draw. I called and left message at LG and no one called me back it was after a month that I finally got someone. Then took another month to get someone to come out....and when a serive man came out he brought me the wrong part. Took another 3 months to reorder right part. Then the same thing happend again to the same drawer ..this time I called LG and asked if there was a recall on a possible manufacturer defect, and they said no and they proceeded to send me another part and the same thing happen I got the wrong part delivered I now have 2 new drawers that are useless because they are for a different model in my possesion. I called Lg to return them and they never came to get them.
And just recently the wheels on the crisper drawers on both sides snapped off, and the crisper lid cover hinges snapped off.
And just today my dials on our fridge are all blank and a ER FF sign has come on. which I have discovered means a Failure in Freezer fan motor., my fridge is not working at the freezer is starting to thaw....great I am dreading calling LG. Here we go again, it will be months before my fridge gets fixed.
I will never buy another LG product again.
Posted on Jul 18, 2008
What does ff error mean
For LG A FF error code indicates that the unit has detected an issue with the freezer fan. This can sometimes be caused by frost buildup.
https://removeandreplace.com/2017/08/27/lg-refrigerator-error-code-er-ff-how-to-clear/
Jan 06, 2018 | Refrigerators
What does FF mean on the display, it won't change the temperature
FF is usually a Freezer Fan error code. A qualified service tech needs to look at the unit, checking for iced over fan motor, loose plug connection, ect. Pleazer Appliance...
Sep 23, 2014 | LG LFX25971ST Bottom Freezer French Door...
WHAT IS THE FF EROR CODE MEAN FOR SAMSUNG REFRIG
FF = Freezer Fan Error, loose connection, over icing in the freezer or faulty fan motor
Sep 21, 2014 | Samsung Refrigerators
What er ff mean at Error message on display of Kenmore Elite Bottom Freezer Refrigerator
Hi.
Error ff (er ff) means defective fan detected. Before calling support or before replacing the fan try performing a complete defrost by leaving power disconnected for one day (remove food from inside the unit first). That will fix the problem if the fan was temporarily malfunctioning because of ice formation. If that does not work the fan must be tested before replacement.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 09, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
What does ER FF mean on my Kenmore Elite bottom
Hi
Thanks for using FixYa. Error ff is freezer fan fault. This usually happens when either the rear board has gone bad or the freezer fan itself is bad and needs to be replaced. To check what is causing the error you can start with checking the fan which is located behind the back wall inside the freezer. Also check the rear board as it might not be putting the fridge into defrost long enough and is causing the ice to build up in the freezer and thus stopping the freezer fan from turning and so causing ff error. Leave the fridge unplugged for 24hrs which will melt all the ice then plug it back if still the issue is not resolved and you hear the fan running then it is the rear board that needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jun 30, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kenmore Refr. Model # 795.77563600 has a Error FF
The FF error code indicates that the freezer fan motor is defective.
You need a new main control board and evaporator fan motor.
The fridge is made by LG, but rebranded as Kenmore by Sears. First 3 digits is the tell. You can call Sears for parts.
LG refrigerator repair in orange county, ca
Feb 05, 2010 | Refrigerators
Error message Er FF
er ff means that the control board is not sensing evap fan motor operation this means either a bad fan motor ice in the fan motor or bad control board. you can verify fan operation by opening freezer door and feeling for old air blowing from back of freezer compartment. you will have to push in the light switch to get fan operation.
for corndo that has same problem you actually have a different problem. er dh means the control board is not sensing defrost heater operation. the most common culprit is a bad defrost sensor. message me back if you need instructions for trouble shooting..thx peyton
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Error message
FF means the board hasn't recieved a response from the freezer fan.  Check voltage to fan.  If voltage is there then replace the fan.  The fan is most likely the problem.
Nov 01, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
213 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
