Question about HP 920 Plain Paper Fax
Need to change name and number
I was given the HP920 by a relative.  I would like to put my name and fax number in the machine and delete the name of the previous owner.  Any suggestions?
  • 158 Answers
Press the MENU button and press 7, then 2 on the numbers keypad. You can then use the keypad to change the fax header. Press the keypad numbers corresponding to the letters you need. It will cycle through lower case first, then upper case. Press the RIGHT arrow button to advance one space between letters.
Posted on Jul 18, 2008
How do I change date and time
Posted on Aug 07, 2008
How to register number has been delete. How do you put them back in a Pansonic Panafax UF-55o machine. The fax machine work just the long distance number that was register are going. Need to know how to...
function 72
press 01 on the soft key pad enter fax number
enter name with the letters on the soft key pad
continue with 02 as above or press stop
62 set to print diectory
Mar 24, 2010 | Panasonic Panafax UF-550 Plain Paper Laser...
MFC-8820D we have moved our office and have a new phone numder. How do we re program that number into our fax. Thanks matt
The following procedure will reprogram a new station (home fax number) for your machine. Thank you for using Fixya and please post back with any questions or to rate the answer provided.
  1. Press MENU 0,3
  2. Enter your new fax number (if the old still exists, move the cursor/arrow back ward to the first position to change the number displayed
  3. Press SET
  4. Enter telephone number (if it's the same as the fax number, enter the fax number again)
  5. Use the dial pad to enter your name (if your name still exists, leave it as it reads)
  6. Press SET
  7. Press STOP/EXIT
You will be given a choice to press 1 to continue with the change or 2 to exit without changes.
Press 1
The date and time will now appear and the change is complete
Sep 10, 2009 | Office Equipment & Supplies
How do I delete stored faxed numbers (speed keys)of the fax machine? How do you change a speed key title?(let say I fax documents to this fax number everyday: I stored the fax number under the name "Team...
From Ricoh Aficio MP2550 manual:
Delete destinations registered in the LAN-Fax Address Book:
numb01.gifOn the [Start] menu, point to [All Programs], [LAN-Fax Utilities], and then click [Address Book].
The [Address Book] dialog box appears.
If LAN-Fax Driver has already started up, click [Edit Address Book...].
numb02.gifClick [New/Browse...], and then select the CSV file containing the address list to be edited.
numb03.gifSelect the destination you want to delete so it is highlighted in the list.
numb04.gifClick [Delete].
numb05.gifClick [Yes].
numb06.gifClick [Close].
numb07.gifIf you made changes to a destination, a confirmation message appears. To save the changes, click [Yes].
If you do not want to save the changes and want to quit editing, click [No].
To return to the editing display, click [Cancel].
The confirmation dialog box does not appear when you have not made any changes after starting Address Book.
You can download the manual (HTML or PDF/ZIP versions) from here:
Jul 29, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
Speed dial
NEW Number
press destination like 01 the yellow part of the keyboard
enter fax number
enter name
Delete a number?
press as above like 02
press clear
press clear
press set
Apr 30, 2009 | Panasonic PanaFax UF-8000 Laser Fax
Given a Brother 590MC FAX machine, Need to remove previous detail
You can go under (menu) and then (Initial Setup) and using up or down tabs move till you see Machine ID. Press (menu) or (ok) button and change phone, fax number, and name. Press(ok) button after each is set to your specification. Hope this helped!
Mar 13, 2009 | Office Equipment & Supplies
Add and delete names and numbers from broadcast
How do I change the name and phone # on my fax machine. Sharp UX-510
Nov 25, 2008 | Sharp UX 510 Plain Paper Thermal transfer...
Brother all in one MFC
According to the user manual, which can be obtained at
if you don't have one handy, the steps to set your fax machine's number is on page 42. The steps to take are:
Setting the Station ID
You should store your name or company name and fax number so
they print on all fax pages you send.
1 Press Menu/Set, 0, 3.
2 Enter your fax number
(up to 20 digits).
Press Menu/Set.
3 Use the dial pad to enter your name (up to 20 characters).
(See Entering Text on page B-11).
Press Menu/Set.
4 Press Stop/Exit.
You cannot enter a hyphen in the fax number. To enter a space
press once between numbers.
If the Station ID has already been programmed, the LCD will ask
you to press 1 to make a change or 2 to exit without changing.
May 15, 2008 | Brother MFC 420CN All-In-One InkJet...
Need help changing the speed dial ID numbers
In order to change #01 to #21 its best just to program the number into #21 slot and then clear the memory for #1.
Start by trying to store a number at a location already used Press Menu/Set, 2 (Fax), 3 (Set Quick-Dial), 2 (Speed-Dial).
Use the dial pad to select the three-digit location (001 – 200) in which you want to erase the number and press Menu/Set.
The screen displays the name or number currently stored there, then prompts you to either 1. CHANGE or 2. EXIT.
Press the Stop/Exit key when the cursor is to the left of the digits. Everything above and to the right of the cursor is deleted.
Hit he menu/set key.
This should save the speed dial number as a blank.
Apr 29, 2008 | Brother IntelliFax-2820 Laser Fax
Adding and deleting into and out of group phone list
Group setting where? In the driver? In the menu in the machine? In some piece of software?
Are you refering to the name and phone number people see when you fax them?
Please be more specific.
Changing the name and phone number for faxing operations is covered in the owners manual. If you can't find the manual, there should be a copy on Brother's Web Site at
Dec 28, 2007 | Brother IntelliFAX 4100 Laser Fax
Incorrect Fax Number showing on sent Faxes
the solution given is correct. happy faxing OMNIPRESENT
Oct 01, 2007 | HP LaserJet 3050 All-In-One Printer
HP 920 Plain Paper Fax Logo
116 people viewed this question
Ben Johnson
