Question about Ricoh Office Equipment & Supplies
Error code sc 534 ricoh mpc2500 - Ricoh Office Equipment & Supplies
  • 263 Answers
This is an error in the sensor in the fuser. It can be caused by being dirty with toner or defective.
You can try this: Open the side door and take the fuser out. You'll notice that where the fuser fits have two sensors (on the left). With a brush try to clean the sensors.
Maybe that result. If this doesn´t, call for technical assistance.
Any doubt reply ok?!
Posted on Jan 26, 2011
  • gael pasbesoindesavoir Jan 31, 2011
    Thank you for the answer, but i don't find which sensor you're talking about, i only see a sensor on the middle top were the fuser fit, and on the left i see a small fan, nothing else.
  • santosj27
    santosj27 Jan 31, 2011
    have you already seen the fusing exit sensor fan motor (at the front right side of
    the machine).
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press 1 , 0 , 7
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
Mpc2500 sc 620-01
That is a Controller error. Unplug hard drive and reboot. If it goes away it is a bad hard drive. If it does not, then the controller board is bad.
Jul 28, 2014 | Ricoh Aficio Mp C2500 Copier
SMTP Scan to email problem on a Ricoh MPC2500
Ricoh scanner uses a email account to send the scan to email. That email account has the wrong password on Ricoh settings, probably someone changed the password and now needs to be updated. I hope it helps.
Apr 29, 2014 | Ricoh Office Equipment & Supplies
RICOH MPC2500 ERROR CODE SC491.What is the problem?
please visit ricohservice.blogspot.com endcoder from ITB maybe dirty...
Jun 12, 2012 | Office Equipment & Supplies
Hello, i have a SC-534 error code on a Ricoh MPC-2500 I have change the BICU board, nothing change, change the two fan on the right of the fuser, and i still have the problem, could this be the sensor on...
I think the sensor you're talking about is the thermopile. If that is what you mean, should give another different code.
Have you sow the fusing exit sensor fan motor (at the front right side of the machine)?
Jan 31, 2011 | Ricoh Office Equipment & Supplies
Ricoh 6513 Error Code Sc.387 Error Code Sc.457 Error Code Sc.350
1. Set SP3-125-003 to a value of
2 to enable Job End & Non-use
3 Self Check Mode.
fore more hrlp visit https://cbrtechsolutions.net
Jan 21, 2011 | Ricoh 6513 Copier
I am getting an error code SC 534 on my Ricoh Aficio MP 6000.
The best I can find is that this is related to a malfunctioning cooling fan, I cannot find that specific code for your model, but all other 534 codes from that manufacturer are related to cooling fans
B010/B188 SC 534 Right fusing pressure motor HP error 1 - HP sensor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - IOB defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - Motor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - motor drive bound
B132/B200 SC 534 Duplex exhaust fan error - Paper exit fan motor M28 defective, indexed as 146, electrical component layout.
B132/B200 SC 534 Duplex exhaust fan error - check and or replace fusing exhaust fan / paper blocking fan
B132/B200 SC 534 Duplex exhaust fan error - replace duplex fan motors M29 or M30
B222/B224/G878 SC 534 2nd duct fan error - replace fan motor
B230/B237 SC 534 Fusing exit sensor fan error, BICU defective
B230/B237 SC 534 Fusing exit sensor fan error, Fan defective
D014/D015 SC 534 Duplex unit fan error - Fuser exhaust fan blocked or has paper in it.
D014/D015 SC 534 Duplex unit fan error - Duplex Unit fan obstructed
D014/D015 SC 534 Duplex unit fan error - Fan harness disconnected or damaged
D014/D015 SC 534 Duplex unit fan error - Fuser unit connector has paper obstruction
D014/D015 SC 534 Duplex unit fan error - Replace duplex fan
D023/D025 SC 534 Second duct fan error - replace the 2nd duct motor
D023/D025 SC 534 Second duct fan error - replace the IOB
D027/D029 SC 534 Second duct fan error - check connections and harness to fan
D027/D029 SC 534 Second duct fan error - replace fan motor
D037/D038/D041 SC 534 Fusing rear fan error: Check or replace harness
D037/D038/D041 SC 534 Fusing rear fan error: Replace BCU board
D037/D038/D041 SC 534 Fusing rear fan error: Replace fusing rear fan
D037/D038/D041 SC 534 Fusing rear fan error: Replace the DRB
Jun 13, 2009 | Office Equipment & Supplies
Ricoh Service Code error - Service Code SC-300
I am a Ricoh tech and my service manual doesent have a 300 code,
Jun 09, 2009 | Ricoh Aficio AP3800C Laser Printer
1,089 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
