Question about Video Cameras
Handycam cartridge won't go down when loaded
  • HissamuddinS Aug 31, 2008
    Sony Digital 8 Handycam DCR-TRV330.
    When loading the cassette holder (cartridge) is not going all the way down.
I will send you a check or I can gave you my check number.
Posted on Aug 31, 2008
When opening my printer to get to the cartridges, they are stuck inside the printer and won't move. The on/off button is flashing.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 26, 2011 | Lexmark Z2320 InkJet Printer
Print cartridge would not move to loading position to allow installation of new cartridge
Aug 17, 2011 | Lexmark X2690 All-In-One InkJet Printer
How do I change the ink cartridges on a lexmark 5495
Please follow the steps below on how to replace ink cartridge on the Lexmark X5495 printer:
  1. Make sure the printer is on.
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
May 15, 2011 | Lexmark X4650 InkJet Printer
Just need to know how to put in black ink in the z1300
Follow these steps on how to install the cartridge: 1. Make sure the printer is on. 2. Lift the access cover. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. 3. Press down on the left cartridge carrier lever to raise the cartridge carrier lid. 4. Remove the used print cartridge(if you are replacing). Insert the new black cartridge in the left carrier. 5. Snap the lid closed.
3. Remove the used cartridge.
4. Load the new black cartridge. Close the cover.
Apr 29, 2011 | Lexmark Z1300 InkJet Photo Printer
Do not know how to change ink cartridge x2650
Lift the scanner unit, and then press down on the cartridge carrier latch to raise the cartridge carrier lid. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Remove the used print cartridge. Insert your new cartridges.
Apr 28, 2011 | Lexmark C533DN InkJet Printer
How to change printing cartridges
Here's how to change your cartridges: 1 Make sure the printer is on. 2 Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. printmastert_25.jpg
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid. printmastert_26.jpg
4 Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
You may also refer to this link: How to Set Up the Lexmark X3600 or X4600 Series All-In-One
Apr 04, 2011 | Lexmark X3650 Printer
While down loading Video on PC the video
Using FireWirecable & card will be the absolute solution.
-Stable,trouble free data transfer during video capture.
-Video transferred at its maximum resolution 720*576 pixels or something like that compared to 340*240 via USB transfer.
-100% supported by any video editing program,even the simplest Window Movie Maker.In other words,forget Sony's software - use something else that wouldn't run you.
Of course,the cable&card might be not very globally available like USB device.But still easy to find and relatively cheap to buy anyway.
May 18, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
Cartridge loading
the cylinder drum of your camera is not running that why c 31:40 is appearing to the screen...or may be the cylinder drum is stuck up...if the drum not running when you move it it is possible that it have to replace the whole cylinder assembly but if it's freewheeling then try to clean the contact of the cylinder connection pin using a pencil eraser sometimes it is a poor connection only...
Dec 04, 2007 | Sony Handycam DCR-TRV350 Digital Camcorder
Video Cameras Logo
78 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
