Question about Adler Royal HT500X Shredder
Won't shred my shredder will go into reverse but ewwill not shred, no sound, nothing..
  • davemel Jul 18, 2008
    Is it garbage ? I've only used a handful of times..can this be fixed?
    Thanks !
    Master:
  • 505 Answers
Maby the blades are blunt thats what it sounds like to me i had this problem with my shredder
Posted on Jul 18, 2008
  • ILL Tell you the what i think its really not worth it cost you more to fix when its cheaper to buy a new one
  • if its under warranty send its back get a refund
My Black & Decker Shredder #BD-61 all of a sudden does not work. I used it tonight, but the next time I tried it does not work. The lights come on in both positions, but
On some shredders when both the forward and reverse LEDs are on it can indicate either a jam or a full receiver bag/ container (the area that the shredded paper is fed into).
Try the following steps:
  1. ) unplug the power
  2. ) open up the shredder (see 1 on diagram)
  3. ) empty out all the shredded paper (see 2 on diagram)
  4. ) check that the shredding jaws (both the entrance and exit) are clear of any shredded material (see 3 on diagram)
  5. ) put everything back together
  6. ) plug power cord back in
  7. ) force the shredder into reverse (see 4 on diagram)
Hopefully you should hear your shredder motor running. If it is switch it to automatic and try shredding again
Jan 24, 2015 | Shredder Office Equipment & Supplies
My shredder worked fine but now when I turn on it does not stop running and does not shred paper ?
Most shredders will have a shred and a reverse setting. Is it running in reverse? Has the bin been emptied? With the power off, you can remove the bin and manually pull excess shredded paper jammed in the cutting heads -watch out, sharp metal . Once cleared run single sheets for the first minute to help clear rollers.
Jan 05, 2015 | Shredder Office Equipment & Supplies
Shredder doesn't shred.
Shreader wont cut will reverse ok
Dec 17, 2012 | Office Equipment & Supplies
Shredder won't shred. can't hear motor in the forward setting only in reverse
Silverfox007:
There is a paper sensor at the throat of the machine that turns the machine on when it is activated by the paper when the paper is inserted. Something has happened to that sensor. Unplug the machine and remove the shredder head from the basket. Use a screwdriver to remove the screws at the bottom of the shredder head and open the shredder head. Look where the paper is fed into the machine and you will see the sensor. It may be unplugged/wire broken/sensor flag broken off... You'll know what to do when you identify the problem.
Sep 06, 2012 | Office Depot ATIVA DX120P Shredder
My VF 1012mx paper shredder won't feed the paper in order to shred it. Green light is on but nothing happens when I put the paper in.
Does it run in reverse.????
You may just have dirty "eyes" where the paper is inserted, OR they may be defective.
Jun 04, 2011 | Royal VF1012mx Shredder
My AS101bCD Aurora shredder will not shred paper, green light on paper in nothing, will happily go in reverse, what can i do
Sounds like a problem with the switch. Replacement is the most likely option, switches cannot normally be repaired.
Jan 26, 2011 | Aurora Electronics AS1018CD Shredder
Will not shred, but will go in reverse
Sorry don't mean to point out something obvious, but are you being shown any indication lights that the waste basket is not seated correctly in the bin or the head? If not, then you may want to try and check these connections anyway. Lights can burn out.
Aug 22, 2009 | Fellowes PS60-2 Shredder
ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Aug 11, 2009 | Royal 1280MX Shredder
Makes noise but won't shred
Had the same prob with a Schneider shredder. The roll pin that secures the nylon driven wheel to the blades shaft was sheared. Easy fix in a way but original pin was a metric size.
Jul 13, 2008 | Tech Solution TS-2550 Shredder
My shredder stop shredding. has paper caught in it
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
Aug 29, 2007 | Quartet gbc 6120S Shredder
Adler Royal HT500X Shredder Logo
154 people viewed this question
Top Adler Royal Office Equipment & Supplies Experts
Electroboy
Electroboy
Kevin Michael
Kevin Michael
P Scarbs
Level 1 Expert
Are you an Adler Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
