Question about Xerox WorkCentre M15i Laser Printer
Light copies Copies are light but prints and reports are ok. I would like procedure for adjusting shading. Thanks, Paul
    President:
  • 2,072 Answers
You enter the buttons in this order. " menu" " pound" 1934, the machine will come up with a T or tech on the screen, you have to then press the machine settings button then scroll to maintenance, press enter, go to adjust shading, place 5 white pirces of paper on the glass and run the procedure.
I doubt though that without removing and thoroughly cleaning the scanner that it will work properly. Those mirrors and the glass haze up badly and need to be cleaned to clear up copy quality.
to remove from tech mode once you do shading. Just POPO the machine. ( Power Off Power On )
Posted on Jul 18, 2008
How can solve in this problem
Dear
Go to TECH mode, doing......(pressing the following keys in serial within 3 secs.)
MENU,copies,<,>,menu,>.
next place a white A4 size paper on platen glass.press MENU scroll to display TESTING press OK, scroll to display SHADING ADJUST press OK . a print out will come.
This will display the status of CIS. if RESULT is OK in the print, Printed at bottom of the page, the printer may work but prepare for the scanner cable (black ribbon type,visible under the platen glass has to be replaced).
Thanks.
Feb 02, 2015 | Samsung SCX-4300 Monochrome Laser...
Sharp ar 5520
Check programme setup. before printing you should have a setup window to alter the shading same place where you enter number of copies required
Oct 31, 2013 | Office Equipment & Supplies
I have an image runner 3220. The copies comes out with the black print looking faded and brownish. Can adjustments be made? If so, how? Or developer changed? How again? Thanks, Paul
How many copies do You have? ( press 123 button )
If You have over 150 000 copies, probably you need to change the Bk developer unit. It can't be changed only the developer, but the whole unit.
This is quite expensive copier for maintenance. If the time comes for Bk developer unit it means that you will soon have to replace Y, C and M developer unit. Also when did you last time replaced the drum unit?
Be sure to post back the copy counter, for detailed instrunctions...
Regarding color adjustment, before that you need to clean the copy optics ( glass beneath and cis sensor ), then in user mode ( asterix key ) under copy settings find color adjustment and perform it.
It's like 5 sheets, beeing printed one by one and which you need to scann over copy glass, but in most cases it doesn't helps...
If You want service manual you can write on emma.servis@gmail.com
Jul 29, 2011 | Canon imageRunner C3100N Copier
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Replaced the power supply/controller pca on a ricoh 2210l. prints fine, but copies come out black. adjust shading procedure yields copy with vertical black stripes and sometimes a faint negative image of...
If the tonner has gone old please take it out and shake if for atleast 2 to 3 minutes before putting it back and takng printouts. The issue would resolve but its a temporariy fix as you would require to change the tonner .
Let us know if you need further clarification.
Thanks
Dec 30, 2009 | Ricoh FAX2210L Plain Paper Laser
Samsung SCX5312 copies look very pixilated/grainy. Prints look fine. I cleaned the Optics. This got rid of the background but did not correct the CQ. Has new drum & fuser. Problem is definitely in...
Hello sir;Did you reset copier after you replace a new drum? if not please do it, if still have problem, you need adjust shading;
Close doccument feeder, select adjust shading . press "set up" An image will be scanned and a ccd shading profile will be print put, if the printed image is different than the image the ccd is bad.
Aug 14, 2009 | Samsung Office Equipment & Supplies
LIGHT COPIES
You have to do what is called a "shading adjustment".
In order press "menu" #1934 on the machine, You will see a " T " displayed in the upper right side of your display. That means you are in the Tech mode. Some versions of software will also just say Tech.
Press the machine status button and then scroll to maintenance. Once there scroll to Adjust Shading, or Shading adjustment.
Place 5 pieces of clean white paper on the glass, 5 pages thick., not spread out, then close the cover and press start, it will ask you if you want to perform the adjustment , just press yes again. It will print out a page when done, that page displays across it, the pixils the the CCD in the scanner sees. If you notice it had some large deviations in it, the scanner will need cleaned. The numbers on that page will really mean nothing, Even if it says OK on the bottom does not mean the mirrors in the scanner are clean.
Jan 22, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Cannon laser 3175 ,after copies it print activity report
yes you can go into additional fuctions button then go into reports and turn off error reporting and activity reporting, or its under communication settings
Jan 13, 2009 | Canon imageRUNNER C3200 Copier
Have a Xerox M20i. Copy comes out light. Toner should be OK. Prints fine. Scans fine.
You need to clean the scanner. You can try doing the shading adjustment to calabrate the scanner but most likely the mirrors are hazed up. Since you can print fine you eliminate the laser.
To do the shading adjustment, you need to press in order,,, Menu # 1934, You will see a " T "on the screen, that will be the tech mode. Press the machine status, then go to maintenance, then scroll to shading. Place 5 sheets of white paper on the glass and then run the shading adjustment. turn the machine off and on, and run copies again. But most likely you will have to take the scanner off and clean it.
If you want to clean the scanner let me know, I will send you directions on how to do that. The mirrors in that scan head tend to haze up.
Jan 06, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre M15i Laser Printer Logo
125 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
