Question about Tally Office Equipment & Supplies
Tally t8006 'toner cg error' - Tally Office Equipment & Supplies
5 Suggested Answers
Jeap
  • 114 Answers
SOURCE: Can't Print with Tally T8006 Laser
can u print anything else?, if don´t disconnect the printer, reinstall drivers and connect again.
Posted on Jan 17, 2007
  • 6 Answers
SOURCE: replace belt CG
Set Belt CG The OPC belt cartridge needs replacement.
Replacing the Optical Photoconductor (OPC)
Belt Cartridge
Replace the OPC belt cartridge at least once every 12 months, or when
the control panel display indicates that replacement is necessary. The life
of the OPC belt cartridge for the T8106 is about 60,000 images (15,000
color pages), at a 5% toner coverage rate on letter-size paper.
1. Turn the power switch off.
2. Unlock the lever to open the front
cover. This releases the pressure on the
toner cartridges.
3. Unlock the lever to open the top cover
fully.
4. Pull the green OPC belt cartridge lock
levers up until they unlock.
5. Pull the used OPC belt cartridge
upward and out of the printer carefully
to avoid spilling toner.
6. Discard the used OPC belt cartridge
Caution! Do not touch or wipe off any powder that is on the OPC belt, nor expose
the OPC belt to light.
7. Remove the two shipping pins from the
new OPC belt cartridge.
8. Remove the protective sheet that covers
the photosensitive belt.
9. Slide the new OPC belt cartridge downward
into both green lock-lever guides
and into the printer carefully.
10. Push the green OPC belt cartridge lock
levers down until they lock.
11. Close the top and front covers carefully
until they both lock.
Posted on May 28, 2009
  • 117 Answers
SOURCE: tally t8006 colour laser constantly gives paper
Please unplug the printer cable eject the paper and uninstall the printer driver comletly and restart the computer after that reinstall the printer driver and insert the paper in paper tray.
it should be work now
Posted on Aug 29, 2009
  • 169 Answers
SOURCE: Printer error TALLY T8006 SVC F4 ERROR
I belive the SVC F4 error indicates the fuser fan is not functioning.
Check the fan is connected correctly, also check if the fan is working.
If the fan is not working it may need ot be replaced, alternativly it may be a IOD1 Board or the MCTL board
Posted on Dec 14, 2009
Tally t8006 colour laser constantly gives paper jam error but no paper is jammed
Aug 29, 2009 | Tally T8006 Laser Printer
Printer error TALLY T8006 SVC F4 ERROR how do I solve it ?
Jun 12, 2009 | Tally T8006 Laser Printer
Replace belt CG
Belt Cartridge
toner cartridges.
fully.
May 28, 2009 | Tally T8106 Laser Printer
Tally T8006 Network set up
You can access the the NETWORK men on the T8006 by powering the pritner ON holding down TRAY
You should then be able to change your IP Get method and network settings.
Exit the menu by pressing the UP Arrow untill you see RESET on the display, then wait wilst the pritner restarts and it should have saved the new network settings.
Dec 28, 2008 | Tally T8024 Laser Printer
Power the printer on whilst holding down the TRAY button to access the Network Menu
Mar 10, 2008 | Tally T8006 Laser Printer
Tray1:A4 SVC L1 ERROR
I too have just bought a 2nd hand printer (Tally T8006) that also worked well until the fuser oil seemingly has to 'swamped' everywhere and which now throws up the same error code as above. Will attempt to 'dry it out' and see if the code clears. Have also recently sourced an original installation CD, will check out fault codes when it arrives - Gazz
Aug 31, 2007 | Tally T8006e Laser Printer
Error Message ('replace belt CG')
To reset page counter after replacing the OPC belt or FC Roller please follow the steps below:
  1. Power the printer on while holding down MENU/ENTER key
  2. Release the key when the display shows "Utility Menu Clear FC Roll"
  3. If you have replaced the FC Roller then select this option by pressing MENU/ENTER key. If you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
  4. When one of these options is selected Press the MENU/ENTER key and the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute". Press the MEDIA key and the display will change to "Execute"
  5. Press the MENU/ENTER key and after about 10 seconds the display will change to "Completed Clear FC. Roll / Belt CG"
  6. Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
Jul 12, 2007 | Tally T8006 Laser Printer
Faint mirror image when printing
It's most likely one of 2 problems...the toner cartridge or the fuser. The toner cartridge transfer roller may still be charged and keeping a little bit of the previous page's information on it, to be transferred on the next sheet. I would try a different toner cartridge first to see if that solves it.
Jun 18, 2007 | Tally T8006 Laser Printer
T8006
There definitely must be a setting to reset the fuser counter. I cant tell you where to look as I am not familiar enough with that model. Check in the counter menus or the maintenance menus, or a reset menu.
Oct 18, 2006 | Tally T8006 Laser Printer
81 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
