Back to:
Tags:
Sony DVP-NS575P DVD Player
Sony DVP SMPS unit fault
posted by Saikrupa on Jul 18, 2008
I have a defective Sony DVP with SMPS. The SMPS is defective. On check up found the fusible resistance in the path of AC input is blown off and pin No.5 of Oscillator IC is burnt off. Requst your guidlines to proced further. Also let me know, how to confirm the working condition of Switching transformer both in cold and hot tests. Thank you.
Yours sincerly
C.R.K.Murthy
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 26, 2008
Not Rated (0)
welcomejee
Rank:Guru Guru
Rating: 86%, 792 votes
You can get complete power supply as one part from Sony. You can't repair it on component level because components are not available.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Sony DVP SMPS unit fault:
I don't want to Accept this solution
Can you Help with these DVD Players problems?
the dvd player used to work. now i try to play a movie,...
I think I have a differtent player, but my problem is the...
I was told this was region free when I bought it but can't...
I can't find the code for the little leaps leap frog for a...
can one update the software of dvp-ns575p to play divx...
Loading problems.
Repair Service
Find DVD Player Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
