I ran Norton Ghost 2003 to create a ghost image of my hard drive. The "operation failed" and left me in the Norton version of Dos. It says "returning to Windows" but it just hangs. I have tried various ways to get back to Windows (XP Pro) but all fail. Any ideas?
  • Tim Sedlik May 11, 2010
    What happens after you reboot the PC now? Where were you trying to ghost the image to? The same machine, same drive?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 95 Answers
Hi
Please use F8 key when windownxp starts and uninstall the norton ghost and then restart the system.
Jyothish
Posted on Jul 18, 2008
I want to format my hard drive
If you have a true image to restore from, as like what is created with Win7 Pro Backup, or from Norton Ghost, you should be able to make a total restore. The destination drive had to be the same size or larger than from the drive the original image was taken from.
With Windows, you will require the image recovery DVD disk that are created using the OS that the image was generated from. With Ghost, you will require the Ghost recovery DVD disk to restore the image.
Jerry G.
Nov 19, 2011 | Computers & Internet
Hi, How do I recover my Office 2003 Auto Correct from Norton Ghost? I back up my PC image and formated my hardrive. Now I want to reover just my autocoreect file and apply it to my new Windows...
This will only work if the drive with your new Windows installation is larger than the drive with your ghost image.
Assuming that the above is true, do the following:
Using disk management, create a partition on your hard drive which is large enough to accept your entire ghost backup. Restore your ghost image to this partition and then select any files or folders you may need. Once you have the necessary files you can delete the partition again if need be and use it for other storage purposes.
Let me know if you need any further assistance regarding the above.
Best wishes,
Graemevm
Dec 20, 2009 | Symantec Norton Ghost 14.0: Windows
Is it possible to make a backup of everything on your hard drive to an external drive
Yes it is possible you can create image of your all partition in external drive with "Norton ghost" software.
Then you can easily restore image to harddisk again when you need.
You can download it from below link.
click here
Let me know if you need more assistance.
Thanks.
Oct 02, 2009 | Microsoft Windows XP Professional
I keep getting the message 2010
After a BIOS upgrade or installation of a new hard drive, the following error message may appear at POST: ERROR
2010: Warning: Your internal hard disk drive (HDD) may not function correctly on this system. Ensure that your HDD is supported on this system and that the latest HDD firmware is installed. Press <Esc> to continue
Press <F1> to Setup
The system appears to boot normally after escape is pressed and the operating system will load.
Solution There are three possible workarounds to eliminate the error:
  1. Update the hard drive firmware to the latest level. Download the hard drive firmware update, and then apply to your hard drive.
    Note: This update requires a floppy disk drive.
  2. Replace the hard drive with one supported by the system being used.
  3. Use the hard drive, producing the 2010, error in the Ultrabay of the system or a docking station with the second hard drive adapter instead. The interface to the Ultrabay is parallel ATA. For more information visit, ThinkPad Second Hard Drive Adapter for Ultrabay Slim - Overview
Additional information This error is purposely generated to alert the user to potential problems with diagnostic or copy tools. There are known issues with several of these listed below.
  1. Disk Fitness Test (DFT) version 3.xx provided by Hitachi GST which uses vendor specific commands on the hard drive. These may not be correctly interpreted since they must pass through the serial to parallel ATA bridge. However, version 4.00 or later of the Disk Fitness Test (DFT) will work.
  2. HDDTEST version 0.28 by Hitachi GST does not function properly for similar reasons. Instead, use HDDTEST version 0.29 or later.
  3. DOS-based copy tools may function slowly or produce incorrect output, specifically previous versions of Norton/Symantec Ghost. These versions are not compatible with the Serial-ATA interface of the Intel ICH6M chip set. Documentation on this problem may be found at www.symantec.com. It is recommended to use either a newer version of Ghost, Norton Ghost 2003 (version 2003.789 or later) or Symantec Ghost 8.0 or later, or to use the -FNI switch when invoking Ghost from the command prompt (For example, Ghost.exe -FNI with the current version of Ghost).
Other disk copy tools and related applications, such as some backup programs, may also have similar behavior. The hard drives shipped in the affected systems will not display the message because they already have firmware that recognizes this new Serial ATA bridge chip. However, a similar drive from an earlier ThinkPad system or an OEM drive might cause the error message to be displayed. Customers may also notice the POST error message after applying a ThinkPad BIOS update if a drive without the firmware update is installed in the system. Some early systems were shipped with a system BIOS version that did not provide this POST error message. Updated BIOS has been released to provide this informative POST error message to users.
Apr 30, 2009 | Computers & Internet
WD 500 GB resized by Norton Ghost Restore to 120 GB and can not get it to original size.
You should partition your new drive first to say 160Gb (you lose a bit after formatting) for 1st partition and the remaining capacity for the 2nd partition. Because your Ghost image is 120Gb it can only restore to a partition of 120Gb, that is why it shows 120Gb on a 500Gb on a single partition.
You may be able to fix this problem without starting again by using Disk Manager (from Control Panel - Admoinistrative Tools) to create a 2nd partition on the hard drive and format this partition.
Apr 28, 2009 | Dell XPS M1210 Notebook
I wish to ghost my pc
two software I've used previously are Norton Ghost and Drive Image but I don't believe you can image to an external drive. you might want to research on a newer version of norton ghost. they might have driver for external drive. Both of these software can be purchase online and download it. Hope this helps..
Good luck!!
Joe
Mar 25, 2009 | HP Computers & Internet
Ibm thinkpad T40 Hard Drive change out
After fdisk and format you need to ensure that operative system is installed into yor hard drive. Using ghost you restore the image disk by booting from ghost image CD if you made a bootable image disk. Ensure Bios is set up to boot from CD.
If you used Norton Ghost ensure you captured the image of full bootable original hard disk drive for same computer. If it does not boot after restoring ghosted image, than the image it is probably not complete. If hard disk image is not good, easiest thing to do is using Windows install CD to installl again operative system, then you eventually restore ghost image.
Aug 17, 2008 | IBM ThinkPad T40 2373 Notebook
O.S.
you can use windows backup facility, start>all programmes>accesories>system tools>backup, or use a third party software similair to norton ghost if you wish to back up the operating system as well.
Sep 03, 2007 | Microsoft Windows XP Professional With...
Support for norton ghost 9.0
the only thing I can sugest is upgrade norton ghost or use another disk imaging program I use powerquest drive image this works with usb support this program is better than norton ghost I've used it on my laptop and pc backups as on my pc I do alot of editing and all editing software takes 15 gig and 4 hours to install with this it only takes 1 hour to recover all drive info. hope this helps
Aug 14, 2007 | Ximeta NDU10-120 (890345000151) 120 GB...
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
