Question about Zanussi Washing Machines
Zanussi ZWF 1621 S Front Load washer - LED Lights are not lit up
The LED lights are not lit up on my washer. I have changed the fuse in the plug and checked the sockets but this doesn't help. The washer was working the last time I used it. The washer is only 15 months old but just out of its warrantee period. Can you suggest what is wrong? Thank you.
  • diane31 Jul 18, 2008
    It's a washing machine, not a dishwasher, the solution posted was inappropriate.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 67 Answers
WHAT IS WRONG WITH YOUR DISHWASHER?
Zanussi ZWF 1621 S Front Load washer - LED Lights  - small_9_26.jpg For a detailed Dishwasher illustration, click below.
Built in
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
There's an error code on the digital display
It doesn't work at all
It cleans poorly
There's no water entering the machine
The water doesn't drain from the machine
It's noisy
It leaks
The dry cycle has problems
The door has problems
The cycle doesn't complete
I see an error code
The detergent cup doesn't open
The cycle times are too long
Note: If your repair problem isn't listed, click here to email the RepairGuru. He will give you the help you need.
It doesn't work at all If your dishwasher doesn't work at all, check these:
Power from the house
Door switch
Wiring
Timer or selector switch
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
if this helps please vote me a fix ya
Posted on Jul 18, 2008
  • chad Alves Jul 18, 2008
    Im sorry I didnt catch washing machine was doing 2 things at once,
    If your washer doesn't seem to work at all, check these:
    No power
    Lid switch
    No power
    Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
    Lid switch
    If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
    Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
    this should help please change the rating ,it was by accident
Remove knobs zanussi zwf 1621 w
some timer knobs had pop on front cover on knob the 2ba nut on inside of same.
Apr 09, 2015 | Zanussi Washing Machines
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Washing machine will not start
I don't think this is a GE model #, but any who, if you hear a humming <water valve sol> the product valve is not getting water to it, first, don' laugh, make sure both plumming valves are on..
If they are off and no one knows how they got turned off, it falls under the old "****-happens" deal !
May 20, 2009 | Washing Machines
Zanussi zwf 1231 w front load washing machine
all connections to the zanussi modules are plug and socket and are keyed so you can't put them in the wrong place
Jul 05, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi zwf 1432 front loader
check the filter down on the right and cleane it
May 28, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWF 1421W power failure
most likely caquse is door interlock. only way for you to test is to substitute
May 08, 2007 | Zanussi ZWF1420W Front Load Washer
Washing Machines Logo
521 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
